Belt CP E-Sky Belt CP |
05-12-2014, 10:28 PM | #1 (permalink) |
Cat and mouse games! Tom& Jerry HELP!
So the phantom2 does things bass akwards 5.8g radio 2.4g fpv I think I can get my Devo 10 working with it now I want to buy this.
http://www.hobbyking.com/hobbyking/s...Backlight.html and this. http://www.hobbyking.com/hobbyking/s...le_600mw_.html Do I need an OSD unit? and what does an OSD do? on screen display I get but...
-Heli Yea! Master of: the living room, mechanical setup and, the obvious! Belt'ish CP FBL, HDX 500 DFC, New V120D02S FBL, Mini CP FBL, Hirobo Shuttle ZX, 450L w/VX1e, QR-X350PRO FPV, 450L w/APM FPV(in progress) DEVO 10 white w/2km range! |
05-12-2014, 10:35 PM | #2 (permalink) |
Oh yeah, is that going to cover my video for 2km? and Do I need clover/mushroom antennas?
The jumper cables for my RX1002 are coming with the new heli like wednesday! and charger so Ill be able to hook up power after that.
05-12-2014, 10:44 PM | #3 (permalink) |
yeah, uh, I dunno???
Looks like the DJI multirotor forum is helpless. Seems like not a soul has veered away from the stock TX lame. They cant answer a general question from the manual about how to hook a standard RX. I am left to fend for myself and doing just fine.
05-13-2014, 03:25 AM | #4 (permalink) |
For one thing, the receiver frequencies do not match with the transmitter frequencies. Don't mess around with HK. There are a few places in the USA that deal with quality gear. http://www.readymaderc.com/store/ind...roducts_id=877 http://www.readymaderc.com/store/ind...roducts_id=266 http://www.readymaderc.com/store/ind...Path=11_22_228 Later, if you want, or instead of the monitor, this will hook up to any Fatshark goggle. I really like my 12" monitor and would really recommend nothing less. Now is the time to consider your investment. When you add the cost of the monitor and transmitter together, it's significantly less than a goggle, but goggles are a hell of a lot more enjoyable, and are a investment. Decide now how best to spend your money. An osd overlays telemetry back to you on your display. You do not need one to fly, I flew 2 years without. The advantage is you know what your battery power is, how to get back home, how far and high you are, a ton of information you can overlay. It can be as simple or as complicated as you want. There are a lot of manufacturers, but few are easy to set up, and even fewer that are reliable. Again, quality components is the key to happiness! Other companies I deal with are; http://hobbywireless.com/ http://www.dpcav.com/xcart/home.php As far as good forums to visit for help, I won't list their site here as a show of respect, but multirotor forums and fpvlab are great with none of the drama of rcgroups. Run your fpv off a separate 12v lipo, not the main battery. 850mah's will fly you for hours and hours. Yes, you want cloverleaf antenna's. Don't mess around with trying to save money, get IBCrazy antenna set. You will need sma adapters, probably, but don't buy them now, wait until you get your gear and see what you need. True, you won't be able to power it up right away, ( antenna's MUST be connected on both before power is applied or it's toast ). Mounting your gear, separation is the key. Very difficult to do with a multi, so I go for isolation. What I mean, cf is a deflector, so I like to install cf plate about twice the size of the receiver and mount it to deflect radiation form the tx to the rest of the system. You can buy cf tape, works a charm. That's enough for now. It's a hell of a learning curve.
Avant Aurora 90n,Trex 600E Pro, HC500, HDX450sev4, Trex 250se, mCP-X, Mosquito, X/A Hexa/WKM/UHF/FPV, F330 Flame Wheel, PenguinV2/UHF/FPV, 757-3 ex Ranger/uhf/Ruby/fpv, QAV250 w/Vector , Ritewing Drak w/Vector Crossfire and fpv. |
05-13-2014, 10:26 AM | #5 (permalink) |
It's a learning mountain. Thanks a bunch. I will look into stuff tonight after work. I just had a hunch you would know shit ton on the subject. thanks!
05-13-2014, 10:43 AM | #6 (permalink) |
The old man has spoken, and (surprisingly) he has spoken wisely, meaning he was quite sober while writing
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
05-13-2014, 11:18 AM | #7 (permalink) | |
You know me so well!
05-13-2014, 12:02 PM | #8 (permalink) |
SWEET!
Thanks Jerry! I was looking at the DJI iOSD mini manual I have but I was not sure of compatability Since they use a 2.4g data TX/RX in the manual.
Are you getting the iOSD Mini or Mark 2? The mini is like 70 bucks so might as well add that to the list. What do you guys think of the dragon sky plug and play goggles Ehirobo has for about $100?
05-13-2014, 12:36 PM | #9 (permalink) |
Chad, I got both MK2 and Mini, the idea being to use MK2 on the hexa to switch between fpv camera and gopro on the fly. Mini goes on the yet-unbuilt quad which will be fpv only, no recording. On Phantom you'll have to feed gopro signal into vTx (no room for a separate fpv camera) so mini is sufficient. You'll have to check if your Naza-M on the Phantom is v2; if not, you'll also need a v2 BEC and LED unit to make it into v2 to be able to use DJI OSD units. AFAIK the signal compatibility is a non-issue, you should be able to connect iOSD to any vTx (regardless of vTx-vRx link type or frequency), will confirm in a couple of weeks when doing the conversion.
05-13-2014, 03:28 PM | #10 (permalink) |
Yeah I have the Naza PT2 MC same as Naza M V2. The diference is all the components are on a main board like bec, gimbal control, ESCs. The RX and GPS are seprate but are also in board form and no outer plastic shells. The MCs are identical minus the names on the sticker. I have been researching a lot over the snow days.
05-13-2014, 03:39 PM | #11 (permalink) |
Oh yeah, it is osd ready for sure. it has the CAN BUS and power/vid wires hooked to the BEC/MC/main board ready to hook-up to OSD.
05-13-2014, 05:58 PM | #12 (permalink) |
They're crap.
05-13-2014, 06:02 PM | #13 (permalink) |
Still speaking wisely, I see.
Well, it's time go out with friends and tip a couple of brewskies myself, we can't all stay sober at the same time, can we now?
05-13-2014, 07:23 PM | #14 (permalink) |
Crap it is then!
05-13-2014, 07:36 PM | #15 (permalink) |
Have fun Jerry. Ya know the difference between wise/drunk Tom? Drunk Tom gives good advise but would get me $$et up w/way too much $$tuff and invite me down to Erie for a few cold ones. :rofl
05-13-2014, 08:23 PM | #16 (permalink) | |
I know! It sucks! Heading out to my local pub and toss a few 90 shillings, Sober feels too much like work, not to mention too much work!
05-13-2014, 08:49 PM | #17 (permalink) |
Drunk Tom will set you back a few thou, Chad, been there done that. Only had two light beers so I'm not to drunk to drive back home (Mrs. P. has just called), even if it might be over the limit for flying.
05-13-2014, 11:49 PM | #18 (permalink) |
Yeah Tom I really like the VTX/VRX in the links above! SOLD!
Still debating monitors 8", 10", or 12" What goes best in a back pack?
05-14-2014, 12:02 AM | #19 (permalink) |
Here's a look inside.
05-14-2014, 10:20 AM | #20 (permalink) |
Afraid you'll be best off deciding this one on your own, Chad, lest you wind up lugging an 80" screen on your back
