Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 425
Hurricane 425 Discussion and support of the Gaui Hurricane 425
Old 10-21-2011, 10:06 AM   #1 (permalink)
Red face assemble hurricane
Hello i like to build my first helicopter and i take the hurricane basic kit
if you can check my list and tell my if i need to change items:
Turnigy 500 H3126 Brushless outrunner 1300KVGaui 425 & 550Steel Pinion Gear Pack(13T for 5.0mm shaft)HXT 10kg Servo (metal gear) 55g / 10kg / .16sec x 3HKS-9257 High Speed Servo 4.5kg/ 25g/ 0.07secHobbyKing GA-250 MINI-MEMS Gyro ZIPPY Flightmax 2650mAh 3S1P 40CBirdie 90A Brushless ESC w/ 3A BEC430mm Wooden Main Blade (Blue/White)
Also if you have some assemble photo for the kit or video the manual was very hard for me
Thank you all
yuvalnet is offline        Reply With Quote Quick reply to this message
Old 10-21-2011, 11:30 AM   #2 (permalink)
Any chance that you can give links to some of those things as I don't recognise them ...
Some initial thoughts ..
Turnigy 500 H3126 Brushless outrunner 1300KV - should be OK
Gaui 425 & 550Steel Pinion Gear Pack(13T for 5.0mm shaft) - Should be OK but I would go with the 50T primary gear and a 15T pinion personally
HXT 10kg Servo (metal gear) 55g / 10kg / .16sec x 3 - don't know these , sorry
HKS-9257 High Speed Servo 4.5kg/ 25g/ 0.07sec - I would go for a STandard size tail servo personally
HobbyKing GA-250 MINI-MEMS Gyro - I have one - it is rubbish, bad bounce on stops, would not help your learning - buy an HK401B at least
ZIPPY Flightmax 2650mAh 3S1P 40C - you will need to join 2 together in series
Birdie 90A Brushless ESC w/ 3A BEC - don't know it, personally I would go for this one http://www.hobbyking.com/hobbyking/s...ess%5FESC.html
430mm Wooden Main Blade (Blue/White) - I would not use wooden blades on a 425mm heli, I would try these http://www.hobbyking.com/hobbyking/s...s%5F430mm.html
Good luck,
Mike.
Old 10-21-2011, 03:12 PM   #3 (permalink)
Default new parts
Hello Mike
I change some of the item like you sad and check more
i add you new list if you can see:
Turnigy 500 H3126 Brushless outrunner 1300KVGaui 425 & 550Steel Pinion Gear Pack(13T for 5.0mm shaft)Turnigy 620DMG+HS High Torque Digital Servo (MG) 10.6kg / .13sec / 52gD50012MG 56.7g / 5.4kg / 0.05sec High Speed Digital MG Servo401B AVCS Digital Head Lock Gyro ZIPPY Flightmax 2650mAh 3S1P 40C X2Gaui GE-610 100amp ESC430mm Wooden Main Blade (Blue/White)Turnigy 2 in 1 Professional Program Box for Brushless ESCXT60 Harness for 2 Packs in Series (1pc)HobbyKing ECO6 50W 5A Balancer/Charger w/ accessories
If you think that i need to add please tell me
Thank you
Old 10-21-2011, 04:24 PM   #4 (permalink)
I still can't read your list very well, but here goes ..
Turnigy 620DMG+HS High Torque Digital Servo (MG) 10.6kg / .13sec / 52g - don't know these but spec is good
D50012MG 56.7g / 5.4kg / 0.05sec High Speed Digital MG Servo - don't know these but spec is good
401B AVCS Digital Head Lock Gyro - yes, these are basic but work
Gaui GE-610 100amp ESC - yes, that is the same (re-branded) as the one that I linked to
430mm Wooden Main Blade (Blue/White) - as I said before, I would not use these
HobbyKing ECO6 50W 5A Balancer/Charger w/ accessories - don't know this
Cheers,
Mike.
Old 10-22-2011, 12:47 AM   #5 (permalink)
A few thoughts. Kit comes with a 50T primary gear. As Mike mentioned, you should probably use a 15T or 16T pinion gear to get enough head speed. I also agree with Mike against using wood blades. Get some 430mm FG or CF blades.
The Hurricane 425 and 550 are basically the same, but, the 550 manual is much better than the 425 manual. You may want to go to the Gaui site and download the " EP550" manual as it might help you some with your build.
http://www.gaui.com.tw/html/download.asp#
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote Quick reply to this message
Old 10-22-2011, 01:14 AM   #6 (permalink)
I forgot to mention - check out Finless Bob's 550 build videos as well https://www.helifreak.com/showthread.php?t=31211
