Like Tree2Likes
Old 07-18-2012, 03:21 AM   #301 (permalink)
What did I do with my protos today?
Got him a stretched brother...
SRIMOK 90E Faifa TJ VBAR HK-4525-UE
SRIMOK 90E Faifa Ellie VBAR P700-520
PRÔTOS 500 Brain HK-3026
PRÔTOS 500 StretchVbar HK-3026
rchelijc is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 09:06 AM   #302 (permalink)
I pickup up a used Protos from a club member and started getting it ready last night (teardown and rebuild with new servos and motor). Ordered a couple of parts from Helidirect this morning to finish her up and should be flying by this weekend if all goes well.
Next step will be to order a complete set of bearings and do a full swap after it's been setup and tested. The original bearings all look good, but I'm a bit too cautious to go on faith.
Bob P.
Outrage G5 - Outrage 550 - Gaui 200 - Gaui X5 - Trex250 - Trex450 - SJM 215 - MSH PRÔTOS - many planks
javabased is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 10:18 AM   #303 (permalink)
I'm more then positive most of the guys in this forum fly WAY better then I, but I do have fun..
I get to fly so much because I literally live across the street from the field I fly at, and I am done with my work shift at 2:30.. I charge at work or the night before, come in grab the packs and get goin.. sometimes I come in recharge and go back.. depends on if the field is busy.. yesterday and today no flyin to hot for me.
Sucks to because I came out this moring and a friggin boot was on my truck.. never loan (irresponsible women your car), so I was off today, but she is lookin pretty over there on the mantle lol.
Off to the SIM
Dx7s, exi 450 pro(I swear it's a trex by now lol)
MSH Prôtos: 500 fbl,MSH Prôtos 450 fbl
Blackout 250
ZMR 250
Dazhim is offline        Reply With Quote Quick reply to this message
Old 07-18-2012, 08:53 PM   #304 (permalink)
Lots of time on the Protos tonight.
  • Replaced D520 with Hyperion DS20-GMD
  • New boom
  • Aluminum Pulleys
  • Aluminum tail pulley
  • New main grips and FBL links
  • New Lynx canopy mounts
  • New Mavrikk 430mm blades
Did a bit of hovering, tracking was spot on, no need to balance the blades at all, very impressed with the Mavrikk's. Tomorrow I'll put some time into tail tweaks and see what she can do.
Compass | MKS
[ eXo | Chronos ]
jaofos is offline        Reply With Quote Quick reply to this message
Old 07-19-2012, 09:06 PM   #305 (permalink)
Sigh, more tail wag. When I first got the Protos (used), it had an old 18t tail pulley on it, never could get it to hold right, ended up going to the 20t. So after last crash, and getting a new full size rudder servo, I decided to try the 18t again and picked up the new aluminum 18t part.
First time flying it today and could not get rid of the slow hover wag with the 18t at all. I started with the ball at 13.5mm on the rudder servo arm, Param D red, BX gain at F (63.5% on DX6i). Dropped all the way down to Param D at purple and 60% gain, still there and the tail was horrible on response.
Came home and put the 20t back on, much better, but still a little wag in hover and when settling down to hover after a pitch pump. Moved ball back out to 13.5mm, seems to be a bit better, but still need some tweaking.
/sigh, we'll see how much I can figure out tomorrow
Compass | MKS
[ eXo | Chronos ]
Old 07-20-2012, 05:47 AM   #306 (permalink)
Are you sure that it is a tail "wag" and not something else - I have been chasing a wag / flutter on my 450 Pro along with a strange "chirping" noise. It all started after a crash when I changed / replaced a few things, so I replaced a whole load of tail bits without success,
I was thinking through what else I changed at the same time and I remembered that it was also when I changed my CC esc from running curves to governor, to cut a long story short, my "chirping and tail flutter /wag" was caused by having my ESC governor gain set much too high
Sorry if this is slightly off topic
Old 07-20-2012, 07:37 AM   #307 (permalink)
I haven't tried Gov mode on the CC ESC, still running fixed endpoints. Logging shows my headspeed staying within the 2600-2800 range, so I doubt it's related to that. Also the ESC settings didn't change between last build with the D520 and 20t pulley where the tail was pretty darn solid.
Compass | MKS
[ eXo | Chronos ]
Old 07-20-2012, 04:37 PM   #308 (permalink)
I flew a pack on the Protos today testing governor gain at 30 (CC Ice 75 Lite). It worked much better than expected: tail kicks are much smaller in pitch pumps or abrupt stops (previously gain was 25). I didn't notice any ill effects.
Also, this was my 300th flight ever
(counted on big helis 450 and above, I don't keep track of the mcpx flights). A little more than 509 total Ah thrown in the air
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 07-20-2012, 06:47 PM   #309 (permalink)
More tail issues.. I'm bout to give up on this servo and try the D520 again.
I've tried every iteration of servo arm ball distance, Param D and gyro gain I can think of.
I start with Param D Red, Gain at F, dial it back to D, then lower Param D and try again. I cannot find a combination where I am happy with the tail behavior. Tried this at 13.5mm and 11mm ball distance on the servo arm.
I'm open to theories at this point before I throw the D520 back on it.
