Old 08-02-2014, 10:02 AM   #1 (permalink)
Default Nano help needed
Hello all,
After putting the factory brushless setup on my bird, and enjoying it for a while, I had an inverted crash. One result of the crash was that the 3 in 1 wouldn't bind anymore. All I would get was the flashing blue light and slight servo jitter. So, I sent the board off to Mega's Micros. I got it back and installed and it bound just like it was supposed to. I flew three batteries and noticed it didn't have the power it did before. Now, it is back to not binding at all. I haven't even crashed or anything since getting the 3 in 1 back from Mega's. This is really getting me to the point of frustration.
Is there anything obvious I am overlooking? I am getting to the point of not wasting anymore money on this little bird, which sucks because I enjoy flying it so much. I hope y'all might have some ideas, and thanks for your time.
Mike
mike77gmc is offline        Reply With Quote Quick reply to this message
Old 08-02-2014, 10:30 AM   #2 (permalink)
The only thing I can think of is undercharged batteries
Are you using the 45c's, they seem to give an extra boost.
Is your main gear pushed up tight against the frame and is there no play of the main shaft up and down?
I am sure there is a helifreak on this forum that can help more than I can.
Maybe you could by an extra board off ebay or such and send your non-binding board back for assessment to make sure it was repaired correctly.
I would spend the money to keep my nano flying because it is a good bird to fly.
Good luck with your heli
mtwarych3@msn.com is offline        Reply With Quote Quick reply to this message
Old 08-02-2014, 12:07 PM   #3 (permalink)
Thanks for the response. I only have 45c batteries and I checked the main gear on the shaft. It is ca glued in place and hasn't slipped. The low power I had after getting the board back was more like a slow spool-up type deal. I could bog the motor down in flight and it seemed to take a lot longer to recover it's rpm. As far as the binding problem, the only left I can think of is to take off the HH brushless set-up and go back to a stock motor to see if it will bind. Other than that, I'm clueless.
Old 08-05-2014, 04:40 PM   #4 (permalink)
There’s a step in the binding process that I keep forgetting to do. It’s step #6 in the manual. Maybe that’s the problem?
Binding Procedure for Computer Radios:
1. Disconnect the flight battery from the helicopter.
2. Power off the transmitter and move all switches to the 0 position.
3. Connect the flight battery to the helicopter. The 3-in-1 Control unit LED fl ashes after 5 seconds.
4. Push the bind switch/button while powering on the transmitter.
5. After 2–3 seconds, release the bind switch/button.
6. Move the rudder control stick to full right. Continue to hold the rudder control stick to
full right until the blue LED on the 3-in-1 control unit is solid.
7. Release the rudder control stick.
8. Disconnect the flight battery and power the transmitter off.
If you are using a non-computer radio (DX4e, DX5e), move the rudder stick to full LEFT.
Nano CPX, 300CFX, TREX 450 Pro DFC, TREX 550e Pro DFC
Freddy-G. is offline        Reply With Quote Quick reply to this message
Old 08-05-2014, 08:29 PM   #5 (permalink)
I went back and tried again, many times, by the book and still nothing. I shot Mega's an email, and am hoping for a reply.
Old 08-05-2014, 10:36 PM   #6 (permalink)
Remove all the components from the 3in1 and see if it will bind. If it does add one at a time until it doesn't bind and you will have your problem. If not your 3in1 is bad.
Order a new 3in1 and get back in the air and send your broken board back to megasmicros and then you'll have a spare.
Sure is a fun little bird when it is working. Keeps me opening my wallet, lol.
Mo helis, mo problems.
fishsticks is offline        Reply With Quote Quick reply to this message
Old 08-06-2014, 12:20 AM   #7 (permalink)
It may need a little oil on all the bearings. As far as non-binding is concerned it's entirely possible that the repair job failed and the board is kaput.
DX8, Mcpx BL, Tarot 450 Pro V2
bobsyouruncle is offline        Reply With Quote Quick reply to this message
Old 08-09-2014, 06:55 PM   #8 (permalink)
Curse y'all for talking me into spending more money on another board. This stupid bird is too freaking fun to fly.
Old 08-09-2014, 09:48 PM   #9 (permalink)
Maybe a daft question but have you tried binding with using the rudder stick? Have you tried binding with binding switch AND rudder stick held while powering on transmitter?
When I first got my nano it would not bind then I held rudder to the right while holding trainer switch (DX6i) and powered up my transmitter - it bound. When I set it up for my new DX6 it bound without doing anything with the rudder stick. I'm sure I read somewhere that if it has been bound using a computer transmitter there is no need to use the rudder stick to rebind it to same type of transmitter. This works vice versa for non computer transmitters.
Blade 450X - Savox, Scorp 2221-8 13t Slant Edge Lite50
Blade 450X (3D) - Hitech Servs Std ESC and 420 Motor
Blade 300X - Savox Servos, lynx tail, OWB, Talon 35, Hyperion 2213 3585 14t std main, DX6
andycrazy is offline        Reply With Quote Quick reply to this message
