Old 04-27-2008, 02:02 PM   #1 (permalink)
Thumbs up SK360 on my T-Rex 450
I took the plunge and installed the SK360 on my T-Rex 450S. I'm not completely in love with the head conversion yet, but it'll do for now.
Installation of the SK360 was quite easy and the software works quite well. I tweaked all the servo reversing and gyro orientation settings to suit and off I went.
The first flights went quite nicely. It took off smoothly and flies out of the box (settings based on the "Basic 3D" profile). I turned down the hiller gain a bit using the dial (ended up at 43%). and it flies pretty nicely.
The heli seems to be a lot faster now somehow. The sound has changed a bit and it even seems to handle wind quite a bit better now! I'm definitely liking what I can see so far.
Now I have to tune my setup to get rid of a few issues:
1) Tail vibration
The vertical tail fin is visibly vibrating quite a bit. I first thought it was the tail gyro, but it's not. I think it maybe vibration caused by the SK360 itself. I think it's "shaking" the heli. But I'm not sure. Just to make sure the heli is mechanically in 100% shape I'll replace my main shaft bearings and I even bought a new tail shaft just in case (even so I don't think my tail shaft is bent at all).
I initially thought turning down the hiller gain may fix it, but just turning it down a little bit didn't seem to make a difference.
2) Piro's "tumbling"
If I piro the heli now, instead of spinning in-place, it'll "wobble" a bit or "tumble". The center of gravity is right at the main shaft as far as I can tell. Phasing is as close to 0deg as I can get it and the SK360 should be mounted correctly too. Though it does seem to slope a little towards the side with the servo connectors.
What could cause tumbling like this?
3) Elevator axis roll in FFF on pitch changes
When I fly forward (nose down) pretty fast and then change pitch, the heli will roll around the elevator axis. As in, if I fly nose down and give more positive pitch, the nose comes up and the heli slows down. Conversely, if I move towards less pitch, the nose points down and the heli speeds up.
4) Piro stop causes heli to tilt
I have my 450 setup for insane piro speed. Now when I do a fast piro (or a few ) and then stop, the heli "falls over sideways". Would this be expected on this kind of system or is this something that can be tuned out?
Thanks!
Mikado Logo 500 3D
Kontronik Jive - Mini V-Bar
int2str is offline        Reply With Quote Quick reply to this message
Old 04-27-2008, 07:46 PM   #2 (permalink)
That heli was lookin pretty baaaadd today andre. im very jealous. cant wait to see it fly!
-Nich
LPS - Last Pack Syndrome - It's always the "last" pack.
ImNix is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 12:20 AM   #3 (permalink)
> 1) Tail vibration
"The vertical tail fin is visibly vibrating quite a bit..initially thought turning down the hiller gain may fix it, but just turning it down a little bit didn't seem to make a difference."
Up and down oscillation, or actual vibrating?
It's because a flybar is in the spinning reference frame of the blades, and the gyro + heli body + swash is not. So this is the hardest thing for a flybarless conversion to handle.
While in normal flight, the gyro is compensating for wind, tail drag, maybe the swash wasn't totally level or there is some aileron/elevator/pitch interaction. A bunch of things it hides from you.
But when you piro, some of those factors spin with the body of the heli, and some do not. Also, the servos aren't infinitely fast and the linkages are not perfectly stiff. So even if the gyro knew everything about pyro rate and wind and the swash was told to "swirl" perfectly, its going to have a bigger problem: the swash will lag and so be out of phase. 15 degrees of phase error seems to be where problems are noticed, and at 2 revs per second that's only about 20ms of servo+mechanical lag.
What can be done? Give it less to compensate for, faster swash response, and better natural stability. Good CG, fast digital servos, solid mechanics, and sometimes longer blades help. Remember that most of our blades and heads are not yet designed for flybarless - although that's in the works.
That's a new one - maybe it's interaction? You might want to check that while in setup mode, the swash is level at max, zero, and negative collective pitch.
Skookum is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 12:50 AM   #4 (permalink)
Originally Posted by Skookum View Post
> 1) Tail vibration
The vertical tail fin is vibrating side to side. The bottom tip to be specific. Very high frequency (it's pretty much a blur).
