Go Back   HeliFreak > R/C Electronics Support > Align 3G FBL System > Align 3GX FBL System
Align 3GX FBL System Align 3GX FBL Flybarless System Software and Hardware Support
Old 09-04-2011, 07:36 PM   #1 (permalink)
Default 3gx will not power up ???
can not get 3gx to fire up--no power---brand new --I am doing something wrong--i have wired it w/ satelite and w/reciever & sat---still nothing--is my luck that bad ?--reciever powers up / servos work --properly---just no 3gx --it will also not power up reciever--is there a switch ??
airbound is offline        Reply With Quote Quick reply to this message
Old 09-04-2011, 07:42 PM   #2 (permalink)
There is a double ended wire that must go from the rx to the 3gx. All the signal wires must also be properly connected between the controller and rx before the 3gx will allow itself to boot up. I tried to power up the system and then connect the servos and signal wires one at a time while mapping my channels. This failed. After hooking everything up and cycling the power the 3gx worked.
I was worried about DOA as well.
Tyler
Tyler is offline        Reply With Quote Quick reply to this message
Old 09-04-2011, 07:52 PM   #3 (permalink)
Thats how I did it the first time--but will retry--I was wondering about that but could not find any iinfo so I came here--cause this is the place I will repost after I give it a try--Thanks
Old 09-04-2011, 09:18 PM   #4 (permalink)
Default we have ignition --thanks tyler
redid wiring--just took her for a test drive --yahoooooo----Must have f----- the wiring --my bad ---
Old 09-04-2011, 09:34 PM   #5 (permalink)
airbound...
this might be an issue for others too.. On two separate occasions I've been asked to look over two different persons 3gx installations and assist in the initial setup. on both occasions the 3gx acted like it was stone dead.
In both cases we unplugged the units and re-wired them according to the manual (both times the wiring appeared the same as before). Yet on both occasions both of the 3gx's "came to life" and worked normally after the re-wire job.
I assume there is some mistake that is easy to make yet hard to spot, because both units and the wiring appeared the same both before and after the re-wire.
Go figure?
the collective is offline        Reply With Quote Quick reply to this message
Old 09-04-2011, 10:13 PM   #6 (permalink)
Thought I was going crazy--- must already be there--I fly rc helis
Old 09-06-2011, 04:18 PM   #7 (permalink)
It's very easy to mess the wiring up I had this problem with mine, turns out I had one lead in backwards and it stopped the whole thing working.
Take extra care when connecting it's easy to stuff up.
Joe
I'm not controlling it, I'm just preventing it from crashing.
Joe Bailey is offline        Reply With Quote Quick reply to this message
Old 09-06-2011, 04:33 PM   #8 (permalink)
Default wiring
I'm setting mine up as we speak (awaiting my batteries from the mailman). I assume that the single colored wires going to the receiver are plugged in so the wire aligns with the 'signal' post.
Thanks,
Bert
bdtrauma is offline        Reply With Quote Quick reply to this message
Old 09-06-2011, 06:35 PM   #9 (permalink)
bd...
All plugs with a single wire should be aligned so the wire goes to the signal pin.
Old 10-30-2011, 11:52 AM   #10 (permalink)
same issue here...
I am using a Satellite receiver (currently only have one, but should work for testing, right?)
hitec 5065 servos all plugged in yellow wire is "up" JR 3500G tail servo plugged in.
Ice 50 ground on the bottom plugged into the throttle
plug in the battery... nothing.
badfrog is offline        Reply With Quote Quick reply to this message
Old 10-30-2011, 11:55 AM   #11 (permalink)
Have you bound it yet?
Powered by Apple iPhone 4
-Bill-
WBFines is offline        Reply With Quote Quick reply to this message
Old 04-18-2014, 08:26 AM   #12 (permalink)
I am running futaba s.bus and having this problem....has any one else ran s.bus with the 3gx and ran into this?
mtickel25 is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 11:00 PM   #13 (permalink)
Badfrog -- Using a single satellite receiver, and with version V4.0 software installed, you need to plug the satellite into the ANT2 port, not ANT1 as directed in the program. BIND the satellite to your transmitter -- binding plug installed in the lower right horizontal connector at power-up. If using V4.0 and a DSMx satellite/DSMx Transmitter, push the little button as you apply power to the 3GX. It will bind in DSMx mode, and I also believe you need to set your TX to 22 msec, not 11.
If using a DSM2 satellite, install the binding plug in the lower right horizontal connector, apply power. Again, the single satellite must be plugged into the ANT2 port, not ANT1.
If using V3.1, the satellite will work fine in the ANT 1 port. No DSMx support is available in V3.1 or older software. DSMx satellites will bind and operate in DSM2 mode.
Dave
Making the world better, one helicopter at a time. Team Heliproz
dksia is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 11:06 PM   #14 (permalink)
BDTRAUMA -- the single wire in each of the connectors plugs into the receiver and the single wire IS the signal wire.
Power to the separate full-up receiver comes from the lower right hand horizontal connector of the 3GX connector block. GROUND is on the LEFT, +V in the middle. If you were using a 7 channel receiver, the other end would plug into the receiver's "governor" control channel. Power gets to the RX through the red/black wire, the governor control gets to the 3GX through the white wire. (Governor works for nitro heli).
You could also just use a two-wire connector (power, ground) between the lower right horizontal connector and your receiver's power input port. Again, on the horizontal connectors, GROUND is on the LEFT.
Dave
Old 04-25-2014, 11:08 PM   #15 (permalink)
For the 3GX to "come alive" it needs to be either connected to an external receiver that is functioning properly, or if using satellite receivers, you must bind them to your TX before the 3GX will fire up. As long as you have NO functional receiver connected to the 3GX, it will not power up.
S.Bus works fine. Just got finished helping a fellow up in Idaho using an S.Bus Futaba receiver. Plug things in correctly, make sure the receiver is functional and bound to your transmitter, the 3GX will come alive.
Dave
