Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Like Tree67Likes
Old 01-02-2012, 12:07 AM   #1 (permalink)
Default Diabolo setups
Be interesting to make a single point reference for setups
Scorpion 4530 LE
Jive 120HV ESC
4200 50-60C packs
Futaba BLS 351
Futaba BLS 256HV
VBAR Blue full size 5.2
Radix 710 FAI v2
Radix 95
FDR to follow!
John
Old 01-02-2012, 02:17 AM   #2 (permalink)
Smile
Oh, my fist post in this forum. I'm from germany and i fly my diabolo since october 15th and now the heli have 63 flights with the following setup without any problems and enough power:
Scorpion 4525 LE & 18 Pinion
Roxxy 9120-12 ESC & CC BEC Pro v2
4000 30C 12S & 4500 30C 12S
V-Stabi 5.2 Blue full size governor with Hyperion RPM sensor
Savöx SC-1258TG @ 6.8V
Futaba BLS251 @5.9V
Edge 713 FBL
Edge 105
More about my diabolo at helifleet.com.
PeterLustich is offline        Reply With Quote Quick reply to this message
Old 01-02-2012, 02:31 AM   #3 (permalink)
Still on order but I have these parts for it:
Radix 710 main blades
Radix 110 and 105 tail blades
Futaba BLS 255 cyclic, BLS 256 tail (Running off 2s lipo unregulated)
Helijive V11 120HV Mode 8
Pyro 700-52 long shaft 17 tooth ordered as recomended by Gerd
Full size blueline V Bar 5.2 Pro To use Vbar Gov
Hyperion Phase sensor
6 Nanotech 45-90c 5000mAh
EC5 Connectors, 4mm bullets to motor from esc.
Futaba R6208SB receiver
White canopy with red writing and gloss black windshield
minicopter DIABOLO LOGO 550sx
scorpion spirit futaba IISI
smsodhi is offline        Reply With Quote Quick reply to this message
Old 01-03-2012, 03:34 PM   #4 (permalink)
Scorpion 4035-560
Edge 713 & 115mm
Powerjive 120
Savöx 2271 & 2272
Microbeast
5000 & 5800 mAh packs
Diabolo: Scorpion 4530-540, MBeast V3, Edge 753 & 105, Powerjive 120
Trex 744: Wren turbine, savöx HV, JETI TX/RX, vstabi silverline
sunnyville is offline        Reply With Quote Quick reply to this message
Old 03-06-2012, 10:50 AM   #5 (permalink)
Default Diablo Setup
4530 Le
Jr Hv8717's on cyclic
Bls 251 Rudder
Helijive 120 v11
Rail 696's + 106's
This is by far the smoothest heli I've flown to date.
tigertym57 is offline        Reply With Quote Quick reply to this message
Old 03-30-2012, 06:54 PM   #6 (permalink)
I was asked about the gear ratios of the Diabolo - here is a copy of some info I posted elsewhere:
First stage has pinions for the motor which range from 15-20t - these mate up with the first stage gear wheel which is 62t. So first stage ratios vary between 3.10-4.13:1 depending on pinion.
The 1st stage has a pinion on it 18t which meshes with the main gear on the mast of 57t so 2nd stage ratio is 57/18 = 3.17. THe final ratio is found by multiplying the two together:
So 1st stage and final ratios are:
15t 4.13:1 13.09:1
16t 3.85:1 12.20:1
17t 3.65:1 11.57:1
18t 3.44:1 10.90:1
19t 3.26:1 10.33:1
20t 3.10:1 9.83:1
The 1st stage shaft has a belt pulley of 39t which drives the tail shaft pulley of 26t so that gives an increase of speed of 39/26 = 1.5 from the 1st shaft which is geared down depending on the motor pinon about ~3.5:1 so final "gearing" from motor to tail is ~3.5/1.5 or about 2.4 - so a motor speed of 20000 with a 19t pinion gives a HS of 1936 and a tail speed of 9202 Interesting to note that changing the motor pinion affects tail speed proportionately more than the HS !!!