I'll double check, but I didn't have any interactions last time I checked (Trueblood leveler).
Mikado Logo 500 3D
Old 04-28-2008, 07:28 AM   #5 (permalink)
That's typically a balance issue in the head, from my experience. Bent main shaft, feathering shaft or blades out of balance could be the culprit...
SpeedVision is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 07:35 AM   #6 (permalink)
Thanks.
Main shaft and feathering shaft are brand new.
I'll try balancing the blades.
Mikado Logo 500 3D
Old 04-28-2008, 11:11 PM   #7 (permalink)
For sure not the SK360 in that case, because it can only cause oscillation as fast as the servos can oscillate. In fact that high frequency vibration could be causing gyro issues.
After thinking about it this makes sense in terms of aerodynamics. The advancing blade on the left side is seeing more airspeed than the retreating blade, so increased pitch will cause nose-up. The gyro should be compensating, but isn't doing it enough or in time.
So it sounds like you need either higher hiller gain (which may be possible with less vibration), and/or a larger cyclic pitch range, maybe +--10 instead of +-8 degrees. Stiffer head damping also allows for higher gains (until the resulting vibration is too much).
Old 04-29-2008, 12:25 PM   #8 (permalink)
Lightbulb
I'm running an all metal head at this point with Trueblood dampeners. Not sure how I could get the head dampening stiffer. Additional shims, I think?
Asides from that, here are the changes I am making:
Vibration related
- New tail drive shaft
- New tail belt
- New main shaft bearings
SK360 related
- New mounting position
Other changes
- Went back to a 12T pinion (3550KV motor) for lower head-speed
Planned setup changes
- Fix gyro settings for new orientation
- Up the hiller gain until I see oscillation (not vibration) and then back off a bit
- Possibly increase swash mix settings some for better flip/roll rates
I'm not sure if I'll be able to fly before the weekend, but I can't wait to play with this some more.
Mikado Logo 500 3D
Old 04-29-2008, 01:37 PM   #9 (permalink)
SK360 related
Hahahahaha.
That one cost me a set of Align Woodies!!
I went from bell/hillier pots facing the tail to facing heli left (looking from tail to nose).
Had to uncheck rotate 90 and had to check "flip aileron and flip elevator"... Just take your time and don't get too eager try and fly
Old 04-30-2008, 12:49 AM   #10 (permalink)
If you go to a low head speed, then you *for sure* want +-10 degrees of cyclic pitch, or you're in for some surprises with hard collective, especially in FF.
Also, Re wandering during fast piros, what helps are longer blades (335s?), higher headspeed, or just a larger heli. The smaller a heli the less natural stability; down at the 300 size for example a heli with standard blades is totally dependent on the cyclic gyro, while a 600 size heli can be hovered ok with no gyro assistance (though FF might be a mess).
Old 05-01-2008, 12:32 AM   #11 (permalink)
Question
New problem...
I've finished all the modifications I listed above. I also moved the SK360 from the back of the heli to directly under the main shaft. With the "front" label actually pointing towards the front now.
After re-orientating the SK360 and wiring everything back up, I made 100% sure that all the software settings are correct. If I tilt the helicopter right, the swash tilts left, if I tilt the helicopter right, the swash tilts left. All the servos move in the right directions as well - all seemed good.
Now when I try to take off, after a few seconds the heli wants to tip over hard to the right. I'm not touching the left stick at all during spool up, but as soon as it reaches a certain percentage, the heli just forces itself over hard right.
Is this noise from the main gear or something?
Mikado Logo 500 3D
Old 05-01-2008, 08:15 AM   #12 (permalink)
Default I feel your pain...
Here's my end of the conversations I've had with Skookum regarding my nasty tipping issue, but to the LEFT. My SK is on top of my Mini Titan in the gyro spot... Since the front of my unit is facing the tail, I have "flip aileron" and "flip elevator" checked, rotate 90 is unchecked.
Also, please note that my unit FAILED the cold test and I choose to use it at my own risk... Whether the "cold problem" is the culprit or not, the SK was at 70 or so degrees when initialized... A replacement is on the way...
