Go Back   HeliFreak > R/C Batteries and Charging Support > Brand Specific Charger and Battery Support > Bantam
Bantam Bantam e-Station Charger Support Forum
Old 03-27-2010, 04:53 PM   #201 (permalink)
Originally Posted by buzzcut44 View Post
Hello,
I recently recieved a used BC-6 dual power charger and I have tried to charge 3 different lipo batteries and all 3 of them showed more MhA going back in than the capacity of the battery .. as it charges the cell voltage is not too high and each cell reaches 4.2V the amperage drops like it should but the total MhA put back into the pack exceeds the total of the pack. Example: I discharged a 2s 2200 Thunder Power lipo to 6v from fully charged and it showed 1840 taken out of the battery. I then charged the battery and decided to stop charging when the MhA showed 3000 put back in to the battery and the Voltage was at 7.95 volts when I stopped it and more than a hour had passed. The invidual battery cell voltage was at 3.97V each. I did repeate this test on a different charger and the battery showed correct charging. Do I have a bad charger?
Can this charger be fixed and for cost? Also where would I send it for repairs?
Joel
Hi Joel,
We are the US Service Center for Bantam products. I will send you a PM so you can contact me on Monday.
RC Accessory is offline        Reply With Quote Quick reply to this message
Old 04-19-2010, 08:31 PM   #202 (permalink)
Originally Posted by Patrick74 View Post
Hi,
Try with this software http://www.logview.info/
You can choose the language in "English"
(Still have a bug on Windows 7, but hoping it will be resolved asap)
Have fun
Patrick
Well you've answered my question even before I asked. I can't get the E-Station graph program to run on Windows 7 either.
Dumb Thumbs is offline        Reply With Quote Quick reply to this message
Old 04-28-2010, 08:00 PM   #203 (permalink)
Will the 902 charge 2 6s 5000mah packs in series @ roughly 2C?
Also the Bantam software, any update on the Windows 7 support?
Bill Jackson
Team AlignUSA
WJackson is offline        Reply With Quote Quick reply to this message
Old 04-28-2010, 08:46 PM   #204 (permalink)
How many chargers can I run on one 23 amp power supply each charging a 3S 2100 pack?
If I'm charging at 1c the charger would be set at 2.1 amps so does that means its drawing 2.1 amps or is that 2.1 amps per cell making a total of 6.3 amps?
Pistol Pete is offline        Reply With Quote Quick reply to this message
Old 04-28-2010, 09:10 PM   #205 (permalink)
No. The 902 is 200 watts of power.
1 6S 5000 packs @ 2c would require 222 watts of power. 2 packs would require 444 watts of power.
No update yet that I am aware of for Win7.
Old 04-28-2010, 09:48 PM   #206 (permalink)
Let me reword my question?
Using this power supply http://www.competitionelectronics.co...wr_supply.html how many BC6DC's can I run on off it? The max charge current is 5 amp so does that mean I can run 4 BC6DC's off it?
I'm not an electronics guy so bear with me.
Old 04-28-2010, 11:11 PM   #207 (permalink)
That PS (power supply) is rated for 13.6V and 23A, or 317W. Assuming your chargers are 90% efficient, that gives you 285W of usable power. The BC6DC is rated at 80W, so it looks like you can run 3 chargers at full output off that PS.
BTW my website TJinTech covers much of this.
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote Quick reply to this message
Old 04-29-2010, 04:15 AM   #208 (permalink)
3 for sure, probably 4 assuming you are not maxing the current out on each charger.
Old 04-29-2010, 09:49 PM   #209 (permalink)
Thanks, so basically your comparing the watts, not the amps because the watts are the total power based on the volts and amps.
Old 05-08-2010, 05:01 PM   #210 (permalink)
Default BC8DX refuses to charge 3s pack with TEMP message
The lipo is 3s 2000mAh transmitter pack. The TX says 10.5v, so I take it to the charger.
The charger BC8DX keeps stopping itself with the status "TEMP" after a minute into the charging process. I don't have any temp probe cable, so I think the charger mistakes the temp setting and terminates the charge, because the battery is cool. I can't charge the lipo because it keeps happening like that. I don't think there's anything wrong with the charger or the lipo (3s 2200mAh), but rather the temp setting. I tried to increase the safety temp to the maximum, but it's still happening.
Immediately after it starts to charge, the tone for charge completion sounds with the "TEMP" code on the top left of the screen, then I see this:
Set 11.1v
Read 11.1v
Any idea? Thanks in advance.
rotorstart is offline        Reply With Quote Quick reply to this message
Old 05-08-2010, 05:15 PM   #211 (permalink)
Set 11.1v
Read 11.1v
Has this happened on any other batteries? Also does this happen on both sides of the charger?
Old 05-08-2010, 05:46 PM   #212 (permalink)
Great question/suggestion, Evan. I tried left (channel 1) and it started charging fine. Would it be some setting on the right side that I misconfigured? There's really not much to configure there though. Any idea? Thanks.
Old 05-09-2010, 05:44 AM   #213 (permalink)
Process of elimination. So the tx packs works correct on Ch 1, but not Ch 2. Try another pack on Ch 2 to see if that goes well.
Old 05-11-2010, 12:04 PM   #214 (permalink)
Default Same thing on another pack
Hey Evan:
Please see the attached image where the "TEMP" message is displayed when I tried today with a 6s 5000mAh pack. This is happening only on port 2 on the right. Port 1 on the left would charge the battery just fine. Is there some kind of settings that got messed up on port 2?
Thanks.
Old 05-11-2010, 12:41 PM   #215 (permalink)
Hey Evan:
Thanks.
Is there anything plugged into the temp port on that side of the charger? There are no settings that would be enabled if the temp probe is not plugged in.
Old 05-11-2010, 12:53 PM   #216 (permalink)
Evan,
Nope, no temp cable plugged in.
Thanks.
Old 05-23-2010, 11:01 AM   #217 (permalink)
Which side of the temperature sensor should be taped down on to the battery?
Blade MCX-->Blade MSR-->Trex 450 Sport
A Heli Addicts Blog
Roundwords is offline        Reply With Quote Quick reply to this message
Old 05-26-2010, 10:26 AM   #218 (permalink)
Evan seems to be MIA. If no one is going to man the Bantam Support Forum there is not much since in having one.
A Heli Addicts Blog
Old 05-26-2010, 10:33 AM   #219 (permalink)
Hello, I get on here when I can. My full time job running RC Accessory is my primary responsibility. We have been traveling quite a bit as well, We have done 8 or show in 5 months this year. Emailing me direct is the fastest way to an answer.
Old 05-26-2010, 10:34 AM   #220 (permalink)
The other support forums for brnaded products are not supported at all by the manufacturer. Its more of a grouping a questions/issues for the same products or supported by field reps and not the manufacturer or distributor.
