Engines and Mufflers Having problems or need advice on Engines or Mufflers? |
05-27-2011, 07:59 PM | #62 (permalink) | |
By the same token you won't catch me "going off the deep end", running around accusing people of not being safe or not caring about other people if they haven't put a spring on their nitro heli. (I'm not implying anyone has done that, by the way.) This really does come down to personal preference and whether you want to feel like every available precaution has been taken.
T-Rex 700N, 600NP, 450v2 w/Pro head, 250SE - Blade mCP-X, mCX, mSR x 2, Parkzone F4U Corsair: All on DX7se |
05-27-2011, 08:01 PM | #63 (permalink) |
The only issue I could see with that is it isn't fool-proof against a very talented fool, meaning that it doesn't protect someone from accidentally having the throttle wide-open when attempting to start. On my last nitro, I used a Switchglo in combination with programmable mixes so that the Switchglo would only trigger if I was in TH.
Alan (just call me "Bum"; no need to be so formal) HeliFreak Support Protos Max Evo 700 (Brain 2), Protos Max V2 770 (iKON 2), Synergy 516 (Brain 2), Oxy 2 (Falcon 12) Graupner MZ-32 Experience is something you gain only after you need it. I wouldn't mind social media so much if it didn't involve people. |
05-27-2011, 08:04 PM | #64 (permalink) | |
It will not light the glow plug if the throttle is anywhere other than idle position. Idle up=no glow. Throttle stick even slightly above zero=no glow It is absolutely fool proof in the hot start area |
05-27-2011, 08:17 PM | #65 (permalink) |
Ah, OK. The way you described it, it sounded like the throttle position didn't matter. It's not something you couldn't do with mixes, but it does sound simpler.
05-27-2011, 08:34 PM | #66 (permalink) | |
I'm not going to do the experiment, because I already know the answer. You'd be surprised at the readings you'll get with and without a spring using this device. I have one and will not set up an airplane or jet without it... helis don't matter in this case, it's for multiple servo set-ups on a single control surface. Check this... I will mail you the meter so you can do your own tests. When your done, mail it back to me and post the vid here on HF. Deal? ... Yes, I'm serious. http://dreamworksrc.com/catalog/prod...roducts_id=881
AMA/CD# 365566 AOPA# 5081747 AMA Turbine # 15130 ... Intercepting the Localizer... Guidance by Futaba 14MZ Heli 2.4 GHz ......FUTABA-- Always Imitated, Never Duplicated |
05-27-2011, 08:47 PM | #67 (permalink) | |
It's simple Physics people. Not redesigning the Space Shuttle. Small, gentle force. Not some super strong spring |
05-27-2011, 08:48 PM | #68 (permalink) |
McKracken,
You may not realize this, large tail servo amp draws are at short spikes of high amps, your throttle will be at a continuous high amp draw. I'm not saying this is a failure waiting to happen, just sayin' it's something I don't want my power system to deal with.
05-27-2011, 08:51 PM | #69 (permalink) | |
Well there ya go.
05-27-2011, 08:56 PM | #70 (permalink) | |
05-27-2011, 09:01 PM | #71 (permalink) |
HOw about quoting my WHOLE post, not just a part to make it sound how you want it.
Yes, it will draw a teeeny bit more. So does adding any other electronics. if your that worried about power draw that the miniscule draw from a return spring would have, maybe you should get a bigger RX pack huh?? I'm talking 1/20th of a watt, if even that much |
05-27-2011, 09:09 PM | #72 (permalink) | |
Tail blades are never neutral.There is always a tremendous amount of torque on them. Just like Playfair said...He uses a throttle return spring on all his helis and when his tail servos get older he retires them to the throttle position.Hmmm.... He also designs,builds and sell heli specific electronic components. I have some of his work on my Trex 700 as a matter of fact |
05-27-2011, 09:25 PM | #73 (permalink) |
A. Higher draw is what is it is... Drawing more amps as little at that may be (if anyone cares to actually measure this instead of speculating, but mileage will obviously vary depending on servos and springs used) Fact is YES it will draw more. Maybe even enough that some day a person will receive a low voltage cutoff or brownout in an unrecoverable situation because of it. Yup that's certainly a possibility. People already complain enough of brownouts in their systems without the extra draw from a throttle servo added into the mix. Don't forget there's 4 other servos banging and stalling every which way. They don't need a throttle servo taking some of their juice away. Whatever BEC someone may be using may not be able to handle it in all situations.
B. When and if a brownout ever does occur (for any reason at all) the pilot may not necessarily want their engine to immediately cut power. Receivers can quickly recover from brownouts. If the engine is cut it could potentially make an already bad situation much worse. That's two possible real world situations where this mod could cause someone to crash their heli (maybe even into a crowd of people) So why introduce potential problems to your system just for some false sense of security to prevent the dreaded chicken dance? There are far worse things to go wrong that can do much more damage to helis and people. The more failsafes you put in a system the higher the probability you're setting yourself up for something to fail. I.E. failsafes are just extra points of failure. Keep things simple, use common sense, use preflight checks, test your equipment, and play safe. Those are the best safeguards you're going to get. Period. |
05-27-2011, 09:43 PM | #74 (permalink) | ||
God forbid you ever have 90 sized heli in idle-up go out of control into a crowd of people. You'd likely feel very differently about making such a definitive statement then. This might be a one in a million or one in a billion scenario we're talking about here, but we're also talking about potential loss of life.
05-27-2011, 09:51 PM | #75 (permalink) | ||
05-27-2011, 09:52 PM | #76 (permalink) | |
Are you done yet?? LMAO
05-27-2011, 09:58 PM | #77 (permalink) | |
05-27-2011, 10:04 PM | #78 (permalink) |
Yes I am because oviously you have your head so far up your #$$ that you can see your tonsils. I know what works, I know what it draws and that there is no servo damaging current draining conditions that will occur. So ya Think whatver the F u wana think, I am done trying to talk common sense because it appears you have none.
And if I upset someone with my post, Tough. Suck it up Princess. Some people just keep pushing and preaching on something they have never used or experienced and think they are the end all know all on the subject when in fact they don;t have a clue of what they are talking about. I have stated before, I have been running throttle return springs for 16+ years. And one of my Nitro's has had same throttle servo on it of over 6 of those years. I have never burned a servo out or caused damage in any way because of the springs. I don't know how much more proof or information you need?? |
05-27-2011, 10:08 PM | #79 (permalink) |
Good grief!
Let's keep this civil!! Raza and I are managing a healthy back and forth without slinging any mud...
05-27-2011, 10:14 PM | #80 (permalink) | |
The one in a billion is where the heli may just be gently sawing it's way into a crowd of people not really on an initial crash trajectory with the ground. Definitely not something I ever want to see ever. It's just my best guess here, but the odds of that happening are much lower than the odds of doing the mod causing a different kind of failure. This is why I generally try to stay away from too many mods. That may just be coming from lessons I've learned from dealing with computers over the years. The less I've "tinkered" with them the better and more reliable they've worked. So far that's also been the case with helis. I just tend to stay away from things that can add a new point of failure. I'm not saying this mod is bad in any way. Just something I wouldn't do personally. If it's something that feels good for you that's awesome go for it. I'll even help you install it I'm just putting into words why I personally wouldn't. Cheers |