If you want to treat the two stage gears as a single stage for ease of use of HS Calcs just input a main gear tooth size of 196 and that will give you your HS with the available pinions
John
Old 03-31-2012, 02:33 PM   #7 (permalink)
Mr Mel's HS calculator shows a main gear size of 196.3 when the Diabolo is entered?
whytlotus is offline        Reply With Quote Quick reply to this message
Old 03-31-2012, 04:30 PM   #8 (permalink)
Thanks - I was under Exxtreme stress lol 196 it is
John
Old 04-04-2012, 05:31 PM   #9 (permalink)
  • Minicopter Diabolo 2012
  • Scorpion 4525 ULTIMATE YY N°0005
  • Kontronik HeliJive 120+ HV
  • miniV-Stabi 5.2 Pro
  • 3x Outrage TorQ BL9180 HV
  • Outrage TorQ BL9188 HV
  • Hercules Super HV BEC
  • Futaba 6203S-Bus HV
  • Radix 690mm + EDGE 105mm
  • JCooler 120
Diabolo: KOSMIK160HV + Scorpion HK4530 N°717 + 3xOutrage TorQ BL9180/BL9188 HV 8,4 Volt + VStabi Silverline 5.3Pro + Bluetooth + GreenCap V2
WalsumerA3 is offline        Reply With Quote Quick reply to this message
Old 04-06-2012, 08:00 AM   #10 (permalink)
*Scorpion 4525-520LE 17 Pinion (Today I would choose a 18 Pinion for 1400-2000)
*Helijive 120+ HV
*V-Stabi Mini Blue Line 5.2 Pro
*3 x BLS451 @ 6V
*BLS256HV @ 6V (Works good so far, even if voltage is on the lower end)
*Futaba R-6203SB
*IISI TXE150 Telemetry
*Edge 713 FBL Mainbaldes
*NHP 105 Tailblades
Love the Diabolo!
Kindly waiting for 753 blades to hit europe...
X-treme 90EP - Jive 80HV, Pyro 700-52, V-Stabi
Minicopter Diabolo - Helijive, 4525-520LE, V-Stabi
h0bbiz is offline        Reply With Quote Quick reply to this message
Old 05-06-2012, 06:47 PM   #11 (permalink)
- Xera 4035/ 480kv, 19T pinion (Have 20T, just in case...)
- PowerJive 120+ HV v9, mode 4+9, 5,8v bec
- 3x BLS 252
- V-bar 5.2pro/ BLS 251
- Futaba r6008hs rx
- Radix 710mm FBL (atm)
- Radix 105mm
- Futaba 10CHG tx
- Symmetrical pitch in all modes, 35% - 45% - 55% - 65% flatline throttle, end points 100/100
Got it tached!
Setup as quoted = 1450 - 1600 - 1800 - 1900 rpm.
Looks like I will have to try out that 20T...
minicopter Diabolo, Henseleit TDR, X50e, X50n, Raptor 50
Futaba 2.4 GHz
DT75 is offline        Reply With Quote Quick reply to this message
Old 05-08-2012, 07:53 AM   #12 (permalink)
Scorpion 4525-520 Ultimate
Helijive 120
Vbar full size
Vbar governor
JR8717
JR8900G tail
2000 HS
Radix 710 V2 mains
Radix 110 tails
Sent from my iPhone 4S using Tapatalk
Team Rotorquest/ SAB Heli Canada
mtymyk is offline        Reply With Quote Quick reply to this message
Old 05-09-2012, 07:31 PM   #13 (permalink)
Default V-bar setup
Thanks guys for posting your setup sure helps.. If any of you that Have a 3D setup won't mind posting your V-bar file so I can get a good base setup that be great .. Would like to know gain,rates etc.. Thanks fellas..
