Old 11-12-2014, 12:16 PM   #1 (permalink)
Default Futaba vs the Others
I plan to get into drones for FPV, fly some smaller helix, and planes.
I always loved the Futaba stuff over the others, but the BNF products available for the Spektrum stuff makes it hard to go with Futaba. Is there a reason why I should consider going with a Futaba 10JH or Futaba 8JH over the Spektrum DX7 or DX8?
photocycler is offline        Reply With Quote Quick reply to this message
Old 11-13-2014, 04:11 PM   #2 (permalink)
I have no interest in drones but from what I can gather a Futaba 8FG or 14 SG are among the best radios for use because of the programmability.
As an example I saw an Align 480 last weekend and it sure looks like its setup was designed with the Futaba.
Old 11-14-2014, 04:55 AM   #3 (permalink)
If you want good distance JR/Spectrum is not so good for FPV. The two best for that are Futaba FASST (14SG or 8FG) and the new FrSky long range radio. For the best range get a FrSky transmitter with their new L9R long range receiver (alofthobbies.com).
How far will you be flying?
RC Mike is offline        Reply With Quote Quick reply to this message
Old 11-14-2014, 05:28 AM   #4 (permalink)
If you are worried about BNF stuff try one of these at the link below. That is what i use on my T8FG for BNF.
http://www.radiocontronics.com/index...roduct_id=5130
T-Rex 550E V2 Spartan VX1n, T-Rex 250 PRO DFC Spartan VX1n, Blade 130X. Futaba T8FG Super
Toocool4 is offline        Reply With Quote Quick reply to this message
Old 11-15-2014, 08:44 PM   #5 (permalink)
You will never hear a Futaba owner say that he needs to "re-bind" his receiver......
"Just a lot of moving parts beating the air into submission"
rcflyersd is offline        Reply With Quote Quick reply to this message
Old 11-16-2014, 09:05 PM   #6 (permalink)
Love that one! Futaba won't let you down. There is a reason spektrum has all those contracts for bind in fly. It's so you are stuck with their radio. If that is your only issue I say pick up a cheap used spek 5 for $40 or a old 6 for around $70.
here is another idea! https://www.helifreak.com/showthread.php?t=586480
Micah
mhills51 is offline        Reply With Quote Quick reply to this message
Old 11-16-2014, 09:07 PM   #7 (permalink)
Toocool4, That would be a great Idea, but I can get a good used DX7 for $100 and I don't have to violate my Futaba with a spektrum add on lol!
Micah
Old 11-21-2014, 12:45 PM   #8 (permalink)
Hey... The module thing is great... But it sure is ugly. What I've done is taken the case apart and mounted a switch on the back. Wired to the module and antenna mounted inside.
When I want to use dsmx I just flick on the switch on the back and it goes to trainer mode. Fasst is off and dsmx on. And when I turn on the Futaba main power switch in the front. It doesn't activate the dsmx module.
I did this a while back so the pics arnt with me. But it's clean and neat. Oh I also made a button to access the bind button on the module.
Anyways... Futaba never fails. I've crashed many times (at least 4 times) using my old dx6i which I sold. The spectrum stuff works, but can have glitches and lockouts. I've just never had any problems ever after switching over to Futaba gear. Rock solid.
Warp 360 CGY-750 . HC3-SX . 3GX . KST215 . Polaris SBEC . 3S/6S
Atom 500 Gpro . Talon 90 | RJX XTRON 500 3GX . Talon 90
700E Pro DFC SC R6208SB + CGY-750 . ICE2 160HV
FUTABA 8FGS w/Spektrum Mod | FUTABA T6J on Phoenix dedicated
T9000 is offline        Reply With Quote Quick reply to this message
Old 11-27-2014, 07:56 AM   #9 (permalink)
Actually, if you want real serious range... skip all the 2.4GHz sets and go pickup a used 72MHz PCM set.... doesnt matter the brand.
Even the cheapest 72 set has a tremendous range advantage (miles usually) with no line of site limitation.
MA Whiplash Gas v2 | HelixHeli T700 Gas conversion | G500 Raw | Trex 450 Sport FBL | OMP M1
Futaba, Bavarian Demon, Hanson Engines| DIY Lithium field battery
jharkin is offline        Reply With Quote Quick reply to this message
Old 11-27-2014, 09:06 AM   #10 (permalink)
That may work, but I wouldn't want the 20+ hits on the way out. Plus Futaba 2.4 don't lock onto a channel like spek so you don't have the issue of loosing signal and needing to rebind. Plus the Futaba has been tested up to 3 miles. Used to control and crash the real 747 in Australia.
If your flying out of sight you are breaking many laws and all AMA rules.
Micah
Old 11-29-2014, 02:49 PM   #11 (permalink)
Futaba all the way !!
Magneto is offline        Reply With Quote Quick reply to this message
Old 11-29-2014, 04:37 PM   #12 (permalink)
Default Whats my options ?
Hi guys, I am getting back into heli's after a long lay off, due health.Anyway I started off with getting my planks back up and running all good except for one reason or another I decided to go with a FRSKY module in the back of my 9c ,I also have a new taranis I have not used yet. Problem being I nave just refurbed my 700 trex, and I am sure I am getting glitching with it. I am putting it down to the fact that while the frsky has twin antennas, they are close together. I am also about to finish putting together a helibug gasser which is going FBL,and want /need to run satalites on the controller, ssooooooo is there an option for a module plug in with the 9c or taranis that will give me a protocol that runs satalites and reliability.
Neal
neale is offline        Reply With Quote Quick reply to this message
Old 11-29-2014, 06:10 PM   #13 (permalink)
Neal
I still have a 9C but after using a 14SG I find the 9C programming is too simple for most of my setups - especially on multi-rotors with autopilots and cameras.
Old 12-04-2014, 04:33 PM   #14 (permalink)
Friends Don't Let Friends Fly Spektrum.
I own both but only put the big and expensive stuff of my 8FG. The others are just BNF stuff on a DX7s.
Llama v3, EXI 450 Pro, Nano CPX, 130X, Protos 500, various planks
Futaba 8FGH, Spektrum DX7s
18-channel scratch built tugboat controlled by modified Futaba Tx
R/C junkie for the past 25 years and counting...
kingmeow is offline        Reply With Quote Quick reply to this message
Old 12-04-2014, 10:05 PM   #15 (permalink)
Love your post lol! I also only put expensive stuff on my 8FG. The others go on my anylink 2 on my 8FG
Micah
Old 12-04-2014, 10:16 PM   #16 (permalink)
8fg for the diabolo and logo, dx8 for the smaller stuff
MS60 is offline        Reply With Quote Quick reply to this message