Here are some excerpts of the information I provided:
I wrote:
I’ve developed a nasty tipping issue just before takeoff. This, for obvious reasons doesn’t inspire confidence. I lived through the 25% hillier decay takeoff’s early on (without incident), so I don’t think habits or skills are much at fault. I do keep my thumb on cyclic because, sometimes, I can catch the tilt, but it really snaps over (always to the left) when it wants to. I had an earlier hypothesis that it could have been contributed to the slope of my driveway, but I have since eliminated that from consideration.
I moved the Sk from inside the frame of my Mini Titan to gyro mount on top. I had a couple tenths of a millimeter gap to each side of the frame and I thought it was just too close. (Edit - no tipping problem with this setup, bell/hillier adjustment pots facing the tail, rotate 90 checked)
I do get some high frequency vibes from the tail on the bench. In the air the convenient little auxiliary horizontal fin on top of the vertical tail fin isn’t showing any signs of vibrating. Since it’s plastic, it shows everything, when vibes are present.
I did lower my control rates to 170 on the advanced tab because my Heli really seems to have a mind of its own in the air. I have aileron/elevator expo rates at 30% on my DX7 to also try to calm things down.
I spool up with a linear pitch curve and a 0-35-65-85-100 throttle curve. Tip happens seems to happen just as positive pitch starts to kick in.
I am trying to rush my takeoffs, which upsets the tail and makes
things more tricky.
Taking heli from inside (70 F) to outside (45 F). Had the heli sit outside for 5-10 minutes with no change.
Don’t think I can go too much higher than 50 on hillier pot without getting oscillation.
Phase is set per manual specifications.
Once airborne (Edit: if I'm lucky) everything responds to stick inputs correctly. As noted above, really feels like a ball bearing on glass – all over the place.
Swash is level with Trueblood tool. Blade tracking is spot on.
Running HS65 MG Servos at 6.0 volts, .11.
Out of fairness to Skookum I will summarize some of his ideas relative to the problem, but I'm not going to cut and paste his answers. He can expound and correct if necessary. Also, Skookum has been very helpful and quick to respond, so service has been outstanding!!! I am confident that these bugs will be corrected and I'll be able to spend more time flying and less time "tuning"...
Summary of Skookums comments:
Could be vibrations during spool up, make sure SK is stationary to establish a good "zero" initialization value. (My comment: Vibes are under control)
Less likely possiblility is TX "center stick" is off causing the tilt. Increase dead band to 3% to test. (My comment: Didn't help)
Tilting could be a problem linked to units that failed cold test. (My comment: This could be the problem and a flight tested unit is in route to me, so I should have feedback as early as this weekend if it arrives in time. Until then, we have to continue to consider other causes of the problems...)
They are working on a firmware upgrade for spool-up and improved self-diagnostics...
Anyway, if you've made it to the end of this novel, that's all I know right now. As soon as I have the new one installed and tested, I will report back ASAP!!!
Peace,
Michael
Old 05-01-2008, 08:25 AM   #13 (permalink)
i was also getting the kicks as you described but only to the back like pulling back on the elev. i found that when i reduced the hiller dial it would go away. the only thing i haven't got right yet is in fff when i give higher collective the heli will nose up and continue to do so so much that i can do a loop without touching the cyclic stick. i have been increasing the pitch gain a little each flight so i still might be low on that. when i do a hard climbout upright or inverted the heli climbs very straight. i think that i need a higher hiller setting, but if i do the heli will kick back on its own. i also have the heli vib free. i have spent more time concentrating on getting all the vibs to disappear than ever before.
HeathH is offline        Reply With Quote Quick reply to this message
Old 05-01-2008, 08:48 AM   #14 (permalink)
Interesting... What orientation is your SK? So far we have, gyro front facing forward - tips to the right. Gyro front facing tale - tips to the left...
My hillier is at 50% or less and bell at 30% or less. Early on, I was able to take off just fine with hillier too high, it woud just oscillate once airborne...
Only other notable change I made... I lowered my swash percentages to E=51, A=50 and C=32 and increased my servo travel percentage on the servo tab to 115% for each. This gave me the suggested pitches without having the swash percentages in the 60's...
