Old 07-21-2014, 06:28 AM   #1 (permalink)
Default Head Block Question
I was doing the tear down and repairs from my last crash.
I found that the Upper Jesus bolt in the Head block got sheared, so I swapped it out with a spare I had. I noticed there was some slop in the head on rotation, i.e. the head block rotates a small amount with the main shaft held still.
I did swap the main shaft out and still had the slop. Is this normal? Im planning on replacing it but I thought I would ask here.
Fly it like you stole it!
SpringerKing
DX6i, 1sq, MSRx, Nano Cpx, 130x, 300x with Beastx, 300xl with Skookum 540
SpringerKing is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 06:40 AM   #2 (permalink)
The Airetic
Yes a very small amount of play is normal.
Free Agent....With standalone opinions.
KiloXray is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 09:46 AM   #3 (permalink)
I really like the design on the Lynx head because it clamps down on the shaft in addition to the jesus bolt. The screws that secure the follower arms act to clamp the head down on the shaft so there is no play. I wish they would come out with something similar for the 450X.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 07-21-2014, 09:54 AM   #4 (permalink)
Thanks for the information!
I was looking at blinging out the head with the lynx set up.
SpringerKing
Old 07-21-2014, 10:29 AM   #5 (permalink)
So you tighten down the bolts until the full gap is gone? I just installed the Lynx head on mine but scared of stripping out the head ( like happened on my stock plastic head) I just snug the screws down evenly as i could by tighten one a lil then the other a lil and back and forth.
as far as I know the play on mine is coming from the bottom bolt on the main gear.
I think Blade drill the holes in the shafts a lil to big for the bolts they use.
I like the Lynx head other then the top doesn't seem to be tap for the head button, I know they don't supply one was thinking could put my stock one on.
RAW 580 ,lots of Planes Powered by IX14 AMA 36 yrs.
Old 07-21-2014, 10:39 AM   #6 (permalink)
You tighten down the bolts until it clamps down on the shaft. I don't think you need to fully close the gaps in the head itself. Try it....remove the upper jesus bolt and see if you can pull the head off the shaft.
This discussion was about play in the head assembly which the OP described clearly. Whether or not slop can exist at the lower jesus bolt is out of scope for this discussion.
