Like Tree1Likes
Old 11-30-2013, 11:51 PM   #101 (permalink)
[quote=justwannahavefun;5468258]
Originally Posted by Helioop View Post
Everyone who uses Kontronik ESCs raves about their quality and reliability, and especially about their superior governor function. I’m now among the converted, but it wasn’t easy. The Manual is barely helpful and customer service can range from great to non-existent; I’ve experienced both extremes. Long hard searches on the web didn’t unearth much help either. Maybe help is out there, but I didn’t find it. So I thought I’d share some of my hard-found setup experience for others left scratching their heads over setting up these wonderful ESCs.
I'm thinking of buying Kontronic. Motor and ESC. That's why I'm here. Trying to find out what people think. I like the idea that you love the ESC. I'm pretty put off by the fact that you have such hit and miss experience with customer service.
ANYTHING that costs this much money should have Mercedes customer service. This is not the first time I've heard of Kontronic customer service trouble. It's really got me thinking . This hobby is supposed to be fun. When spending on the upper end of the spectrum for a product a person should have nothing but positive experiences. Of course there will always be some quality issues. No one is perfect. But if you do have a quality issue Kontronic should be bending over backwards to help.
I did notice another post here on HeliFreak that had a Kontronic rep looking as if he was really trying to help a guy with a problem. That's nice when you're looking at spending $550.00 on an ESC.
It also worries me that the documentation is lacking. I've found this often in this hobby. I realize that it's tough to write really good instructions. That being said, it's no excuse. Why do manufacturers assume that all of us are at the same level and or experience and therefore do not need much help?
No matter the level, good instructions are a must. I guess I'm barking up the wrong tree though.
If you notice the post date of this thread is over 3 years old. In the last 3 years the support for kontronik in the United States has changed dramatically.
About 2 and a half years ago I purchased my first Kontronik product. It was a jive 100lv for a gaui x5 i owned at the time. I was astonished at the simplicity of the programming, and the dramatic increase in performance and efficiency. I did have a little bit of a time learning the modes and yes using the jumper was a bit of an annoyance but overall you could program in minutes and be ready to fly. There was a lot of information circulated about how to adjust throttle end points that was false that confused a lot of people. I had to research a bit and this thread in fact helped me figure it out, and from then on i started helping people realize what i had.
About a year and a half ago Kontronik USA was established headed up by Charles. I was fortunate enough to become a part of it and I have been providing help in any way i can on here and to people i meet. A US servicing facility was also created with the help of Greg Alderman (Helidirect). He now handles both Jive firmware updates as well as motor shaft and bearing replacement here in the United States. Charles can also provide firmware updates as well as being able to ship your esc internationally for any service that may be required at the factory in Germany.
With this new level of service we have been able to much better help customers within the US.
I hope this reassures you and if you ever need help PM me or send me an email or even call whichever you prefer. I am here to help.
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 12-01-2013, 05:59 PM   #102 (permalink)
Default Kontronik Jive ESC Mode & Governor Setup
I had help a year ago sending my HeliJive 120 in because I thought I had an issue. They sent it to Germany and it was checked out upgraded and returned no cost!!!! Can't beat that!!
On the iPad again,
JCL
AMA 954079. KG5BBF
JCLs is offline        Reply With Quote Quick reply to this message
Old 12-07-2013, 04:50 PM   #103 (permalink)
Got Heli Jive on the way! Just a little confused about auto-bailout;
After programming- can I keep my 3 position switch as I have it today:
Normal 0% <-- change this to "bailout" value*
IU1 45%
IU2 65%
*percentage that doesn't arm the Jive but works for bailout too: possible ??
So I just wanna keep my tx as it is today without any "bailout"/ TH switch..
Thanks fellows !!
Edit This could give me unwanted fast spoolups.....I just have to stay in normal mode more than 15 seconds if I'm on the ground
So much fun but so little time Bring it to work !
J_Rig is offline        Reply With Quote Quick reply to this message
Old 12-07-2013, 08:57 PM   #104 (permalink)
The way you set it up is using throttle hold as your bail out value aka a flat line between 20 and 30% depending on transmitter brand. You leave normal at 0 and use it of you want to cancel bail out early if you land before the timer is up and want to take off with slow start and as your arming curve
Richard Zappe
Old 12-08-2013, 10:16 AM   #105 (permalink)
That is very clarifying thanks.
I have to rethink my system(8FG) now, especially since I don't have a traditional TH switch in use. That is incorporated in the IU three position switch ( assigned: SE )
I wonder how people are solving this bailout switch physically.
