Old 04-24-2014, 03:47 AM   #1 (permalink)
Default PWM rate on align800MX with CC Edge 120HV
I've done 5 flights on my new align E700DFC non-Hv combo. The Esc logs show 220F temps which, according to CC website are too high.
My PWM settings are 12khz and timing is medium. Is it ok? If not, can i reduce it to 8? can the motor timing be reduced to low?
Currently running headspeed 2250. Shall i lower it to 2100?
Its a 44.4 volt setup, 10 pole motor, 12 teeth pinion and 112T main gear.
I need urgent help with bringing down the temp
rcfreek is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 04:41 AM   #2 (permalink)
PWM 8KHz. Motor runs fine so far. Average temps are much lower on my ESC.
Which is your average temperature?
T-Rex 700 Pro DFC BEASTX | BLADE Fusion 270 | Spektrum DX18G2
-=RAGE=- is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 01:02 PM   #3 (permalink)
PWM 8Khz here too (I realize this is a different motor)
http://www.castlecreations.com/suppo...00MX-530KV.pdf
DX8, Trex 700 dfc, Trex 550 dfc, Oxy3, Rifle 1M (plank!) PL8, PL6
atkin is offline        Reply With Quote Quick reply to this message
Old 04-24-2014, 02:49 PM   #4 (permalink)
Closed Account
See this link https://www.helifreak.com/showthread.php?t=505978
I use the above and it has worked fairly well for me.
xokia is offline        Reply With Quote Quick reply to this message
Old 04-25-2014, 01:52 PM   #5 (permalink)
Yeah, but they used PWM of 12khz for motor timing
Old 04-25-2014, 05:03 PM   #6 (permalink)
Closed Account
I'm not sure what you are asking they used PWM of 12KHz and 5 degrees for timing.
If you lower the PWM you take some of the load off your ESC and it will stay slightly cooler buy your motor will get warmer. I generally don't use any timing advance at all. Timing advance on an electric motor is kinda goofy anyway IMO.
Old 05-09-2014, 02:12 PM   #7 (permalink)
Most of the team guys use 12
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 05-18-2014, 03:16 AM   #8 (permalink)
800MX is a multistranded engine, and can efficient use 12kHz PWM. If you have a rewounded one with thick single strand, use 8 kHz.
120Amp ESC on this engine one is on the edge, since it has capabilities of short surges above 200 Amps. Make sure you put it in a place with adequate airflow! If you cannot get enough airflow, put on a fan or upgrade to 160HV ESC. 160HV have more than twice the weight of the 120HV... most weight added in the heat sink.
Goblin700-800MX-Brain; Trex550-550XF-Brain; Forza450-JR BL
-iKon; Trex250 DFC-250MX-Neuron
HeliTor is offline        Reply With Quote Quick reply to this message
Old 05-18-2014, 01:09 PM   #9 (permalink)
My EDGE gets too hot at 12KHz.
Old 05-19-2014, 06:15 AM   #10 (permalink)
yes they do get hot just keep an eye on the log
