Flybarless Helicopter Systems CSM Cyclock, Helitronix Multi-mixer, Spartan AP2000i, Firmtronix Digimix-3, Gyrobot, SK360and AC3X |
03-12-2010, 09:16 PM | #1 (permalink) |
Gyrbot900
Where do I find Video instructions programs setting for Gyrobot 900.
Thanks for appreciate! |
03-13-2010, 09:41 AM | #2 (permalink) |
I do not know about video but you can try my site where I put a set up guide
www.Heli-RND.com - we ship worldwide free; SK 720, SK 360, DS 760, GyroBot .....mostly FBL only, the good products only www.Heli-RND.com |
03-13-2010, 06:43 PM | #3 (permalink) |
Anyone have Heli-chris with Gyrobot 700 or 900 calibrate setting. I need it Thanks for appreciate.
Please adjust it for Heli-Chris with BLS251 and 3 JR 8717 HV JR 9303 TX Rudder Base Futaba BLS251 Rudder Center 0 Rudder Min. -781 Rudder Max. 1143 Gyro Direction Reverse Asymetry Rotor CW Rudder Tuning Rudder P 500 Rudder I 430 Deadband 35 Swashplate Base Servo Speed Standard Swashplate Type 120 Degr. Servo 1 Direction Normal Servo 2 Direction Reverse Servo 3 Direction Reverse Swashplate Center Pitch 34 Elev. - 27 Ail. 11 First level swashplate with the elev. and ail. values and a swashplate leveler Then install te complete head and set the pitch value (0 degr. on the blades) Swashplate limit 804 Pitch Min. -1214 Pitch Max. 1275 Rotation 0 Elevator Dir. Reverse Aileron Dir. Normal Swashplate Tuning Flybar Without Mode Standard Elev. P 350 Elev. I 500 Elev. Feedback 8 Ail. P 300 Ail. I 400 Ail. Feedback 8 Deadband 30 Beginner Angle 35 Degr. Beginner Gain 350 Beginner Override 50 Elev - Ail. Throw 30% Rudder 30% Elev. - Ail. Expo 50% Elev. - Ail. D/R 100% Rudder Expo 50% Rudder D/R 60% Last edited by zzr1; 03-13-2010 at 08:07 PM.. Reason: Adjust Fixed |
03-14-2010, 08:47 AM | #4 (permalink) | |
I found one that most closely matched my heli (main blade size) and started from there. There is a little trial and error involved. I approached it like setting up a legacy tail gyro. I turned up the gain until the heli wobbled on that axis, then I turned it down. P is equivalent to Normal Mode on tail gyro I means the heading hold component. See page 22 of the manual. Rick |
03-14-2010, 09:17 PM | #5 (permalink) | |
Thanks I have not set it up with Tail Gyro but I focus with 3 cyclic servo on heli-chris trex 700E and 3 JR DS8717HV and BLS 251. Im not good about set up with value number.
I tested with 3 cyclic servo. two servo fast but other slow.sometime weird. Align 3G is easy to set it up. What kind of heli you using with Gyrobot ? Im looking for match value setting. any idea? Thanks Quote:
03-15-2010, 12:39 PM | #6 (permalink) | |
Much of this is trial and error. Turn up the gain until it wobbles on that axis, then turn it down a notch. |
