Old 08-22-2013, 07:09 AM   #101 (permalink)
Not 100% the same as BX V3, since V3 has some extra params (that I've never played with anyway).
Other than that, you set it up exactly the same.
Ran another couple packs through it at lunch and it is nice and locked in again (both tail and cyclics)
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 08-22-2013, 10:37 AM   #102 (permalink)
Which BX ver do we have in the AR7200BX?
Just got the USB adapter. I presume you can only upgrade the Spektrum part?
U got an original BX?
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 08-22-2013, 12:30 PM   #103 (permalink)
I believe we have V3 in the AR7200BX. dCH also managed to upgrade his firmware.
I am just comparing the 3D-H with the original AR7200BX
Blade 180CFX | 300X
Old 09-20-2013, 03:25 AM   #104 (permalink)
Default Lynx carbon/alu skids
Still using my landing gear mod. Just drill the holes in the alu mounts to 2.5mm
Weight 15.4 grams
How much are the stock skids?
ID:	452111   Click image for larger version
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 09-20-2013, 06:21 PM   #105 (permalink)
I have a set of stock skids sitting here collecting dust...
Weight = 12.9 grams (dust included )
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 09-22-2013, 12:25 PM   #106 (permalink)
Did anyone ever check weight of the Lynx OWB vs the stock parts?
( Goblin 500, Blade 300x, AXE 100 CP ) x 2
kcgraves is offline        Reply With Quote Quick reply to this message
Old 09-23-2013, 04:55 AM   #107 (permalink)
Default Lynx OWB
This is + 6.1 grams vs. the stock plastic part. But a wonderful upgrade!
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 09-23-2013, 05:01 AM   #108 (permalink)
Default MicroHeili Blade 400 skids
OK, not bad! Only + 2.5 grams vs. stock then!
The MicroHeli ones, which are thin/light, are 23.5 grams = + 10.6 grams
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 09-23-2013, 05:18 AM   #109 (permalink)
Thanks. I have one on the way.
Old 09-23-2013, 04:09 PM   #110 (permalink)
I have just scanned through all pages of this thread for curiosity as this weekend I swapped the motors over on my 130s to determine if the performance went with the motor. Whilst there was a slight change, it was more obvious to me that all the bling and upgrades, inc 450mah packs are adding so much weight that the thrust ratios are reduced.
So, is the real question one of thrust (power) to weight ratio, rather than purely weight ?
For sure, my 300X is run @ 100% throttle with stock powertrain and takes increased collective mgmt at the end of the flight when the HS drops ! I am hoping that 2216 and CC esc with governor deliver enhance thrust to weight and more consistent feel !
MrCrash is offline        Reply With Quote Quick reply to this message
Old 09-24-2013, 02:49 AM   #111 (permalink)
IMO it's both actually.
Power to weight indicates the disc loading, which should be as light as possible.
But low total weight makes the heli feel much more nimble (quicker reactions).
Then there's reliability and vibrations for this thing. I've upgraded my 300X as I felt the need to do so. For instance the plastic tail case cracking just from flying, not crashing. And so on...
I've almost finished my Gaui X2 build. This thing is also 300 size but the parts are incredibly much smaller vs. 300X. We'll see about reliability but it goes without saying that it will have dramatically less disc loading
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 09-24-2013, 02:42 PM   #112 (permalink)
I get it !
Old 05-06-2014, 01:19 PM   #113 (permalink)
Bumping an old but relevant thread hoping to find weights for the Lynx tail upgrades... case, shaft, lever, slider and hub. Really, any upgrade weights could help this thread out but those are the hot ones on my list. Also interested to hear if they caused any problematic CoG issues.
Not wanting to be a thread mooch, I have come bearing gifts... some already posted but redundant info is not necessarily a bad thing.
Stock main blades: 35.5
Lynx main blades: 36.9
Blade green tail blades: 2.5
Lynx orange tail blades: 1.5
DS76 (no horn): 7.6
5065 (no horn): 11.2
Stock tail hub: 9.5
Stock canopy: 13.5
Fusuno fiberglass canopy: 31.1
CC BEC: 14.7
eFlite battery: 117.2
Pulse battery: 118.2
Stock ESC: 40.8
Talon 35 (no connectors): 24.9
Talon 35 (with ec3 and bullets): 29.9
Hyperion 2213-3585 motor w lynx 14t pinion: 64.5
Stock motor/pinion: 40.2
Lynx OWB main gear assembly w/ bolt: 23.8
Stock main gear assembly w/bolt: 18.6
Lynx main rotor head w/bolt: 5.0
Stock main rotor head w/bolt: 4.8
Lynx v2 swash: 9.3
Go fly one!
Dustin Mustangs is offline        Reply With Quote Quick reply to this message
Old 05-06-2014, 02:45 PM   #114 (permalink)
Paging SHYguy....where are you dude? You're certainly missed here.
Old 05-07-2014, 03:12 AM   #115 (permalink)
Yeah, when I noticed this thread got new replies I thought SHY was back! I remember last he mentioned about testing the Tesla. Maybe he got a new toy and new hobby.
Old 05-07-2014, 03:43 PM   #116 (permalink)
Well, once again I am an idiot. Some of these weights are posted on the Lynx site, inconceivable! Just for reference, my weight is 0.15g heavier than theirs for the v2 swash. I assume others are similar.
Anywho...
tail case: 11.85 (with fin and screws)
tail shaft: ???
tail crank lever: 3.6
slider: ???
tail hub: 4.8
Still all ears for the slider and shaft...
Go fly one!
Old 05-14-2014, 11:42 AM   #117 (permalink)
Hi guys! I'll soon be back! Just a loooong, cold winter and no 3D. Just indoor RC car racing.
Was 95% decided on a Tesla... but mu wife's parking skills are not up to the job :-D
And summer tires on 21" wheels are NOK 80.000 - no thanks! :-)
Micro: OMP Hobby M1
Big: SAB Goblin 500
Old 05-15-2014, 06:51 AM   #118 (permalink)
BLADE 500Xc, 300X, MCPX V2 BL, 130x Red Bull, Hubsan X4 Quadcopter, DX7s
sn00p is offline        Reply With Quote Quick reply to this message
Old 05-15-2014, 07:01 AM   #119 (permalink)
Good to hear from you SHY
Blade 180CFX | 300X
Old 05-15-2014, 01:06 PM   #120 (permalink)