Old 05-01-2008, 08:56 AM   #15 (permalink)
all of my swash %'s are at 65. the gyro is facing sideways so i had to check the rotate 90 button. i didnt know that the swash % should be less than 60. my hiller settings are way down. like 15 and 11 just to get it not to kick. i can go higher without the oscillations but it will kick randomly.
Old 05-01-2008, 09:21 AM   #16 (permalink)
Interesting!
And just like you, the SK360 worked fine for me rotated 90 deg...
I think I'll try to rotate it back.
Mikado Logo 500 3D
Old 05-01-2008, 09:38 AM   #17 (permalink)
Mine does the same thing. It's point "3" in the first post..
Or shall I say mine DID the same thing. Since I'm grounded until I can resolve the tipping issue...
Mikado Logo 500 3D
Old 05-01-2008, 09:59 AM   #18 (permalink)
My goal was to get the Hillier high enough to get a stable hover... Right now my heli feels like a steel ball on glass and won't hold reasonably still in a hover, unlike when it was flybar'd
This is where I tread on "thin ice", so here's Skookum's comments. I will quote his reply since this is more technique and less "problem solving"... As always I reserve the right to remove this content if he wishes...
Skookum wrote:
"Yes, I'd increase the servo travel and then lower the swash values.
Swash values should ideally all be below 60 or so to prevent interaction at max collective. So if you set the servo travel to say 110%, you could then set the swash mixing to -60, 60, -46 and you would avoid interaction. In reality I've used 65% and never run into an obvious problem, but I mostly just sport-fly.
For the gains, I don't remember if you said what your Hiller gain is up to, or what your cyclic pitch range is. With 8 degrees of cyclic pitch each way, I'd expect you could get the hiller dial up to 60% or more, at which point it shouldn't wander. At +-10 deg cyclic pitch, 50% hiller would be the same effective gain.
I did notice that on the Advanced tab the Damping gains are higher, probably you pressed Copy From Dials at some point. What copy from dials does is show you the actual gains the gyro is using. Otherwise its mostly useful when you want to lock down the gains, so you'd go "copy from dials" then enable "disable gain dials". If you press it otherwise to check what's going on, I'd press "get setup" again after to undo what it changed.
Basically the gyro takes the ratio between the hiller gain dial, and the Base hiller gain for elevator, which is say 55/50 = 1.1. It would then use the hiller gain dial value for hiller elevator gain, but for hiller-aileron and both damping numbers, it would multiply the value in the table by 1.1. See kind of wordy to explain, maybe the manual needs a diagram or table there. The idea is that ratios don't need changing that often, so it makes for one-dial field tuning.
Anyways, back to the best gains. Probably the Damping gains are too high, because they are scaled by the hiller gain dial too, that is limiting the Hiller gain. So on the advanced tab, try setting Damping gains to 16 for elevator and 12 for aileron."
The biggest issue we are facing, in my opinion, is getting the best mechanical head setup and proper head geometry to allow full servo travel (without swash binding) to allow higher hillier gains... Until the aftermarket responds, we'll have to "wing it" and do the best we can. At least we'll learn A LOT in the meantime.
Old 05-01-2008, 11:44 AM   #19 (permalink)
Team Taco CEO
For me it seems to tip away from the PC ^ label on the gyro (Gyro mounting with Pot. in the front makes heli tip toward the front left). I think the problem is from vibration and resunance. It seem it's very sensitive on how you mount the gyro. For me, it was better if you use spongier tape like to ones provided or two or three layer of white 3M foam tape. The gray 3M tape with red backing tape don't work very good.
Kevin
Don't Taco My Pack, Bro! ,
Why crash when you can POUND it!
fireup is offline        Reply With Quote Quick reply to this message
Old 05-01-2008, 11:53 AM   #20 (permalink)
Team Taco VP
Yes when testing my unit on Kevins heli this last weekend it would go full forward elevator at a certain RPM. He had it stuck down with the thin gray double sticky tape. We remounted it with 2 pieces of the 3M white foam stick tape and moved it back a bit away from the tail belt drive bearing and that solved it. I really don;t know if ti was vibration or noise from the bearing that was causing it but it was for sure one of the 2.
Bob
