Skookum Robotics Skookum Robotics SK-360 SK-540 & SK-720 Digital Flybar |
08-20-2014, 07:18 PM | #1 (permalink) |
"Send to" issue... Win 8.1. CAN'T SEE BUTTON!
Anyone else have this issue? No matter what I cannot see the "send to gyro" button... I see enough of it to click it though. I've tried everything including changing my screen resolutions etc. Is this a Win 8.1 thing?
"It's not just a hobby... it's a lifestyle" - Pete ϟ MINNESOTA! Goblin 500 + 700 / SK540 / Jives / DX8 / Quantum / RJX servos / 306b / Deep cycles Last edited by Slyster; 08-20-2014 at 11:54 PM.. |
08-20-2014, 07:54 PM | #2 (permalink) |
Check the system DPI setting, AFAIK if it is more than 100% you will not be able to see the buttons.
Jeti software has the same issue, they did not design it to re-size window properly.
-DX8 -MSH MiniProtos Stretched, SK720, DS95/DS95i, Hyp 4S 25C 2500mAh -MSH Protos Stretched, Brain, Hyp DS16/BLS251, 6S 3000mAh -Goblin 500, HC3SX, Hyp DH16/MKS980BL, Scorp 4015-1100 |
08-20-2014, 07:55 PM | #3 (permalink) |
Not just Windows 8. I reported the same issue and posted up images right when the update came out and I'm running windows 7 home premium.
Mine will always open tiny despite the setting to maximum, and requires me to manually drag the box open. I can do alittle better than you and see the top edge border of the button only. Previous version were fine.
Tony Synergy 516, Gaui R-5 Speed (RIP), Cypher Vtol Jet (RIP), Spirit FBL, Hobbywing and Scorpion Tribunus ESC, Xnova motors. The girl in my DX9 tells them all what to do |
08-20-2014, 08:42 PM | #4 (permalink) |
I use F1 to Send to then. F4. to disconnect.
Nick Flying your heli the world is still out there, but at least for the time it hasn't got you by the throat. Mini Titan E325 FBL, Blade Nano Cpx |
08-20-2014, 08:53 PM | #5 (permalink) |
yeah my MS Surface keyboard doesn't have F1 keys.....
"It's not just a hobby... it's a lifestyle" - Pete ϟ MINNESOTA! Goblin 500 + 700 / SK540 / Jives / DX8 / Quantum / RJX servos / 306b / Deep cycles |
08-20-2014, 08:59 PM | #6 (permalink) |
=] auto send working for you?
08-20-2014, 09:39 PM | #7 (permalink) |
It doesn't seem to be instant... like every time I move the sliders etc... was always unsure if it send or not so I clicked it after every change. I can see enough of it to click, but people new to Skookum won't see it.
08-21-2014, 12:04 PM | #8 (permalink) | |
Go to Preferences --> Send Setup by --> Send Button. Give it a try; Send Setup (F1) button should appear in the lower left hand corner. Ching-Ho Cheng
Nano CPx, Hirobo Quark 250 SE, Pro Upper Frame, Talon25, KDE, KST215, DS95i, Mini Vbar 450 Pro (6s), KDE, Lynx, Tarot, RJX, YEP40, KST215 & 515, SK540 465 (6s), Align DFC, HW50AV3, KST315 & 8910A+, SK720BE |
08-21-2014, 06:45 PM | #9 (permalink) |
We know that, and that isn't the problem being discussed here. The issue is that for some of us, the software doesn't open up wide enough to see all or any of the button once activated. See the image and comments in post # 3
08-21-2014, 06:59 PM | #10 (permalink) | |
Control Panel --> All control Panel Items --> Display. Then "Change the size of all items" ? I am using Smaller - 100% (default).
08-21-2014, 07:09 PM | #11 (permalink) |
I've never changed any of my display settings, but I'll take another look just in case. The prior versions of software were fine, but maybe this one needs something different. My display is the normal 100% settings, but I'll play around in the control panel and see if anything changes.
08-21-2014, 07:27 PM | #12 (permalink) | |
08-21-2014, 07:36 PM | #13 (permalink) |
Its a bug. No one should have to change anything in their PC settings to get the button to show. I'll email Art.
10-07-2014, 05:04 PM | #14 (permalink) |
why hasn't this been fixed yet? Local friend having issues too until he 'discovered' the button is mostly hidden.
10-07-2014, 06:52 PM | #15 (permalink) |
It has been fixed in version 4.05 of the GUI/Firmware/etc that is currently in beta testing. The last niggling little bugs that beta testers are finding are being worked out as of this writing. The new version should be released... maņana.
10-07-2014, 07:18 PM | #16 (permalink) |
Excellent! Thanks SpeedTape
10-07-2014, 07:49 PM | #17 (permalink) |
Have not seen the latest version of software, it is still at 4.02 ?
10-08-2014, 07:15 AM | #19 (permalink) |
Got it. Any estimate of the release date ?
