Go Back   HeliFreak > R/C Helicopter Support > SAB Goblin 500/570
SAB Goblin 500/570 SAB Heli Division - Goblin 500/570 Helicopters
Old 08-23-2015, 02:53 PM   #1 (permalink)
Default BEST G500 motor out there?
My Quantum just isn't cutting it in my G500.. what is the BEST most powerful motor you guys are using? Xnova? KDE? Savox?
Old 08-23-2015, 03:33 PM   #2 (permalink)
Well i have only used the pyro 600-12 and that has more power than i could ever use. It works awesome for this California heat. it stays very very cool.
Goblin 500: Kontronik Jive, Kontronik Pyro, MKS, Pulse, Mini Vbar
Goblin 700:Xnova, Yge, BK, Pulse, Ikon
All flown By a Spektrum Dx7 gen 1, and A Spektrum Dx9
Team Helidirect
Helis4Life77 is offline        Reply With Quote Quick reply to this message
Old 08-23-2015, 10:38 PM   #3 (permalink)
Which Quantum are you using out of curiosity?
Field Rep for Lynx Innovations and MKS Servos
Oxy3 285, Oxy4Stretch, Oxy4Max, Oxy5-520 6S, Urukay Triple head, Goblin 770 Sport.
FlatCrank is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 02:11 AM   #4 (permalink)
KDE has the most power. That being said I am able to do really hard 3d with my quantum 4120.
Goblin 380, Goblin 500, Goblin 570, Goblin 700c, Goblin nitro, Synergy N7, Blade 180cfx,
DX9,icharger 4010 Duo
Sponsored by Visa
Matt Sherman is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 02:11 AM   #5 (permalink)
I went from the QUANTUM 4120-1200kV to the Pyro 600-12 to the KDE550XF-1200-G3.
The pyro was the most efficient yet easiest to bog - good for collective management practice
The KDE was by far the most powerful when you need it, yet quite efficient when you turn the HS down and use the torque. Lov the KDE power and quality
Goblin 380, 420, 500, 570, 700. Soon RAW 420 & RAW 6s Piuma
HeliAxe is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 05:59 AM   #6 (permalink)
This puppy will handle anything you throw at it at any headspeed.
http://www.kdedirect.com/collections...e550xf-1200-g3
dl5973 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 06:27 AM   #7 (permalink)
Link: https://www.helifreak.com/showthread.php?t=708120
-Shane
ShaneXman is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 11:59 AM   #8 (permalink)
Any opinions on the Scorpion HKIII 4020-1300? I got a good deal on one of these - getting ready to start my G500 build.
SAB Goblin 380, Ikon, Xnova 3215-930
SAB Goblin 500 Sport, Ikon, Xnova 4020-1200
MSH Prôtos Max V2, Brain, MSH 4530-500; Oxy3,Jeti DS-14, RCHN #640
billsatori is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 06:19 PM   #9 (permalink)
I did a lot of research for something that will work well with a stock G500 as well as a stretched 3 rotor at high and/or low rpm, depending on preference. This is the one I came up with!
Scorpion was a runner up and some like them better. I think Quantum are lacking power.
jaybyrd is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 06:25 PM   #10 (permalink)
Waiting for Dave Mullen to review the Xnova.. vs his usual Savox. KDE loks really nice. Yeah I run the Quantum 4020-1200.
Maybe I just need more headspeed.. but it sure doesn't have the power of my G700 with the Quantum 4530... you'd think it would scale.
Old 08-24-2015, 07:12 PM   #11 (permalink)
Savox Pro spec 1200 here, but the KDE looks like a beast!
I remember Dave Mullen advised me 1-2 years ago to choose the Savox over the Quantum 1200 as it has around 15-20% power
I have never tried the Quantum 1200 that came with my 500 kit only had the Savox installed and Im happy with it
Revolectrix Ambassador
Revolectrix.com 10% Discount All Products Code
LEESS17
Lee2782 is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 07:47 PM   #12 (permalink)
The 4120-1200 has plenty of power. It's unboggable for me running 2500 HS with 516 Rail mains.
SAB KRAKEN JIVE 120, BK CYCLIC, BK TAIL, PYRO 750-500, THUNDERBOLT, VBAR
GOBLIN BT SPORT HELIJIVE 120, BK CYCLIC, BK TAIL, XNOVA 4525 530, SWITCH, VBAR
GOBLIN 570 JIVE 120, MKS SERVOS, XNOVA , SWITCH MAINS, KBDD TAILS, VBAR
seefest is offline        Reply With Quote Quick reply to this message
Old 08-24-2015, 10:26 PM   #13 (permalink)
The G500 was my first experience with Quantum motors.
Mine ran hot, had decent power but with huge peaks.
Get the XNova
Weule is online now        Reply With Quote Quick reply to this message
Old 08-24-2015, 10:45 PM   #14 (permalink)
I got the KDE motor for the same reason. It gives you the options to be able to run 520mm blades or even stretch the Goblin to run 550mm blades and still provide the power you need to smack it hard.
KDE motor pull like a tank at any headspeed
Old 08-25-2015, 10:58 AM   #15 (permalink)
I think Slysters power issues is that he runs big heavy batteries 5000mah 45C and low headspeed, 2000-2100.
At that HS and weight, I can see why it would be a dog.
Slap a 4100mah battery in there and raise the HS to at least 2450 and it will be a night and day difference.
Old 08-25-2015, 12:43 PM   #16 (permalink)
True. It could be battery weight. Although now days I run closer to ~2400rpm so I think a bigger motor might be worthwhile... the cool thing about larger motors is that they won't really detract much from flight times (if you don't use the extra power very often).. But I'll definitely borrow a friends smaller G500 lipo and give that a try before getting a new motor.
Old 08-27-2015, 01:49 AM   #17 (permalink)
Get the XNova
I thought my quantum was running hot until I temped it and was only in the high 140's to 150's. Scorpion is what runs hot. I run 2800 HS with 3700 and 4100 pulse. Has lot's of power
Sponsored by Visa
Old 08-27-2015, 03:22 AM   #18 (permalink)
Tried the Scorpion, quantum and XNOVA.
XNOVA is my favorite. Same power as the Scorpion but not heat ESC and packs (and itself) so much. Xnova is more efficient.
Goblins 380/500/570/630/700
xahhax is offline        Reply With Quote Quick reply to this message
Old 08-27-2015, 03:39 AM   #19 (permalink)
Yes,i choosed X-nova 4025-1120 for my G500 also!
huanbuihd is offline        Reply With Quote Quick reply to this message
Old 08-27-2015, 08:09 AM   #20 (permalink)
Does the KDE fit under the stock canopy without opening up the hole.
ChuckL is offline        Reply With Quote Quick reply to this message
