DJI Multirotor Forum(A2/WKM) DJI Multirotor Forum(A2/WKM) |
05-08-2014, 07:28 PM | #81 (permalink) |
It requires a WKM or A2 with the PC Ground Station program. It called POI or point of interest.
AMA #844172 DJI S1000 Lightbridge Zen for 5D, S900 LB Zen for BMPCC, DJI Phantom 2 Vision +, P2Z2 with Data Link, P2Z3 with LB DJI Forum Support |
05-09-2014, 03:20 PM | #82 (permalink) |
DJI | iPad Ground Station
Can you make it fly sideways for example for 100 meters between 2 waypoints?
| SAB GREEN GOBLIN 700 | SAB URUKAY | Synergy E5 | Synergy E7SE | 700 Dominator | Futaba 18MZ | T-Rex 500 ESP DFC | Mcpx BLS | Red Bull BO-105 | 180CFX | Kyosho Hyperfly | TBS Disco | Disco Pro | Disco Pro AMOB | Caipi | www.youtube.com/hizlimax | |
05-17-2014, 05:55 PM | #83 (permalink) |
Thinking about buying the iPad Ground Station. I currently have a Naza H V2 with a iOSD Mini. Just wondering if I can plug the air end of the data link into the open CAN-Bus on my iOSD Mini, or do I need to buy a CAN BUS Hub?
TRex 600LE Nitro DFC Head Beastx VWinRC 550 FBL Naza H |
05-17-2014, 06:48 PM | #84 (permalink) | |
HF MR Support
Yes. No need to buy another CAN BUS
Lynh |
05-22-2014, 01:48 PM | #85 (permalink) |
DJI PC Ground Station Flight Data
Has anyone found a way to record/export/display the flight data that the ground station gets during a "mission"? It would be nice to "replay" a misson after the fact to see all the data. When flying, you may not be looking at all the data and later want to see what the max speed was, or altitude, or track, etc?
I know you could use like a "fraps" screen capture and play it back, but I was wondering if there was anything from the application itself that can record/export/display past missions? Thanks in advance John |
07-16-2014, 01:35 AM | #86 (permalink) |
Help
Hallo,
i'm Italian, i'm sorry for my bad english. I need help for a question about GS on iPad: When i use the search function, it doesn't work. I've connected everithing right. The gps is ok, datalink is connected to mini iosd and this is connected to PMU. The internet connection is ok too but, when i select a search function and type a anime of country like Rome or Milan, the message appears: "Request timeout" and the GS doesn't find the location. Ps i've a naza v2 on my dji F550. |
07-16-2014, 06:03 AM | #87 (permalink) |
When you first power up the GS, does it scan and find your aircraft?
Chris D. Bergen Bergen R/C Helicopters |
07-16-2014, 06:13 AM | #88 (permalink) |
Thanks for your answere...
Yes, GS reveals the aircraft and displays everithing. The problem is when i search a different location where i'm. For example, If i am in Rome and i search Milan, the message is "request timeout" |
07-16-2014, 12:53 PM | #89 (permalink) |
So other than that, everything works fine?
Why are you searching for a place other than where you are? Just curious as to what you're trying to accomplish...
07-16-2014, 02:04 PM | #90 (permalink) |
Because could not be an internet connection in a place where i could go after for a trip for example so i would be able to plain a route before going there...
Excuseme for my english.. |
07-16-2014, 11:05 PM | #91 (permalink) | |
HF MR Support
If you use flight simulation mode with internet connection, are you able to access the area you wanted?
Lynh |
07-17-2014, 12:38 AM | #92 (permalink) |
I'm sorry but i don't know the flight simulation function on iPad GS.
07-17-2014, 07:15 AM | #93 (permalink) |
Ok! Now I understand. . In the GS, you can zoom out to show a larger area, move the area you want to center, then zoom into it.
I'm not sure the search function is usable yet, doesn't work on my iPad either for that purpose.
07-17-2014, 08:10 AM | #94 (permalink) |
Hi,
I turned on the radio, aircraft and GS. I zoomed out and selected a search function. In the window i wrote a location. The message was the same: "request timeout". I was in gps mode and the aircraft was visible on GS. |
07-18-2014, 10:38 AM | #95 (permalink) |
Guerinomaione I think what they are saying is at your home base with internet connection, zoom out until the area you want to go to is included in the map, then pan until it is in the center and then zoom in on the area you want to make a mission for. do this without using the search function.
hope that helps. |
10-21-2014, 04:45 PM | #96 (permalink) |
I appologize if this has been answered before. I have looked but didnt find.
Does the iPad need to be the type with cellular & wifi or or can i use an ipad with just wifi? Thanks in advance for a response. |
10-21-2014, 09:39 PM | #97 (permalink) | |
HF MR Support
Just Wi Fi is fine.
Lynh |
02-27-2015, 07:40 AM | #98 (permalink) |
Continuing POI "pain"
I too have just acquired DJI's Ground Station running on my iPad Mini and an autonomous POI flight is not smooth at all. I've emailed DJI about this several times asking them to add it as a software update (which they easily could do) but as of yet they have not.