Compass | MKS
[ eXo | Chronos ]
Old 07-20-2012, 07:30 PM   #310 (permalink)
When nothing else makes sense, go back to the mechanics.
I tore the tail apart and re-built it exactly as the manual shows. I noticed that there were some washers on the tail grip bolts that aren't shown in the manual, so I left them out, and wow, such a tiny thing made such a huge difference! I think one of the washers must have been a little too large and was keeping one of the grips from rotating properly at high speeds, which given the issues I experienced, makes perfect sense. So now I'm sittin with the ball at 11mm (gonna leave it here for now) and Param D Red, Gain at E on the BX. Gotta bump Dial 3 down a notch or two, the blades bark and bounce after left-rudder piro's, but I'm much happier now!
Compass | MKS
[ eXo | Chronos ]
Old 07-21-2012, 10:32 PM   #311 (permalink)
Got in six solid flights today. Put on the 3k tail blades, and had a blast. Flew her as hard as I've ever flown irl. Ugly tik-toks, hard rainbows, cyclic reversals, hard stops, full pitch speed runs, everything my meager skills could attempt. She took it and asked for more.
One weird thing. On one hard stop, the motor just quit. I hit TH, set her down gently, looked her over, put her back in a hover to verify all was well, and flew the rest of the pack. I didn't have any flashing lights, no esc error tones, nothing. I didn't have any other problems afterwards. :
Sent from my Tapatalk using iPhone.
Goblin 500 Sport HW 100v3 Brain2 KST Rail 516
Prôtos stretch AR7200BX Savöx 1250/1290MG Switch 473
180CFX DX18
RCHN #0650 AMA# 448427
th0rg0d is offline        Reply With Quote Quick reply to this message
Old 07-21-2012, 10:41 PM   #312 (permalink)
I had some good flights this afternoon, up until the end of the second flight, right as the timer went off, the belt slipped off the main gear, no idea how, but i was already coming in for a landing so it was an easy auto, no damage.
I came home and tightened up the belt and boom a tiny bit, we'll see how she does tomorrow.
Compass | MKS
[ eXo | Chronos ]
Old 07-22-2012, 04:55 AM   #313 (permalink)
Sounds like one way bearing letting go...
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 07-22-2012, 11:03 AM   #314 (permalink)
Hey, Thor. Don't oil the OWB. If you did, take it apart and wipe it clean. It will slip if it's greased. Don't ask how I know
Goblin Speed | iKon
Old 07-22-2012, 12:46 PM   #315 (permalink)
I haven't. I did though oil for the first time, the swash, main bearings, tail slider, and tail bearings. When it happened, I thought maybe the belt popped off the pinion. But, I managed to fly out the pack, and subsequent packs, without repeating the problem.
180CFX DX18
Old 07-22-2012, 04:49 PM   #316 (permalink)
to test OWB, grab your motor can to keep it from turning and turn your blades backwards, if it stays locked its fine, if you can make it slip, its broken.
Old 07-22-2012, 10:42 PM   #317 (permalink)
Well, I put her in today. 2nd flight, about 1min left on timer, I'm about 20 ft away, 10 Ft up. She starts a slow piro, I cant control tail. I know then I gotta land. Try to come down in Piro hover, but I cant piro hover yet. She picks up Piro speed, about 4 sec/rotation 6 ft up. OK, TH time. She goes in on her side. Edge Blades, Feathering shaft, 2 9650 gearset's. for sure. Both Long Uniballs pulled out of grips. I can Epoxy them in tho. Straightened the studs on them.
What caused it, Well, I think I ejected a tail blade grip. When I picked up the Pcs, one Tail was missing. Found it about 40ft away. And the Align Servo horn on my DS650 had broken. Down at the next hole, not the hole that the Uniball was bolted through. it's the 6 sided horn, so I can move to another arm on that for now. Figure the grip ejected, causing to much vibs for BX. The 70MM KBDD tails sure do have nice authority though. There a bit larger than stock, and landing is tough to not scrape them need to land left side down not right
I went to fly my B400 too, an she wanted to Piro as well. Found I had installed KBDD tails on backwards. Only change form last flight. So must have caused some flutter/vibes.
Dan Pesonen
FBL, Don't think about it, DO IT.
mCX2, nCPX, mCP X, Blade 400, MSH PRÔTOS, T-700N
"Tri-Flow"
I put that S*** on everything!"
banditpowdercoat is offline        Reply With Quote Quick reply to this message
Old 07-22-2012, 11:30 PM   #318 (permalink)
Stripped a servo gear today on an auto attempt on my second battery out of 4. Luckily I had ordered some replacement gears for my 9650s a few weeks ago. I fixed it when I got home and now I have two batteries already charged to fly in the morning before work.
William
Synergy N5C, 130x, Mini Protos 6s
wbefield is offline        Reply With Quote Quick reply to this message
Old 07-23-2012, 02:29 AM   #319 (permalink)
I haven't even flown my s9650s in the protos yet. I've got MKS 9660 metal gears on the way, which I'll swap, before I maiden her.
Old 07-23-2012, 03:01 AM   #320 (permalink)
Today I took my Vbar off in anticipation of the Brain.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
