Banshee Helicopters Banshee Helicopter Support |
09-16-2013, 10:16 AM | #1 (permalink) |
Banshee & Kosmik wiring.
I'm trying to get this 200A fuse inline, but I don't like the way it is flexing when I put my batteries in when I have it bolted straight to the KOSMIK.
I'm seriously considering bolting a length of wire to the Kosmik and soldering the end of that wire to the 200A fuse so the wire can bend and take the stress off of the fuse. I've heard the fuse can bend and fail, so I think this might be the best solution. Has anyone done this yet? I've already split my PRC 6 connectors into bullets to reduce connectors, solder points and a bit of weight.
Mark Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc.... |
09-16-2013, 12:23 PM | #2 (permalink) |
I finally just put the Positive end connector in a vice and bent it and bent the 200A fuse.
Now the battery slides in without any issues and connecting the batteries is easy.
09-16-2013, 06:10 PM | #3 (permalink) |
nice work Mark looks good there , i have never used the fuse or the ferrite rings on my kosmiks or Heli Jives and am yet to have any issues and my Heli's get hammered
09-17-2013, 08:44 AM | #4 (permalink) | ||
I just need to adjust the tail to the small hole and balance the main blades just to be safe.
If you open this up to full screen, you can see the telemetry including headspeed.
09-20-2013, 10:19 PM | #5 (permalink) |
I also dont bolt the batt leads to kosmik on straight, they are off to the side
11-02-2013, 07:39 AM | #6 (permalink) |
I did a little rewiring and moved my BEC cables down lower on the heli so they don't run by the top of the motor and two servos on the way back.
I don't know if the BEC power will be any cleaner this way, but I figured it can't hurt.
11-02-2013, 10:32 AM | #7 (permalink) |
Mark, stupid question...what is PPM?
William Blake Team Kontronik TDR1, Banshee 850 # 22 Diabolo 700 |
11-02-2013, 10:50 AM | #8 (permalink) |
Single cable from RX to FBL, Futaba calls it S-bus.
Henseleit TDR, TDR2, TDF, TDS, TDSF Kontronik, Scorpion ESC, iChargers, VBar, VControl Old hand at Planks Peter |
11-02-2013, 11:16 AM | #9 (permalink) |
A communication signal - Pulse Position Modulation.
Jeti sends a PPM signal to the SK-720 BE.
