Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 03-13-2013, 02:12 PM   #1 (permalink)
Default Still having Governer issues. (solved)
This is copy/pasted from the JR section which so far was of no help.
So I've been messing with the governor on my NX4 for a while now its the Gaui gov. Can't seem to get it working the way I want.
Current settings are as follows:
Governor is plugged into Aux 3 on the Ar7200bx
In Device Select Aux 3 -> FMOD -> GOV
Under Governor, Norm = -70% , ST1/2= -110%
The problem is with the governor turning off, or I should say NOT turning off. The manual states that under 30% throttle the gov should technically shut off.
My normal mode throttle curve is 0-25-50-100, yet no matter what I try the gov. stays on (LED glowing green) from 0% throttle all the way up to 100%.
The only way to have the gov. to turn off is to go back into the governor settings and set it manually to 0 gain.
- Trex 700 V2 /AR7200BX - Gaui X3 - 3x MCPX BL -
AR90 is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 09:40 PM   #2 (permalink)
What radio is that? If 9503 check out the link.
https://www.helifreak.com/showthread.php?t=504419
tauseef
www.cuttingedgecnc.com
tauscnc is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 09:44 PM   #3 (permalink)
tauseef
its a 11x, saw that thread above before. Couldn't find an answer.
Am I right to think that the LED should go red when under 30% throttle? Or does it just keep glowing green and the governor just doesn't engage until 30%?
Old 03-13-2013, 10:11 PM   #4 (permalink)
Sent u a pm to call and see if we can get this figured out.
tauseef
Old 03-13-2013, 10:15 PM   #5 (permalink)
I don't have an 11x but looking at the manual it says GOV can be on gear, aux1 or 2. Are you sure it can be on aux 3?
tauseef
Old 03-13-2013, 10:19 PM   #6 (permalink)
Just checked my Align which I believe is just like your Gaui.
At full low stick Led is Green. No change from flight mode switch... Always Green, Always on.
Only time it goes Off is when it reads the magnet.
Mine never goes red.
tauseef
Old 03-13-2013, 10:23 PM   #7 (permalink)
tauseef
Ah, makes sense. Im guessing it just stays green and doesn't engage until 30% throttle.
I'll give it a careful test flight tomorrow and see if everything is working as it should.. If its not, I'll take you up on that phone call
Also, I do believe Aux 3 should work. As I'm sure you can tell, in the 11x menu's it allows me to set Gear through Aux 3 as Gov.
Thanks, I'll update tomorrow. Hopefully with good news
Old 03-13-2013, 10:26 PM   #8 (permalink)
Sounds good. Good luck and be safe.
tauseef
Old 03-14-2013, 06:40 PM   #9 (permalink)
So I got to fly a couple of tanks today, just came back from the field. Seems like the governor is working perfectly
Light does stay green, however it doesn't engage until 30% throttle.
Now I just have to tune the Beastx, thanks for your help Taus, appreciate you taking your time to look into this.
Old 03-14-2013, 08:22 PM   #10 (permalink)
Awesome news! And no prob on the help.
tauseef