kevinbj1 is offline        Reply With Quote Quick reply to this message
Old 05-11-2012, 04:31 PM   #14 (permalink)
I am finishing my collection of components so I can post my setup now:
Xera 4530-500LE
Jive 120HV
Full size V-Bar
Futaba BLS255HV / 256HV
Futaba 6203SB Rx
Hercules Super BEC
SB Matt Black or Radix 710 V2
Radix 110
ThunderPower 4400 65C
Getting 18t, 19t and 20t pinions for planned 1500, 1800, 2000 and 2100 rpm
Marcos
Banshee #27, 2x TDR, Diabolo, Logo 690SX, Raptor E700, JR Sylphide E12 EX Super Gracy, Voodoo 600, Voodoo 400, Logo 550SE, Logo 400SE, JR Forza 450. Mikado Vcontrol.
marcosp is offline        Reply With Quote Quick reply to this message
Old 05-30-2012, 08:08 AM   #15 (permalink)
Default Jlog file
Thought I'd just post my log file from todays flight. Got her up for the first time in about 4 weeks after my crash. First flight buttock clenching in Idle 1, second flight Idle 2 more relaxed and threw it about a bit more. Will get confidence up again soon. First time used the Jlog on the Diabolo. Used the nanotech's , waiting for my new TP 65C 4400 batteries. Motor was hot and esc too. Could just hold my hand on the motor for 5 sec.
Old 06-03-2012, 04:38 AM   #16 (permalink)
My Diabolo is on its way from Germany, and all the components have been collected. Good times
Scorpion 4525-520 Ultimate, 18T
Commander V 130A opto
MKS HBL 950
MKS HBL 980
BeastX
Radix 710 FBL, will try EDGE 753's once i get my hands on some.
Radix 105, EDGE 115
DIABOLO | PROTOS | T-REX 700N
headhunter is offline        Reply With Quote Quick reply to this message
Old 06-04-2012, 07:31 PM   #17 (permalink)
My Diabolo is also on its way I have wanted a TDR for some time now and after seeing the Diabolo I went for it what a nice machine! Heres my setup I have waiting.
Kontronik Black Edition HeliJive and Pyro 700/52
Full size V-Bar
Futaba 6203SB Rx
Kontronik BEC @6v
Radix 710 V2
Radix 110
Jlog
Magneto is online now        Reply With Quote Quick reply to this message
Old 06-18-2012, 09:33 PM   #18 (permalink)
Finally my Diabolo is on its way too.
Scorpion 4530LE 540KV, 18T (aiming for 1650 to 1950 headspeed)
Helijive 120HV
AR7200BX
BLS451
BLS251
Radix 710 V2
Radix 105
CACN is offline        Reply With Quote Quick reply to this message
Old 06-30-2012, 08:44 AM   #19 (permalink)
Post
Im still waiting for my kit to become available, paid for and shipped. I have the electronics sorted.
Quantum 4530-500
YGE120HV with Heatsink.
Outrage Torq 9180 Cyclics
Outrage Torq 9188 Tail
DH 711mm FBL (also have a set of Radix 710mm v2 to try)
Radix 105
SK540
WR Hercules BEC
Futaba R6203SB rx
GensAce 5000/45C
Insane Canopy on order too..
Have ordered 18T and 19T pinions. Aiming for 1800-1950-2100 so i think i only need the 19T.
360Wings is offline        Reply With Quote Quick reply to this message
Old 10-17-2012, 10:08 AM   #20 (permalink)
Now i have my tracking number below is my set up;
Kontronik 160hv Kosmik & 18t pinion
Outrage BL9180 cycli servo's
Outrage BL9188 tail servo
Mikado V-Bar silverline full size
Radix (size not yet decided)
Motor, now thats an interesting one, i was going to put the ultimate in but now i'm thinking a big LE motor, whats people's views on this, apart from the blades and motor everything else is ordered.
gashead is offline        Reply With Quote Quick reply to this message
