Go Back   HeliFreak > R/C Helicopter Support > Hirobo Nitro Helicopters > Hirobo Electric Helicopters
Hirobo Electric Helicopters Hirobo Lepton EX, Quark and other Electric Helicopters
Old 12-08-2006, 10:47 PM   #1 (permalink)
Team Taco VP
Default Perfect pinion for 4S 3025-10
OK guys, I got some pinions to test and all I got to say is SWEET!
So you all know with the Hirobo 24T the 3025-10 gave too high a head speed at 100% throttle. Most of us were runnign 85% throttle. Well I am going to tell you WHAT A DIFFERENCE 1 tooth makes!
We tested a 23T and 22T pinion today on 4S with the 3025-10 mtotor. The 23T pinion and 100% throttle FLAT gave 3010 head speed... WOW is all i can say... Motor temps were NOTHING and ESC was ambient (this was a CC ESC). A 22T gave 2800 head speed and again motor temps were NOTHING and ESC was very happy. Those wanting a lower head speed in the 28's will want a 22T pinion!
In my opinion, 23T is the SWEET spot for the 3025-10 motor.
More testing to come with other motors and also 5S. We should be able to get the 3025-12 on 5S and find the right pinion this weekend so stay tuned!
Bob
Old 12-08-2006, 11:41 PM   #2 (permalink)
Hi Bob
where can we get a 23T from
hung is offline        Reply With Quote Quick reply to this message
Old 12-09-2006, 07:08 AM   #3 (permalink)
how about 22T -> http://www.helidirect.com/product_in...oducts_id=2199
xircom is offline        Reply With Quote Quick reply to this message
Old 12-09-2006, 06:27 PM   #4 (permalink)
The helidirect one is brass and I think the ones Bob is using are hardened aluminum which is what I would rather run. I guess the brass one would be OK, but I know the aluminum ones would be good to go for sure.
CRAZYKEV is offline        Reply With Quote Quick reply to this message
Old 12-10-2006, 11:38 AM   #5 (permalink)
Team Taco VP
They are steel not aluminum. AdrianM says they are not ready for sale yet but SOON!
Bob
Old 12-10-2006, 03:40 PM   #6 (permalink)
Bob, if we can lower the HS down with24T by reducing the throttle curve, what advantages does the 23T give us - just a question, as I am no electric expert,
Thanks,
Also, are you going to move to 5S permanantly,
Thanks,
Jeff
buster1 is offline        Reply With Quote Quick reply to this message
Old 12-11-2006, 01:44 AM   #7 (permalink)
When the speed controller is limiting voltage it does this with resistance,
pumping amps through resistance makes heat - in the speed controller
Also need to get the motor into it's efficient zone,
as the motor temperature has dramatically decreased on 22/23 T
one would assume it's much happier now
Using lower gearing may reduce the current we draw,
thus giving the battery and easier ride (very important)
and also means we bog less (that doesn't happen to the Lepton often)
Gryphon field rep
Jafa is offline        Reply With Quote Quick reply to this message
Old 12-11-2006, 03:42 PM   #8 (permalink)
There will be a lot more happy lepton owners if we can get one to fill our
Xmas stocking
Please Santa all I want is a 23T pinion
Old 12-11-2006, 06:24 PM   #9 (permalink)
Bob
Sorry, I thought I had read elsewhere that it was alum.
Steel is even better :mrgreen:
Old 12-11-2006, 08:28 PM   #10 (permalink)
Team Taco VP
Guys a buddy of mine Jason out at the field has now been running the 23T pinion for 15+ flights. He is LOVING it! 3000 head speed with 100% flat curves. Motor and ESC come down only 10 degrees above AMBIENT! 700ma less from the packs than with the 24T pinion same flight time.
Again this appears to be the pinion for those wanting high head speeds with good efficiency on the 3025-10 motor on 4S. He is using a CC85 ESC non-gov mode.
BTW, test a 22T and head speed was a tad above 2800 so 22T will also be good for those wanting a little tamer head speed.
Bob
Old 12-12-2006, 01:28 AM   #11 (permalink)
Bob, the thread doesn't seem clear - where can I get a 23T pinion for the Hyperion 3025-10,
Also, if heads speeds are up around 3000 and getting better efficiency with battery - could this be a cheaper alternative to going to 5S - also sounds like we could get almost another 1 minute of flight time,
Thanks,
Jeff
Old 12-12-2006, 01:39 AM   #12 (permalink)
Team Taco VP
You cant get the pinions yet.... AdrianM here on Helifreak will have them soon.
While this is a GREAT setup for the Lepton on 4S, 5S is totally bullistic! Personally I think 4S is a very good setup and most folks and most will be very happy with it. 5S is for "power" freaks that want so much power it is almost SCARY.... 5S was beyond what I needed but it was still fun However I am going to say there is nothing you cant do with a good 4S setup that requires 5S. 5S is a pure "Croch Rocket" of a heli so if thats what you like then go for it!
Bob
Old 12-12-2006, 12:28 PM   #13 (permalink)
thanks, i am going to stick with 4S for now - I can do all the 3D with it - but will definitely try the different pinion - are flights extending or decreasing with that pinion,
Thanks,
Jeff
Old 12-14-2006, 04:29 PM   #14 (permalink)
Thanks,
Jeff
Hi, I'm Jason.. running the 23t.. and yes I extended so far with 1 minute and still could tweak a little more.. everything is so happy with this pinion. packs, controller and motor are in the sweet zone,,,,
Over and Out!!
altitudeav8r is offline        Reply With Quote Quick reply to this message
Old 12-14-2006, 04:47 PM   #15 (permalink)
Team Taco VP
Yo Jason... you get the 5S motor in yet?
If not I want it back for some testing on another heli
Bob
Old 12-14-2006, 05:44 PM   #16 (permalink)
Bob what was your buddies flight time? Pack?
Jeff
Learn to Fly is offline        Reply With Quote Quick reply to this message
Old 12-16-2006, 09:14 PM   #17 (permalink)
Any news on when the pinions would be available?
Old 12-17-2006, 02:21 AM   #18 (permalink)
early next year is what I was told
toyturbo is offline        Reply With Quote Quick reply to this message
Old 12-17-2006, 04:27 PM   #19 (permalink)
Will the Mikado 22t 5mm 0.5 module pinion work on the Lepton?
3secondsToImpact is offline        Reply With Quote Quick reply to this message
Old 12-17-2006, 08:55 PM   #20 (permalink)
altitudeav8r,
thanks for update regarding 23T pinion - where did you gets your if its not out until the New Year,
Thanks,
Jeff
