Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 07-29-2013, 05:36 AM   #181 (permalink)
Default Re: Warp 360 6s Battery choice:(sticky plz)
im happy with 1300 mah 3minutes of insanity.
Sent from my Compass7HV while in an inverted tail-in hurricane.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 07-29-2013, 10:27 PM   #182 (permalink)
I don't how I am missing this but where can buy these new 160mah packs?
California Cabernet & Cuban Cigars
Warp 360 | HC-3SX | JIVE 80+ | HK 2520-1360 | MKS DS92A+/95i | Radix | DX8 | PL6 | GP 6S 1500
Mr-Mike is offline        Reply With Quote Quick reply to this message
Old 07-29-2013, 11:57 PM   #183 (permalink)
hobbypartz.com
Old 07-30-2013, 06:42 PM   #184 (permalink)
Thanks crf69!
Old 09-05-2013, 11:45 PM   #185 (permalink)
Hey guys,
I found the perfect 6S pack for perfect CoG and flight time:
Turnigy 1800mAh 6S 40C Lipo Pack
If you put it all the way to the main shaft the CoG is perfect.
I also bought lighter 1300mAh packs... I really don't get how you maintain a good CoG with such packs. Even when I put them as to the front as possible (half of an inch contact surface with the chassis) the Warp is still tail heavy
Soko
PS: As I'm quite confi with 2750 rpm I will try this 2200mAh 5S packs next. They should give the same perfect CoG and a little bit more flight time as well.
The future of setup... now! Soko Heli Toolbox app for a next generation setup experience.
ONE tool for ALL setups of ALL sizes and ALL brands of helis
www.soko-heli-tools.com
soko is offline        Reply With Quote Quick reply to this message
Old 09-06-2013, 07:03 AM   #186 (permalink)
For the equivalent price/weight I would think you would be better off with pair a 3S packs in the 1000mAh range and a serial connector. You keep the 6S power. They will fit in the canopy.
Old 09-06-2013, 02:00 PM   #187 (permalink)
Default Warp 360 6s Battery choice:(sticky plz)
Actually I allready have a pair of 1550mAh 3S for my foamy which I want to use for the warp as well
Old 09-06-2013, 05:18 PM   #188 (permalink)
That's too much weight, unless you have 'something' else in mind... Stretching it?
Old 09-06-2013, 06:34 PM   #189 (permalink)
The contrary...
Two of those are 272g.
The perfect CoG LiPo has 309g.
So I reckon I have to put them a little bit to the front (leave a ~5mm gap).
And all this is on a plain and stock Warp 360 with all electronics mounted in the front (except the motor of course).
Soko
Old 09-07-2013, 12:01 PM   #190 (permalink)
Of course, that's true. Sorry, was mixing up the cell count
Old 09-08-2013, 07:53 AM   #191 (permalink)
Default Punch Platinum 6s 1300 35C
Bought 4 @ beginning of this season.
Each has 35-40 cycles and I get 5 minutes with good power.
Cullen Warp 9 7 2013 (4 min 54 sec)
Cullen Colapietro is offline        Reply With Quote Quick reply to this message
Old 10-01-2013, 01:34 PM   #192 (permalink)
Will this fit and leave enough room to adjust COG?
105mm x width 33mm x thickness 35mm
276gr
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 10-01-2013, 02:06 PM   #193 (permalink)
My perfect CoG Lipos are 113x34x39mm@309g
So if you use the wide canopy mount (have to drill 2 new holes in the canopy) you can ajust CoG position
Old 10-01-2013, 04:38 PM   #194 (permalink)
Drill new holes?
Old 10-01-2013, 05:29 PM   #195 (permalink)
yeah.
have a look in the manual. in one section it says something like "if you want to use bigger lipos you may want to put the canopy more to the front. to do so you need to drill new holes"
dont use the domenison they give in there though.
I think i used 20mm
Old 10-07-2013, 12:36 PM   #196 (permalink)
I have a new 6s 1300 65c battery you guys might be interested in. The dimensions are 48x38x70 wt. 210g
This more square format makes it easier to get the weight more forward while still being light. The price is 44.99 each. I would be glad to donate one to the hardest 3d guy here for testing.
Mark
MarkF is offline        Reply With Quote Quick reply to this message
Old 10-11-2013, 08:33 PM   #197 (permalink)
Ya ill take one if your offering
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 10-13-2013, 10:44 AM   #198 (permalink)
276gr
I dont understand. Weight is identical to the gens ace designed for the warp, so is the dimention. It should be fine?
Old 10-13-2013, 01:45 PM   #199 (permalink)
I never tried the gens ace. All I know for sure is that the LiPo I posted above fits perfectly on my Warp "super combo"
Which doesn't mean that yours wont bdw...
Old 10-13-2013, 02:27 PM   #200 (permalink)
210gr and good cg? Sounds to good go be tru?
