Old 01-11-2014, 03:07 PM   #1 (permalink)
Default 800MX VS 850 MX
Is it worth upgrading the motor right away this is my first TREX 700 HV DFC helicopter? I'm wondering if I'll be pleased with the 800MX motor? I'm still in the building process.
Delljr is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 03:36 PM   #2 (permalink)
It depends on flying style, I find the 800 to be more than enough. Depending on headspeed you can still bog it if you push to hard this is more a result of not enough headroom than a lack of power though. If you want to run high headspeeds and push hard either motor will benefit from a gearing change.
waxman is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 03:38 PM   #3 (permalink)
I should add that the esc would need upgrading to change the motor.
Just build it and fly it stock.
Old 01-11-2014, 04:23 PM   #4 (permalink)
Default Re: 800MX VS 850 MX
I have the 800mx and it works very well for me. .I was running a HS of 2200 with the 12 tooth but recently installed the kde adjustable motor Mount and installed the 11tooth and dropped head speed to about 1990 and love it. . It was fine at the 2200 just not necessary. .I upped my pitch to 13 from 12 and really enjoying the way it flies at 1990.. it also added a minute of flight time. I'm at 4:50 flying 3d.. using the cc 120hv esc.
Sent from my Goblin while pirouetting inverted.
charles.frank is offline        Reply With Quote Quick reply to this message
Old 01-12-2014, 02:43 PM   #5 (permalink)
if you can bog a motor you are running to much of everything. you need to find a balance in the pitch length of blades and cyclic and what FBL you are using, Sounds like you are getting it there. The 800 will run hot just the way that motor is the 850 need a 160 esc the 800 you can get away with a 120 its all in the setup and style of flying
Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 01-12-2014, 04:47 PM   #6 (permalink)
Thank you Dino, I made the decision to upgrade to a 850MX which KV 490 or 540? Thanks
Sent from my SGH-T889 using Tapatalk
Old 01-12-2014, 05:23 PM   #7 (permalink)
Old 01-12-2014, 11:17 PM   #8 (permalink)
Ive only been flying for about 2 years so nothing to fancy. . Collective management not the best. . But heres a vid with the 800mx @ rpm 2000 13°collective
Watch "Trex 700e v3" on YouTube
Trex 700e v3 (4 min 42 sec)
Old 01-13-2014, 12:32 AM   #9 (permalink)
Nice flying..
Old 01-13-2014, 01:35 AM   #10 (permalink)
Could anyone explain the difference in kv? The 540kv 120A/250A
5330W/ 11000W (2sec)
The 490
115A/250A
5100W/11000W (2 sec)
If I did the conversion right the HP 490kv would be 6.8 HP/14.7HP
And 540kv 7.1HP/14.7HP
Also why would the 540 have more horsepower on the low end...
So basically why is the 490 the better motor?
Old 01-13-2014, 08:03 PM   #11 (permalink)
Is this your first 700 electric helicopter? or just first Trex 700?
willy000 is offline        Reply With Quote Quick reply to this message
Old 01-13-2014, 08:23 PM   #12 (permalink)
Yes, its my first 700... Have a 550 DFC...
Old 01-14-2014, 12:45 AM   #13 (permalink)
And you are wondering if you will be pleased with the 800MX?
You have to be joking! Im sure you would of been pleased with the 750MX.
There is a huge difference from your 550 to a 700.
Old 01-14-2014, 05:18 AM   #14 (permalink)
Yup. Fly it stock and get back to us...
AMA 373608
K2Freak is offline        Reply With Quote Quick reply to this message
Old 01-14-2014, 11:54 AM   #15 (permalink)
Thanks for all your suggestions....
Old 01-14-2014, 04:41 PM   #16 (permalink)
The 490
115A/250A
Kv is how many times the motor spins for every volt applied. So the higher the Kv the higher the motors rpms are. Now how it applies to you is your style of flying really. All around the 490 is ideal because it's still spins fast but has more torque. More ideal in my opinion for smack flying. Now if your the every day flier i doubt you will notice the difference. Also gearing may become a factor for running one or the other to suit your flying style.
I can guarantee you thou even if you had a 750mx...it has tons of power for most mortals. Also need to remember the bigger the motor the shorter your flights will be.
Lower Kv = slower, more torque
Higher Kv = faster, but less torque
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
Old 01-14-2014, 04:48 PM   #17 (permalink)
Great answer, thank you so much for the explanation... Good advice... Thanks
Old 01-14-2014, 10:51 PM   #18 (permalink)
What's your target headspeed? If it's 2200 (hard 3d) with the stock gearing you need the 540kV. If you are targeting sub 2000 you can look at the lower kV.
I run the 800mx and it's truly awesome and ballistic. It's the same motor used by some of the Align pro's in XFC. It has equivalent power to the 4525 Scorp. IMO the 850mx is extreme overkill, and doesn't strike the best performance/flight time balance.
OnTheSnap is offline        Reply With Quote Quick reply to this message
Old 01-15-2014, 09:24 AM   #19 (permalink)
Thanks, I have the stock 800MX with 520 Kv, so if I don't get the 2200 head speed that's okay, sounds like it will be awesome, Just got my Castle Creation 160 HVF so I will be installing that tonight. Can't wait coming from a T-rex 550 DFC..
Old 01-24-2014, 09:22 PM   #20 (permalink)
I have both 550pro with 730mc and 700pro with 800mx both are awesome but my favorite is still the 700.
TS3D#1
NanoCPX, TREX550 PRO DFC,
TREX700 PRO DFC HV, DX8
TREX 700 Pro, TREX 700LTop, GauiX3, Futaba 14SGH
Excalibur3 is offline        Reply With Quote Quick reply to this message
