Vario Vario Helicopters |
01-03-2009, 11:30 AM | #1 (permalink) |
Radio location in a Bell 47 G II
What is everybody doing with there radio gear in the Vario copters. My Bell 47 is allmost ready to go but I am concerned about the radio gear so close to the spark plug and wire.Not a problem in my Vario 206 with the large fuse.But with the 47 there is no where else to put it.Also 2.4 or pcm?
Thanx Terry. |
01-04-2009, 01:14 PM | #2 (permalink) |
Locate your gear under the cockpit floor. That's what I saw done with a most of the 47 G's at the NATS last year. I have my gear under to floor on my Huey not too far from the front of the motor. 2 years in and no problems.
Christopher J SMI R & D Pilot RCXcel "Size it up, then scale it down" |
01-05-2009, 09:02 AM | #3 (permalink) |
Bell 47
Thanx for the reply Chris.It just goes against all the things I learned about gas engines and radio system installations.I will check it out.
Thanx. Terry
Terry. Bergen Intrepid/Bergen Intepid EB/Vario Bell 206 Jet Ranger/T-Rex 450 Pro FBL Robird G31 6S /T-Rex 250 DFC ZYXS/Gaui X5 BeastX V3/ Warp 360 TracX/Nano cpx/Gaui X3 Ikon |
01-05-2009, 08:17 PM | #4 (permalink) |
If u run a shielded/supressed plug cap you should have no problems
You also might want to ask this same question on www.scalerchelis.com in the Main Discussion section.
