Old 06-17-2010, 09:47 PM   #1 (permalink)
Question "HELP" Castle BEC PRO with Phoenix Ice HV 80
Need Help.
I got the BEC PRO and need some help. Should I go with a 2s lipo on the BEC or run it connected to the HV 80 and my main power(12s lipo)?
The BEC is rated for 50V but i dont want to burn out my electronics. Also is it safe to use the HV 80 with the spectrum AR7000?
sawdogg73 is offline        Reply With Quote Quick reply to this message
Old 06-17-2010, 10:05 PM   #2 (permalink)
I would use a 3S with the BEC. I don't understand the AR7000 question???
Evan D is offline        Reply With Quote Quick reply to this message
Old 06-17-2010, 10:48 PM   #3 (permalink)
You can run either. One of the major reasons, in my opinion, for running the Rx battery is to correct the CG on a tail heavy 700.
AMA #844172 DJI S1000 Lightbridge Zen for 5D, S900 LB Zen for BMPCC, DJI Phantom 2 Vision +, P2Z2 with Data Link, P2Z3 with LB DJI Forum Support
Tahoe Ed is offline        Reply With Quote Quick reply to this message
Old 06-17-2010, 11:07 PM   #4 (permalink)
EvanD. I was asking if the Spectrum AR700 receiver can handle a 12s setup. A 3s 2200mah 25c is what i will try first and see how teh CG is. Thanks
Old 06-18-2010, 01:16 AM   #5 (permalink)
im going to go strait from the 12s to the bec pro and get rid of the 2s rec pack all together, once I get my new kde receiver mount in the mail. any thing to get this beast under 11 pounds.. just got the KDE bearing blocks in and they work great.. My stock bearings were getting notchy after only 8 flights...
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 01:34 AM   #6 (permalink)
I'm going to run through 4 common electronics setups for you quick:
- 8v Cyclics with receiver pack -
50v main pack to ESC
8v 2s receiver pack to AR7100
unregulated outputs (8v) from receiver to cyclic
7100 regulated (5.2v) outputs to tail/gyro
- 8v Cyclics without receiver pack -
50v main pack to ESC and BEC
BEC adjusted to 8v to AR7100
- 6v Cyclics with receiver pack -
8v 2s receiver pack to Align 6v regulator
6v to receiver
6v outputs from receiver to cyclic
either 7100's 5.2v reg output to tail/gyro or stepdown from unregulated rec to tail/gyro
- 6v Cyclics without receiver pack -
50v main pack to ESC and ICE, CC Pro or WR BEC
BEC to receiver
See there are so many ways you can hook stuff up... To answer your question though,
No receiver takes 50 volts input. They take up to 8. How you get that voltage to them is up to you, either by using a 2s pack, a 6v regulator or an adjustable BEC. It all depends on how you want to run things and what you're willing to pay for.
On my T-Rex 600 ESP, I have the following configuration:
50v main pack to CC 110HV ESC
8.4v receiver pack to Align 6v regulator
Align 6v regulator to AR7100
AR7100 unregulated (6v) out to BLS451 cyclics
AR7100 regulated (5.2v) out to Spartan/BLS251 tail
This works great for me. I get perfect CG with the pack placement. The receiver pack runs 6-7 flights safely without needing a recharge and the 6v regulator has a nice little power switch on it as well as lights to show how much pack is left. If I needed 8v cyclics, I'd just eliminate the align 6v regulator, plug straight into the 7100 and use the power switch on it.
Just remember that if you use a 7000 or other receiver that does not have a 5.2v output on it and you need to run 8v cyclics with a 5.2v tail, you will actually need something like 4 voltage drop diodes in series to bring the voltage down enough. I believe each one drops the voltage .7 volts, so 3 would drop it 2.1 volts and 4 would drop is 2.8 volts. I've never seen anyone do that, though. Everyone I know with a 5.2v tail either runs 6v cyclics & 1 step down circuit or has a 7100.
I hope this was helpful!
T-Rex 450SE v2.5, 450M, HS65s, GY401/9650, Radix 325s
T-Rex 500 ESP - DX7/AR6200, DS510s, GP750/DS520, 500M, Align ESC/BEC, Align 425s, 6s 2650, 13T
T-Rex 600 ESP 12S - DX7/AR7100, BLS451s, Sprt DS760/BLS251, Scorp 4025-630, 14T, CC110HV, Align 600Ds
rbgrn is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 08:11 AM   #7 (permalink)
RBGRN,
WOW! You have a 12s 600 ESP. Was it hard to upgrade it. I have a 600 esp with the 650L motor,100a ESC and 6a BEC. I'm still new the the game but have all helis from 250 up to 600. This will be my first 12s(700e 3g) but felt the 600esp was a little under power. I didn't know you could run 12s on the 600. I was going to put a 8s bat on the stock motor but didnt know if it could handle it. I'm sure I could find some info about it.
Thanks for everyone sharing there setups and help. This is only my secound time using theis website and i should of used it more before and i would have saved about $2k in repairs and upgrades.
Old 06-18-2010, 08:21 AM   #8 (permalink)
RGGRN,
Is it ok to run 6v to a DS650? I have the same thing setup on my 600esp with the DS620 with no problems. Looks like a lot of people are runing 5.2v to the tail. Does 6v shorten the life of the tail servo?
Sorry if this sounds like a dum question.
Old 06-18-2010, 11:48 AM   #9 (permalink)
it's not dumb...I asked the same question before. Heard that you need a stepdown on the 650, but it's not true. it's rated for 6v so no stepdown needed.
Former owner of T-Rex: 250, 450 V2, 500ESP V-Bar, 550 DFC 3GX, 600ESP V-Bar, 700E 3G
Shef is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 11:49 AM   #10 (permalink)
and by the way, go to the 600 forum and you'll see a sticky about making a 600 12S. I did the same thing and it was just awesome! But I sold it last week and went for the big boy.
Old 06-18-2010, 12:08 PM   #11 (permalink)
There are plenty of tail servos now that can run 6v. It all depends on the specific model. If you want to get 6v to the tail, you can't use an AR7100 because it only has one rudder output and it is regulated to 5.2v.
Old 06-18-2010, 09:38 PM   #12 (permalink)
I am running a DS650 at 6V without any issues.
doug
TRM Power - RC Racing Engines - - Blackout Mods Conversions - - VP Racing / Powermaster Fuels - - Gas-Powered-Helicopters.com
Doug Darby is offline        Reply With Quote Quick reply to this message
Old 06-18-2010, 11:57 PM   #13 (permalink)
Same here.
Old 06-19-2010, 06:04 AM   #14 (permalink)
me too
