Old 06-02-2009, 04:23 PM   #61 (permalink)
thanks guys, were there any prior review of this motor besides this one? Esprit said not alot of people buy this motor. usually the underrated motors are the best. my JGF500TH was awesome.
butters149 is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 04:24 PM   #62 (permalink)
Originally Posted by nitro-pro View Post
it all depends on how you fly...everyone will be different..your batteries will do it u will just have to start at lower flight time and see how it go's
Yep......Butters, realistically your looking at 4 min flight times, MAYBE a wee bit more.
My 500L just took a dump and I plan on buying the 1350kv Hacker. I just can't bring myself to buy a motor like the Scorpion where the bearings only last 30 flights or so.
The Hacker costs more money but I think it is a worthwhile purchase.
Ultraviolet is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 04:26 PM   #63 (permalink)
Hacker makes excellent motors.
Just because everyone flocked to Scorpion does not mean they are good.....just cheap.
Old 06-02-2009, 04:30 PM   #64 (permalink)
Couldn't have said it better my self...you pay for what you get these days
Trex 600N SE FBL, YS50, Hattori pipe, Beastx, Quick Uk everything, JR 8717's on cyclic, 9254 on the tail, push glow, Castle Creations 20 amp BEC Pro, Model Avionics Throttle Jockey Pro.
nitro-pro is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 04:36 PM   #65 (permalink)
will my stock motor screw work?
Old 06-02-2009, 04:42 PM   #66 (permalink)
The motor is rated to be 900W peak. I made almost 1100W peak from it (almost 55A spike).
I browsed a bit Power system discusion thread, someone wrote 1210KV Scorpion makes 1700W. That must be insane (if that is measured wattage, not from paper).
I choosed Hacker, because of the Scorpion bearings issue.
I really do not want to lube it or replace the bearings with Boca.
It would be nice, if someone buy 10S (1600KV) and Eagle Tree it.
I have choosen the safe side - bought 12S as recommended, but just thinking how well the 10S can work...
I do not regret, is is working great for my style of flight.
I was considering Kontronik miniPyro, but that is expensive, 200 Euro (but lighter!).
Next step will be mini Vbar, but first i need to learn how fly flybar, or maybe after next crash, if all the things on the main shaft will be broken, i will be considering FBL.
Edit: Butters: there is some accesory in the package, some propeller mounts and screws, the original screws are a bit too long, so use the ones you get with the motor.
- TDSF in a box...
- TDR #2, Scorpion 4525LE, PowerJive, MKS HBL950/980, Vbar
- TDR #1 (stock, sold at 700+ flights), e-Revo, Protos 500, Jeti DS14
jointer is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 04:48 PM   #67 (permalink)
Thanks, 4 minutes is fine, is the rule for lipo 70%? as long as the voltages arent lower then 3.5 right? What am i gonna do with my scorpion motor?
Old 06-02-2009, 05:04 PM   #68 (permalink)
80% rule no lower then 3.25 per cell
Old 06-02-2009, 05:07 PM   #69 (permalink)
Cant wait to get this badboy, hopefully itll come in by Fri or Sat. Priority from Fl to Ca. and theyll ship it tomorrow.
Old 06-02-2009, 05:16 PM   #70 (permalink)
Butters, you never used the stock motor?
I am asking because Scorpion 1600 should not be much more powerful then stock.
Let us know how the Hacker feels compared to Scorpion.
- TDSF in a box...
Old 06-02-2009, 05:18 PM   #71 (permalink)
nope, i bought my heli used, came with the scorpion, third flight motor froze, bearing busted, sent to innovative for repairs. it caused me to kinda auto hard, broke my front TT gear.
Old 06-02-2009, 05:36 PM   #72 (permalink)
how does the stock align motor compare?
any data on that
dl5973 is offline        Reply With Quote Quick reply to this message
Old 06-02-2009, 06:10 PM   #73 (permalink)
Sorry, not from me. 3.5mm bullets i ordered have been a bit different then stock, so i was forced to change connectors also on ESC, now i cannot plug the original motor without soldering another set.
Also i am leaving for three days with the heli (half business trip, half holiday) and after that i must return the Eagle Tree to its owner.
However if you find somewhere log with stock motor, i would be happy to see it, but i have not found any (also i was not searching much).
Shame i did not managed to do it, but hell, i do not even want to go back.
- TDSF in a box...
Old 06-03-2009, 04:13 AM   #74 (permalink)
i will try logging stock motor
Old 06-03-2009, 06:42 AM   #75 (permalink)
if i get the 10S can i still use the stock esc?
Old 06-03-2009, 06:50 AM   #76 (permalink)
I think you can without problems, stock 60A ESC is rated 70A peak, with 12S my best spike was 55A, full pitch +12 degree slam from ground, but if you are not insane stick banger, you will not get there.
Average current consumed during my flights is about 22A.
- TDSF in a box...
Old 06-03-2009, 06:57 AM   #77 (permalink)
im e-mail esprit to see if i can change it to a 10S, im gonna call them when they open. im also of thinking of paralleing my 2 6S 2200 to make it 4400 6S or just get a 3300 6S
Old 06-03-2009, 08:31 AM   #78 (permalink)
way too much weight i think...it will never fit under the canopy even with the tray drop
Old 06-03-2009, 08:38 AM   #79 (permalink)
butters you may want to stick with the 12s if you are worried about flight times as the 10s will be worse flight times but more power
Old 06-03-2009, 10:45 AM   #80 (permalink)
screw it, already ordered the 10s hahaha, gonna get the 3300mah 35C batts.
