Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X7
X7 Discussion and support of the Gaui X7
Old 03-25-2012, 07:52 PM   #41 (permalink)
Originally Posted by akamullen View Post
Just tested with lots of pressure on the servos and moving sticks crazy fast for a good 20 seconds, NO brownout or lockout, NO blinking RX or sats.
I have the BEC PRO V3 set at 8V, hooked up to 6S. one power lead going to the beastX and one power lead going to the RX.
Which RX? your RX may have a much better 3.3V buffer than vbar, or the cheap RX I tried, that would be the key. But, MR MEL is right on too, I'm sure these servos draw upwards of 30A when they need to.
Maybe just try it with your setup and go?
Stuff
Rob Cherry is offline        Reply With Quote Quick reply to this message
Old 03-25-2012, 10:01 PM   #42 (permalink)
Had unforcasted rain in my flight window today, I hope to beat on mine some tomorrow after work.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 03-26-2012, 11:14 AM   #43 (permalink)
My next test will be a capacitor on the 3.3V lead that goes the satellites.
I did to string a few 4700uf capacitors in parallel and connect it to an open port on the vbar, but I've calculated that the servos will empty those capacitors in about 0.01 seconds, rendering them useless.
Stuff
Old 03-26-2012, 03:47 PM   #44 (permalink)
Either use a buffer pack (if your BEC allows it) or a Fromeco DC up system.
http://heli.dacsa.net
Old 03-26-2012, 07:12 PM   #45 (permalink)
As expected no issued at all on mine with an RX pack tonight.
Old 03-27-2012, 02:59 AM   #46 (permalink)
Yup, these servos are amp hogs, I should have put a buffer pack. I saw it glitch momentarily on bench. I put a small capacitor on vbar, but still not enough. I lost control for a brief second on the second piro flip, go full screen on video for full effect..lol
[ame]http://www.youtube.com/watch?v=rhlosmaDhk0&feature=g-all-u&context=G2e248dcFAAAAAAAAHAA[/ame]
Minion Mini Quad 4S / Mini Talon V-tail Drone / Micro H Quad on Taranis FPV
Rollin_3z is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 05:32 AM   #47 (permalink)
http://www.youtube.com/watch?v=rhlos...dcFAAAAAAAAHAA
Ouch man
Is the damage bad?
Old 03-27-2012, 08:41 AM   #48 (permalink)
ahh dude lol damn that was a bad day
BLACKOUT MINI,ZMR 250,TBS Discovery ,Zephyr 2
TARANIS X9D + ,ez-uhf jr mod
GauiX5 Gauix3
kachur779 is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 10:16 AM   #49 (permalink)
Default swash bearing
Originally Posted by Rob Cherry View Post
That's all fine and dandy, but I did that already.
I really love these servos, I'm ok with the fact that they draw power fast and furious, it results in uber sick response time. I've never seen a servo with this much torque and speed. I've been using the original outrage servos in my X5, 0.05 speed, these seem just as fast or even faster. They do have a tad bit of slop, but less slop than the stock X7 swash has. I'm waiting on my ABEC 5 replacement bearing, that should tighten things up around the swash area.
I currently get 4 flights from a 1300 2S RX pack. 2 is optimal to keep the voltage higher. This is a fair trade off for lightning quick servos, which I need.
can you give me a link to the bearing you put in the swash?
xfactor6 is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 10:43 AM   #50 (permalink)
Originally Posted by cdsexton View Post
Ouch man
Is the damage bad?
The frame survived, not one crack. One servo toasted, everything else was a right off
Old 03-27-2012, 11:00 AM   #51 (permalink)
Old 03-27-2012, 07:23 PM   #52 (permalink)
Ok, I just spent 1075.00 for another servo, 2 batts, blades and kit parts...lets see if I can get more than 3 test flights out of this rekit...
Can you imagine if this was a Outrage Goblin?
Old 03-27-2012, 07:28 PM   #53 (permalink)
Man, sorry dude!
Another confirmation that vBar (with satellites), BEC and Savox 2271 DO NOT PLAY NICE.
Stuff
Old 03-27-2012, 07:47 PM   #54 (permalink)
It's the servos.
Luckily I have the Torqs!
vr360 is offline        Reply With Quote Quick reply to this message
Old 03-27-2012, 11:07 PM   #55 (permalink)
Originally Posted by vr360 View Post
It's the servos.
Because they are so friggen fast! I'll take 'em! Ninja tocs!
Actually, it's vbar, not the damn servos. We need BEC's to step up their game AND/OR vbar needs to increase the buffer on their 3.3V rail, both mini and fullsize failed and browned out!
To me, this is just more obvious evidence that all BEC's have a limitation, they will never replace the consistency or reliability of an RX pack. The are stepping the voltage at a certain frequency (hz), and now these new servos have surpassed the stepping frequency rate and draw more power, faster than the BEC can deliver. Beastx may have a larger 3.3V rail buffer, but that doesn't fix the BEC, only hides its problem.
Stuff
Old 03-27-2012, 11:28 PM   #56 (permalink)
Man, sorry dude!
Yeah you're right man...I just added a LiFe 6.6 pack and my sbec set at 6.0 volts. Plus a capacitor for good measure!
Old 03-27-2012, 11:54 PM   #57 (permalink)
Looks like its ready to fly! (almost)
Stuff
Old 03-28-2012, 01:16 AM   #58 (permalink)
Hey guys,
When i first got into this hobby i was using Hitec A9 because i wanted the telemetry feature. I noticed that i was having complete power shutdowns using same servos, bec etc others were using on the same helicopter...i couldnt understand what was going on. I ended buying a Futaba 8FG because i was starting to have suspicions that my Hitec electronics were behind the failures. One thing i knew was that the Hitec required voltage to be above 3.5v where Spectrum and Futaba could go as low as 2.7
I decided to do some bench testing at the time using 3 INOLAB 760MG servos. I did not mount the servos or anything i simply moved the sticks on the bench. I discovered that because of the telemetry the same exact servos using the same exact power source at same voltage would draw 30% to 50% more current when plugged in to an Optima9 RX vs my R6008HS RX. The difference between the two grew even greater as load increased.
I noticed that someone was using a DX8 and just wanted to point this out as Telemetry could be part of the reason why some people are having issues while others are not.
here is the link that pointed out the issue that luckily made me switch to Futaba!
Gaui X7 MSH Brain YGE160HV Xera4035-480 Gaui X475 FES MSH Brain YGE120 Xera4020 Gaui X5 MSH Brain YGE90HV Xera 4025
Gaui X6 vbar silver 5.3 YGE120HV 700mx
joe1l is offline        Reply With Quote Quick reply to this message
Old 03-28-2012, 02:38 AM   #59 (permalink)
I'm not running Telemetry, but I am running DX8 spektrum, no problems here. I think this is a Vbar issue, not spektrum. My beastX with spektrum receiver is working fine with these servos. no lockouts or brownouts. I believe JC is running the same setup beastX, Spektrum, Bec Pro, on one of his with no problems.
AnythingHeli.com OWNER/ TEAM PILOT
GAUI X5 / X7 *
GOBLIN G380/R420/G500-x2/R580/G650/R700/G770 (and many others)* Swinging Rotortech Blades * OMP M1 & M2 * MSH Brain * * iX12*
akamullen is offline        Reply With Quote Quick reply to this message
Old 03-28-2012, 02:43 AM   #60 (permalink)
It's rather that bigger Spektrum receivers have bigger built in capacitors so they can hide the problem longer, but sooner or later they run out too.
Measure voltage drop on the processor and you can see you playing with fire.
VBar and others has smaller so its seen there faster.
