Old 04-12-2012, 06:17 PM   #21 (permalink)
Originally Posted by gmcallister View Post
=] lets go from here, we now have a datum to work from. load the latest rev 3.10 to get the best out of the SK......
I updated last night. Will test it tomorrow with the new settings and let you know the results.
- Goblin 700, Sk540, ICE2 HV160, Quantum 4530-500, MKS Tail, Outrage Torq Cyclics
- Kasama Srimok Faifa 90e, VBar 5.3 Pro, ICE2 HV120, Scorpion 4035-500kv
- Gaui X5, mini vbar
- Trex 250 se
Bruno28 is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 06:50 PM   #22 (permalink)
Originally Posted by Jamesppp View Post
On the tail screen shot it shows left at 73 and right at 96. Or somewhere close to that.
A centered tail should probably be a bit closer to equal travel
100/100 would be sweet( I can't get it on mine though)
I actually aligned the servo horn at 90 degrees, then did the trim. So what can be wrong for me to get those values and not 100/100?
- Trex 250 se
Old 04-12-2012, 07:45 PM   #23 (permalink)
When you 90'ed the servo horn did you follow up by mechanically setting the tail rotor to 0 degrees without moving the servo horn?
And prior to doing any of this the transmitter endpoints should be 100/100 on the rudder
Compass7HV,Sk720HeliJive120HV Pyro 700 52L allHV
Outrage 550: Scorpion 4020-1390,CC125A ESC,WR ESC
Logo 5003D Scorpion Sk720 4020-1100, Blade130X MCPX
TT E-620 SE x 2: Scorpion 4025-740 200srx, nano qx JR Parkmites x 2
Jamesppp is offline        Reply With Quote Quick reply to this message
Old 04-12-2012, 07:54 PM   #24 (permalink)
Yes, so what i did was, set the servo to 90 degrees. Then adjust the linkages so that the tail blades are at 0 degrees. Then i used the sk720 to do the centering, left and right limits.
Im not sure about the TX, but i think it is at 100/100 for rudder, will have to double check this.
Can it be that the servo horn is not exact with the servos natural mid center?
- Trex 250 se
Old 04-12-2012, 08:27 PM   #25 (permalink)
It is possible that the horn isn't centered on the splines but you would probably see that
If you move your ball closer to the shaft you will at least get higher numbers left and right which will give you more resolution
I think my Logo tail is supposed to have a few degrees of pitch at center stick to counter act the torque so with the blades centered there is much more travel right than there is left(head rt and head left). I'm on the same boat you are
Old 04-13-2012, 12:50 AM   #26 (permalink)
So should i move the ball link to the closest hole in the servo horn? What advantage do i get beside the 100/100?
- Trex 250 se
Old 04-14-2012, 02:33 AM   #27 (permalink)
DUDE! I followed your instructions, and man it WORKED PERFECTLY!!!
Never seen the tail so solid!!! Its perfect solid for both left and right!!!
When giving full throttle it is fine, but if you have negative pitch and then give it fullthe tail just moves a tinny bit, its ok with me.
I just kept my old trim settings just so that the tail servo is not put on too much pressure of exceeding the rudder limit. 100/100 is very hard to get, and if i keep like that i think it will ruin the servo.
But now its what we expect with the SK720, love it.
Thanks a lot gmcallister, you were great help!
- Trex 250 se
Old 04-14-2012, 03:50 AM   #28 (permalink)
Glad you guys have it sorted
The SK tail really is a brick wall.
Cascade is offline        Reply With Quote Quick reply to this message
Old 04-14-2012, 04:08 AM   #29 (permalink)
I was surprised! It feels like there is a invisible wire that holds the tail in place.
Very happy now.
- Trex 250 se
Old 04-14-2012, 04:15 AM   #30 (permalink)
Wait until you get the governor in and working, it's truly amazing
Running a 600 on 12S with 2400RPM, short clip but the SK gov really shows how well it almost predicts what's going to happen.
We can't bog this thing.
[ame]http://www.youtube.com/watch?v=UZrbq9TINBs[/ame]
Old 04-14-2012, 04:18 AM   #31 (permalink)
I currently use the CC Esc governor.
Should I set up the sk720 instead?
- Trex 250 se
Old 04-14-2012, 04:30 AM   #32 (permalink)
Nah, not on the CC, I'd fly it for a while as it is if you're happy with it, sounds like you've hit on a good setup already
When you get the itch, pick up a HW ESC and you'll be golden.
Old 04-14-2012, 04:32 AM   #33 (permalink)
What's the advantage of the hw esc? And should I just get the 100amp one?
- Trex 250 se
Old 04-14-2012, 04:44 AM   #34 (permalink)
It works without problems on the SK gov, the CC doesn't like to play nicely.
If you're running 6S you should look at your power draw in the CC logs to see how many amps you're pulling.
With an 8S setup you'll be running higher voltage but less amp draw, usually results in cooler electronics, more grunt etc so if you can run a HV setup on the HW 70A HV you'll have a lot of headroom to go bigger if you need to
