Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 12-31-2013, 01:19 AM   #41 (permalink)
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 01-01-2014, 06:04 PM   #42 (permalink)
Well the new year started off well.
The basic and cyclic setups are done!
This is the most accurate setup. Positive and negative pitch was dead equal and zero pitch was perfect!
The wiring is definitely a challenge and will likely be pretty fugly!
New pic
Jeti DS-16, Oxy 3, Goblin 380, 500, 630, and 700 competition, Airwolf 600 scale heli, Brain/Ikon 2, Spartan VX1e, Sk 720, YGE and Hobbywing.
Shogun71 is offline        Reply With Quote Quick reply to this message
Old 01-02-2014, 05:49 AM   #43 (permalink)
Nice!!
Yes this heli is a bit challenging regarding to wiring, but a extra clean wiring is possible if you wish.
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 01-02-2014, 06:56 AM   #44 (permalink)
I've routed servo wires below electronics tray, and my SK servo plugs side is at the front. The length of servo wires was just enough to do that. Still need to shorten that satellite wire. You'll need to find a special USB cable with 90degree angle connector to access SK usb port.
Goblin 700 Sport [spirit pro, hw130, xnova4525, bk kst servos, switch, gensace12s]
Warp 360 [SK540, yge v4 and other antique electronics, radix/edge blades]
uiron is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 01:42 PM   #45 (permalink)
Well, I finally got a chance to finish up the build.
I have ordered a 90 degree usb cable and will flip the controller the opposite way.
Cog is really close.
A spool up and tiny hover had me worried as this heli was so quiet....
If the stars align the first flight will be done tonight at our indoor flying session!
Fugly wiring pics....
Old 01-11-2014, 02:26 PM   #46 (permalink)
I'm pretty sure the electric waves in your setup will get confused with that wiring style
Forgive my joke
This heli is a bit trickier to wire, that's for sure. Be creative is the best tip i can give you.
some opened a hole in the electronic tray to pass the cables from underneath, i preferred to totally cut the tray end (the one with those pass through holes), and it's just enough for the cables pass underneath all the tray and enter the gyro, plugs to the front.
It will keep you busy on the next rainy/snowing day
T500 AP
Old 01-11-2014, 05:52 PM   #47 (permalink)
Just got mine in the mail today and i already started building Any tips of advice or anything i should be cautious about? Thanks
DX7S~
Blade 130x
Align 450 Pro DFC- Beastx
mguido6 is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 07:44 PM   #48 (permalink)
Check out the build thread at the top.
I have touched on a few things through my thread. Take your time and enjoy.
Old 01-11-2014, 08:30 PM   #49 (permalink)
Wish I could have made it this evening to help you ... the heli-gods were definitely not on my side this evening ... worse yet, I suspect my wife through out my Bluetooth adapter for the Compass TracX that I had bought.
I've just ordered a new one, but I won't see it for at least a few weeks.
Good luck, buddy ...
Jeff_Barrett is offline        Reply With Quote Quick reply to this message
Old 01-11-2014, 11:09 PM   #50 (permalink)
Oh, my freaking goodness!
This heli is going to get a lot of light time!
Flawless maiden!
I only had to adjust the front servo to swash linkages by one turn each to get a perfect hover.
I actually had to drop the tail gain just a bit.
By the end of the second battery I was yearning for some open air and let it open up a little... Kinda hard to do flips and such indoors...
This is an epic model!
Old 01-29-2014, 12:30 PM   #51 (permalink)
After a long wait from China my 90 degree USB cables finally arrived.
I moved the sk540 180 degrees and squeezed the cables for the throttle and aux power under the esc tray and tiedied up the wires quite a bit.
I reprogrammed the controller for the new orientation and everything checks out!
A little more wire tidying and I will post some pic's of the heli.
It all looks and fits good now.
Now if only the temperature would get above -10c and I can consider some outdoor flying. I am hoping by July that we will be warm enough to get outside.
Old 01-29-2014, 12:46 PM   #52 (permalink)
Marc and I will be at the dome on Friday with our Warp and X3. You should come.
Sent from my SGH-I747M using Tapatalk
Old 01-31-2014, 04:34 PM   #53 (permalink)
Well for what it is worth everything is done!
I got all the wires re routed and cleaned up a little more and the tail grounded. I show electrical continuity from any bolt on the grame to the bolts holding the side plates on the tail.
Good enough for me!
Final pics...
Old 04-20-2014, 08:09 PM   #54 (permalink)
Big update!
The first nice day outside in 6 months and the warp got to stretch its legs in open air.
AWESOME MACHINE!!!!!!!!!
Wow, put my Atom 500 to shame.
It felt so good I even tried hovering inverted!
