Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > Blade 450X
Blade 450X Blade 450X Helicopters Information and Help
Old 11-17-2014, 02:01 PM   #1 (permalink)
Default Pitch chanel
Tried to fly yesterday. Spun up in idle up...flipped to sport and the thing just shot straight up like a bat out of hell. Lowered the collective and it just went faster. It all happened so fast. Hit TH and tried to feather it down. Plummeted like a rock. Landed in soft grass. Usual damage. Checked it over tonight. Beast settings all look good. DX8 pitch setting was reversed. How the crap can the radio reprogram itself?!? Flew just fine last week. I have a couple 450x files in the radio but if I selected the wrong one then it would not have been bound, right?
myvrodrocks1 is offline        Reply With Quote Quick reply to this message
Old 11-17-2014, 02:40 PM   #2 (permalink)
I've heard a few anecdotal stories like that in the past about settings getting mysteriously switched on their own. It's never happened to me personally, so I've always written it off as an accidental change while they were mucking around in the servo menu. I've seen that kind of thing plenty of times too. But who really knows? I guess the moral of the story is to always do a preflight control direction check because you can never be sure.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 11-17-2014, 02:49 PM   #3 (permalink)
Ive heard about it happeing on a DX6i. You cant beat a preflight check to ensure everything is operating as it should be.
Blade 450X - Savox, Scorp 2221-8 13t Slant Edge Lite50
Blade 450X (3D) - Hitech Servs Std ESC and 420 Motor
Blade 300X - Savox Servos, lynx tail, OWB, Talon 35, Hyperion 2213 3585 14t std main, DX6
andycrazy is offline        Reply With Quote Quick reply to this message
Old 11-17-2014, 03:22 PM   #4 (permalink)
Also a good lesson never to spool it up in my living room again...
Old 11-17-2014, 06:04 PM   #5 (permalink)
GOOD LORD. IN YOUR LIVING ROOM? Wow [emoji15]
Sent from my Phone using Tapatalk
C
MCX, 120 SR, DX6, Phoenix 5, Nano CPX, 200 SR X, 450 X, MCP X
trel is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 04:59 AM   #6 (permalink)
That was "tongue in cheek". But still smart to not do...
Old 11-19-2014, 05:00 AM   #7 (permalink)
Could I have plugged my motor in backwards causing the blades to spin the wrong way? Making up now down? I was in full control of the tail...
Old 11-19-2014, 08:31 AM   #8 (permalink)
Did you have the blade grips off recently? You may have put them on backwards with the pitch link trailing vs leading? This would make up down and down up on the 450x.
puppydog_taz is offline        Reply With Quote Quick reply to this message
Old 11-19-2014, 09:06 AM   #9 (permalink)
Viewed from above the heli the main blades should spin clockwise. In fact, it would be impossible for them to spin counter-clockwise because the one-way bearing won't allow it. So if the motor was spinning the wrong way the head wouldn't move. When viewed side on from the right side of the heli the tail blades should spin counter-clockwise. Just to be clear, the default configuration of the 450X is that the main grips are oriented with trailing edge control. The tail grips are opposite and are defaulted to leading edge control. If you install them backwards it reverses the pitch like puppydog said.
Old 11-20-2014, 06:36 AM   #10 (permalink)
I have to disagree with both of you. I know it was not the motor spinning backwards... But the one way bearing is a coupling between the main gear and tail gear, not between the motor and head. So the blades most certainly will spin the wrong way.
Also what puppydog said I also disagree with. The main blade grips do not matter. They can be installed either way and the heli flies the same.
Wait!! That's it! I put the grips on backwards! (Aluminum)
I have been going over and over grip orientation in my head and on the bench. Cyclic inputs are the same no matter what side the ball link is on. But pitch! Pitch is reversed!
Do now that I put my heli back together right, I need to reverse my radio channel again or the same thing will happen all over!
Damn!
Old 11-20-2014, 08:36 AM   #11 (permalink)
Yes you're right - I've tried that the other day.
It's strange that not everything is reversed with trailing edge blade control but it's exactly like that. Pitch up means swashplate down but nose up means front of swashplate also up.
I had to go into all that when I changed my 4503D to flybarless with a 3GX unit. I wanted to make sure that there was no surprise for the maiden flight like the heli tipping over or flipping right into my face. So I filled a whole page of paper with tiny drawings and schematics to find out.
DX9, DX6i, Align T-Rex 450L (6S) w. 3GX FBL, Blade 450-3D (resurrected with 3GX FBL), Blade 130X (retired), Blade 130S, Blade mQX, Blade nanoQX, Blade mSR (sold)
ManInAGarden is offline        Reply With Quote Quick reply to this message
