Ufly Walkera Ufly Helicopter Support |
03-11-2010, 07:07 AM | #1 (permalink) |
Ufly Spare Parts?
I'm getting my new Hot Rod Ufly tomorrow and would like to know from you that have one - what spare parts do you recommend having on hand (in other words, what breaks easiest)?
03-12-2010, 11:42 AM | #2 (permalink) |
So far on mine I've broke a main blade and stripped out the tail gear (they strip very easy) So far thats been it on mine.
Beating the air into submission!!!!
03-29-2010, 01:24 AM | #3 (permalink) |
Lost a flybar paddle. I had an old dragonfly that I thought would NEVER see any use and behold, the flybar paddle is the same size!! Get a spare battery or two.... Along with some spare tail gears, some folks mention to need the tail rotor shaft due to loosing or breaking the small pin that goes through the shaft. Also the c clip gets lost. But, just for me, a flybar and a broken main blade.
03-29-2010, 12:49 PM | #4 (permalink) |
The 11T brass pinion on my motor lost the set screw, I found it and when I put it back in I realized the set screw hole was striped. I have no idea how this happened, I had never messed with the main motor at all. I have the upgraded Hot Rod version from wowhobbies. Does anyone know where I can buy just the brass pinion. I can't seem to find one anywhere.
cleric |
03-29-2010, 08:48 PM | #5 (permalink) |
From another forum, they are saying these gears work on the ufly
http://cgi.ebay.com/ws/eBayISAPI.dll...T#ht_500wt_976 It is mention to use the 13T or 14T on the stock ufly. |
03-30-2010, 04:56 PM | #7 (permalink) |
Number one rule..... Always check all the screws on the heli for loctite and apply where needed.
03-30-2010, 09:21 PM | #8 (permalink) |
Re: Ufly Spare Parts?
Yeah, I've learned that the hard way!