Old 12-08-2013, 01:03 PM   #106 (permalink)
I use a separate switch for my Futaba radio and assign idle up 3 to the SC switch and use a 20% flat curve for Bailout with a Helijive, When setting up bailout with the Helijive for futaba you need to change 17% default TH value to 19 or so to get the tele ring tone for bail out activating you can use this value in TH if your going to use the TH switch for bailout, If using a separate switch with a flight mode curve return to the default value of 17 after programming bailout! This is for Futaba only, Spektrum bailout programming uses a TH value of 15-30% to get the tele confirmation tones for bailout programming . Heres a good thread to familiarize yourself with Bailout programming and setup these threads answer a lot of questions,The posts written by dl7uae are very informative! https://www.helifreak.com/showthread...=bailout+setup
Magneto is offline        Reply With Quote Quick reply to this message
Old 12-08-2013, 03:15 PM   #107 (permalink)
Hey thats some awesome reps, awesome good help!
Wait- why distinguish/differ "TH switch" and "separate switch"
Old 12-08-2013, 03:27 PM   #108 (permalink)
You can use either TH or a separate switch tied to a flight mode ,I saw your post and wanted to give you all the options!
Old 12-20-2013, 06:45 PM   #109 (permalink)
I am just getting a heli jive now and I have been flying with the ikon and dx8. My question is that my "travel" is set well above 100 in my throttle setting in order to make it 100% in the ikon setup. Do I leave this and the esc will recognize the endpoints or do I set the travel back to 100 in the DX8 and not worry about what it is reading in the ikon setup? Sorry if this has already been explained but I could not clarify by reading the post
cpatts2000 is offline        Reply With Quote Quick reply to this message
Old 12-20-2013, 07:41 PM   #110 (permalink)
HF MR Support
Default Kontronik Jive ESC Mode &amp; Governor Setup
Get the ikon right and HJ will learn the rest.
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 12-27-2013, 01:58 PM   #111 (permalink)
If you're using the Kontronik governor then do not adjust your throttle endpoints in the iKON setup. Set them back to default in your transmitter then do a mode 1 reset on your Jive to make sure they're correct.
Low speed, high drag
Otto Rotation is offline        Reply With Quote Quick reply to this message
Old 01-17-2014, 04:47 PM   #112 (permalink)
Exactly!! Setting up the Throttle endpoints for the Ikon is a No No as you are not using the Ikon Gov! Leave your throttle endpoints in the radio at default! 100/100
Old 01-31-2014, 10:10 AM   #113 (permalink)
+1
I made this same mistake a few months ago. It was pretty obvious that something was not right since the governor was not holding the headspeed. I would notice a drop shortly after loading the disc, like there was a delay. It was not responding to load as it should.
After adjusting the endpoints, the governor was able to hold the headspeed without breaking a sweat.
- 6S TREX 450 Pro FBL - µBeast, MKS, Castle Creations
- Goblin 500 - Kontronik Pyro 600-12, Jive 100lv, iKon, BK servos
- TBS Discovery - Pixhawk
- Spektrum DX7
SeanM is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 09:05 AM   #114 (permalink)
Question
im using a dx6i in normal should I set TC to 60 flat, IU1 to 65 flat, so I don't want 0 to 100 TC right? spool up at mid stick , wait for motor to kick, than take off, now can I hit IU1 while im flying, or do I have to take off in IU1 spool up, and the way I understand is that I have to spool up and wait every pac, do I have it right, dont want a freak show when I maiden the 570 thanks
pert is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 11:54 AM   #115 (permalink)
you got it right. you can change idle ups all you want after the first start up.
Richard Zappe
Old 03-14-2014, 06:18 PM   #116 (permalink)
ok, so if I'm in I U 1 at say 63% and while im flying I can hit IU2 at 65% the esc will do it by its self. im lost but if it works that's all I care, thanks
Old 03-15-2014, 02:46 AM   #117 (permalink)
That is correct. You will here the rpm change and stay at 65%.
Sent from my iPad mini using Tapatalk HD
Mikado Logo 600 mini Vbar - Outrage fusion50 ar7200bx - goblin 700 mini Vbar - dx7s - powerlab6
-kenny- is offline        Reply With Quote Quick reply to this message
Old 03-18-2014, 06:54 PM   #118 (permalink)
thanks kenny
Old 03-20-2014, 12:44 PM   #119 (permalink)
Question programming mode
I am trying to program a Different TX with My jive 120. TH set to 0, all trims to 0 and a linear TC. The Jive goes right into programming mode, however after the first beep and I apply full throttle to clear any programming nothing happens, as in no descending or confirmation tones. It just goes into two beeps, three beeps etc etc.
renefigueroa is offline        Reply With Quote Quick reply to this message
Old 03-20-2014, 01:07 PM   #120 (permalink)
Default Sv: Kontronik Jive ESC Mode &amp; Governor Setup
Futaba? Reverse throttle?
@TapaT green
