Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Like Tree12Likes
Old 01-21-2013, 04:34 AM   #301 (permalink)
mnc
Originally Posted by RCNet View Post
I really like how you mounted your sat rx. What material did you use, and how did you attach it to the radio tray?
I used a piece of a cd case,just cut it out and heated it to bend and stuck it on with vel
velcro so it is easy to remove so I can get to sk 540 for adjustments
added a small pice of foam for a spacer for my batts
ID:	386337   Click image for larger version
Never enough time, Never enough helies
mnc is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 10:58 AM   #302 (permalink)
Formerly BarnStormer
Great idea bro!
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote Quick reply to this message
Old 01-21-2013, 11:46 PM   #303 (permalink)
Finally complete. LiPos should be here tomorrow, now to wait for the weather to get halfway decent.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 11:55 AM   #304 (permalink)
I used a piece of a cd case,just cut it out and heated it to bend and stuck it on with velcro so it is easy to remove so I can get to sk 540 for adjustments
I really liked your mount. However, when I attempted to mount in this position, I found the canopy was narrow enough, it bends the antennae inside so they are no longer straight. Did you find this?
= Rb43 =
Rob43 is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 12:13 PM   #305 (permalink)
Member
Nice wiring job, BRG. About your BX mounting tape, have you run it like that before, where the tape does not cover the full mounting face?
Old 01-22-2013, 01:20 PM   #306 (permalink)
Thanks Bob!
No, I have not... but I'm gonna be swapping out that tape tonight because I am not crazy about it. I was doing the wiring and ran out of the grey 3M stuff (4011?) and the local hardware store only had Loc-Tite brand mounting tape.
Should I cover every conceivable part of the unit with tape? This is my first FBL heli.
AMA# 977012
Old 01-22-2013, 01:32 PM   #307 (permalink)
Default Warp 360 Pictures - Show Us Yours!
4010 is the stuff
Oxy 3 SK540 Minijazz 20 / WARP 360 SK540 Koby 55 / Goblin 500 SK540 jive 100 / 6HV ultimate Helijive120 SK540 / 7HV SK540 Kosmik200 / Futaba18mz / Skookum support rep
heathy is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 04:04 PM   #308 (permalink)
Originally Posted by heathy View Post
4010 is the stuff
Or 4011.
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 04:27 PM   #309 (permalink)
Member
My thought is that the entire base (mounting surface) of the unit should be covered. Maybe it doesn't matter. :
Old 01-22-2013, 04:40 PM   #310 (permalink)
Skookum recommends only ~10mm included tape as a strip at each end with an air gap in center.
Like in the pic
GimpyGolden is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 04:48 PM   #311 (permalink)
And the tape that comes with helicommand fbl's has a square cut out in the middle. I don't know enough about vibrations and damping them to understand what effect it has, but certainly interesting.
If someone is smart enough feel free to break down the science behind it for us
Kendo is offline        Reply With Quote Quick reply to this message
Old 01-22-2013, 04:58 PM   #312 (permalink)
Air can't transmit vibrations.
By supporting the right areas you maintain stability but decrease vibration.
just a guess.
Old 01-22-2013, 06:09 PM   #313 (permalink)
I've also found 4 small squares in the corners to work very well in reducing vibes.
Old 01-22-2013, 06:50 PM   #314 (permalink)
mnc
yes i seen this also dosent seem to affect range
Old 01-23-2013, 03:42 PM   #315 (permalink)
OK. Thanks. I presume that in practice, provide the satellites aren't masked by carbon, that the range far exceeds our visibility for orientation.
= Rb43 =
Old 01-24-2013, 07:48 AM   #316 (permalink)
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 01-24-2013, 11:33 PM   #317 (permalink)
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote Quick reply to this message
Old 01-25-2013, 12:38 AM   #318 (permalink)
Registered Users ):>
Wow, Linc looks great man
Banging them sticks.
-Dan Duzinski
frypan is offline        Reply With Quote Quick reply to this message
Old 01-25-2013, 09:40 AM   #319 (permalink)
Originally Posted by lazor 22 View Post
Looking good Lincoln!
Old 01-25-2013, 12:25 PM   #320 (permalink)
Member
+1
