Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 255
Hurricane 255 Discussion and support of the Gaui Hurricane 255
Old 10-30-2012, 09:32 PM   #41 (permalink)
Default gaui x2
hrc could i purchase your tail mod and gear for the gaui x2 thanks tom
helijunke is offline        Reply With Quote Quick reply to this message
Old 11-08-2012, 09:57 PM   #42 (permalink)
Default Tail Gear Upgrade
I sent a PM to HSC to get a tail gear upgrade too. Hope it works!
-B
benlyon is offline        Reply With Quote Quick reply to this message
Old 11-09-2012, 06:33 AM   #43 (permalink)
HSC
Strange I did not get the PM from you.....
Something is wrong on my PM.....investigating....
Anyway you can also kontact mee on mail jemecandrej@gmail.com
Regards
A je to ?
HSC is offline        Reply With Quote Quick reply to this message
Old 11-17-2012, 09:25 PM   #44 (permalink)
Please, send me the info for tail and gear mod aswell ! I would very much like to buy them and have them shipped to belgium!
JacobsT is offline        Reply With Quote Quick reply to this message
Old 12-09-2012, 04:42 PM   #45 (permalink)
the main pulley i got is still going strong,
its everything else that ive broken
here is a list of my latest crashes/problems
siezed belt pulley bearing
fixed that then
i nicked my tail blades and caused a loss of control in the air
hard skid landing
fixed that then
aile servo failed partialy( works but not at full travel)
so back to ds11 amb from ds09 amb
and then my one way let loose from the gear, had it epoxyed
i think all my issues are from wear and tear, and i smashed my new
edge blades too
im back in the air, for today at least. i forgot how much work ive put in this little heli
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 12-13-2012, 04:30 AM   #46 (permalink)
Question Curious...
fixed that then
hard skid landing
fixed that then
edge blades too
Fusionsx00, Wow, definitely not cool turn of events but at least your X2 is still airbourne.
Question: With the upgraded gear/tail pulley from HSC, is it a "Must Have" upgrade? Looking at the photo's, the CNC is High Quality and looks to be an excellent upgrade but I haven't read too many flying impressions with these installed.
ACTIVE FLEET: GAUI X4 II, OXY 2/3/4 >< Align >< BLADE >< Walkera
...living the Hobby 4+ minutes at a time
R3L72 is offline        Reply With Quote Quick reply to this message
Old 12-13-2012, 01:26 PM   #47 (permalink)
I have them installed on my 255, and they are so much better than the original red plastic versions. I have not had my belt slip once since having them installed.
Flybar Helis mSR & B/H'd HBFP2. Guru-Z Neon. Trex 250 SE. Trex 450 Sport.
Flybarless Helis mCPX V2. Gaui X2. Tarot 450 Pro. Protos 500. Compass Atom 500.
Fubarred Helis Brushless Bee & Silverlit Chinook
CageyH is offline        Reply With Quote Quick reply to this message
Old 12-13-2012, 02:06 PM   #48 (permalink)
I have both front and rear cnc-gears, top quality.
With the stock gears I got the belt to slip a few times, that has never happened with the new gears.
Also, HSC is a top guy, order with confidence.
Lynx Heli Innovations | HD Helicopters
ZyBeR is offline        Reply With Quote Quick reply to this message
Old 12-13-2012, 09:36 PM   #49 (permalink)
+1.
Is it absolutely necessary? No. Would I recommend it? Definitely. It'll let your run the belt a bit looser and have less chance for slippage.
GravityJunkie is offline        Reply With Quote Quick reply to this message
Old 12-14-2012, 02:07 AM   #50 (permalink)
the hsc cnc pulley in the front is aerospace grade
it is a perfectly machined part, it spins true and the belt pattern is perfect
the stock plastic red one is crap, the plastic one is always warped, and the belt notches do not line up .
for me this made a huge improvement on the belt hold on,
the main problem is the belt itself, it is too thin, but with this pulley you at least have one that meshes.
Old 02-08-2013, 12:41 AM   #51 (permalink)
HSC
Hello boys, good news!
After 3 mounts I have finaly some time to produce some of those " wunderpulleys"
Soo if someboey want some kontact mee on PM....
Regards
A je to ?
Old 02-08-2013, 03:13 PM   #52 (permalink)
Great news, those rock..
By the way I do recall you were experimenting with different belts at some point,
any success with that?
djelom is offline        Reply With Quote Quick reply to this message
Old 02-18-2013, 01:15 PM   #53 (permalink)
HSC hasn't replied to my PM so I'll post here to see if anybody might know?
Yesterday, I started sorting through the remains of my smashed X2 after ignoring it for a month and a half to see where I was on getting it back together. I remembered/discovered my HSC rear tail gear and shaft had snapped in two.
One of my questions to Mr. HSC was, although less than optimal, if I could just use the stock Gaui part.
Another of my questions was the gear machined as part of the shaft and if not, could it be removed and put on another shaft. Last night, I took a stock gear/shaft and was able to press the gear off the shaft and with that success and knowledge, was able to remove my HSC gear from the broken HSC shaft. I now have a gearless stock shaft and the HSC gear.
Does anybody know how these are connected? Is it an interference or friction fit or is something like sleeve retainer or other adhesive used? The HSC gear seems minutely looser on a stock shaft compared to the snapped HSC shaft. I'm just wondering if anybody knows if I can mate these up and use the HSC tail gear again?
Thanks,
-- Elisabeth
Granny's House of Choppa-R&D Division
2 Rockin' Gaui Hurricanes
- 6S 500 class. 1 FB, 1 FBL
Gaui X2 & X5- MKS,Scorpion, Castle and lotsa good stuff
2 FrankenHeli 450s, Axe 100SS, Futaba
EKron is offline        Reply With Quote Quick reply to this message
Old 02-18-2013, 02:25 PM   #54 (permalink)
HSC
Hello !
I totally forget answer your pm, soo busy lately...... Mad house...
Abut the shaft, you can change it with no problem, only keep it clean with alchol or something similar, then you need to grind a bit the part on the shaft where pulley align on shaft with diamant disc from Dremel or Proxson. And finally glue it with "Loctite 603", this adhesive is designed too glue such a things...
Regards
A je to ?
Old 02-18-2013, 03:58 PM   #55 (permalink)
Thanks, HSC. No worries.
No local availability for Loctite 603. Going to cost about $26.00 USD with freight for a 10 ML bottle I'll probably only use once. Looks like I'm just going to use the stock Gaui part.
Thanks again,
-- Elisabeth
Old 02-18-2013, 07:03 PM   #56 (permalink)
i use the stock tail shaft with the main shaft hsc pulley. i put a idle pulley on my tail box and now the belt does not slip.
thanks again hsc, your parts fixed the issue enough on my bird that i fly it with confidence now.
Old 02-18-2013, 07:22 PM   #57 (permalink)
I've pulled my HSC tail pulleys off of my crash bent shafts. I'll put the HSC on stock shafts with this:
http://astroid-designs.myshopify.com...ts/loctite-609
Old 02-18-2013, 07:53 PM   #58 (permalink)
Wow! Thanks for the link. Good to know something besides the 603 will work and not having to spend twenty bucks for a 10 ML bottle even better.
-- Elisabeth
Old 02-18-2013, 08:17 PM   #59 (permalink)
yeah astroid designs is great, i get my stuff in 1 day since im in az. he mostly stocks
mcpx and blade stuff.
Old 02-18-2013, 09:24 PM   #60 (permalink)
I just double checked and I use the 609. If you worried, the 680 is even stronger.
