Old 10-28-2012, 09:38 AM   #21 (permalink)
I am running mks servos on the YGE 60LV. I've run a microbeast, sk540, and MSH brain. I've not had a problem.
A friend of mine had the same problem as you are having with a castle ESC. He installed a BEC and the problem went away.
I think a capacitor *would* fix your problem though. Any way you can measure servo current draw?
aclysma is offline        Reply With Quote Quick reply to this message
Old 10-28-2012, 05:34 PM   #22 (permalink)
I ordered a servo current logger and should have it in a week.
It would be interesting to see how much current they draw
dl5973 is offline        Reply With Quote Quick reply to this message
Old 10-28-2012, 05:36 PM   #23 (permalink)
sorry to go off topic
how does the brain fly compared to sk540?
I have been curious about the brain just holding off until all issues have beeen sorted out.
Old 10-28-2012, 06:17 PM   #24 (permalink)
Same here (DS95s/DS95i) and a SK720. Telemetry for RX voltage shows no drops below 5V and the SK log backs this up.
-DX8
desertstalker is offline        Reply With Quote Quick reply to this message
Old 10-28-2012, 06:27 PM   #25 (permalink)
I might have a servo that is puttting out an abnormal amount of current.
or a faulty bec
not having much luck lately with RC gear
Old 10-28-2012, 07:17 PM   #26 (permalink)
The SK log is probably the most useful I think, if the SK can log a satellite going offline or rebooting.
Telemetry for receiver voltage I doubt has that much temporal resolution to catch a momentary voltage undershoot but I could be wrong.
But I guess there are other signs that could suggest this phenomena if you don't have a logger; you would also see this by the 'blinky' sat and and might perceive a moment of loss of control.
spykez is offline        Reply With Quote Quick reply to this message
Old 10-30-2012, 06:42 AM   #27 (permalink)
I tried to recreate what the OP is experiencing with my setup, YGE60A, MKS DS95/95i, 2x DSMX sats and MSH Brain.
I was unable to get any sats flashing.
I had the servo's pretty warm after loading them and then I was flicking the sticks as fast as I could for as long as I could and everything was solid.
So I am thinking something is not right in your setup, maybe a bad servo drawing too much current etc.
There is nothing wrong with the YGE60 BEC if everything is working as expected.
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 10-30-2012, 04:22 PM   #28 (permalink)
Originally Posted by dl5973 View Post
I loose signal within a few seconds
Also I loose power in normal flight towards the end of the lipo. My motor cuts out and back in
I'm using a Skoookum 540
So you are using the Skookum as a RX with a Sat? I'm not familiar with the 540 at all, but I've had some similar issues.
If you are using a RX....which one is it?
~Lane
LVeillon is offline        Reply With Quote Quick reply to this message
Old 10-30-2012, 05:06 PM   #29 (permalink)
No surprise there, DSMX sats will NOT flash under power loss conditions. They have no way to detect the brownout.
-DX8
Old 10-30-2012, 05:09 PM   #30 (permalink)
I thought read that if they have a brownout, they will be flashing?
Either way, I also could not get the servos to slow down/stop at all
Old 10-30-2012, 06:12 PM   #31 (permalink)
Only DSM2 ones do that, they flash on powerup if the TX is using the same 2 channels as it was when they last linked. As DSMX is channel hopping the TX will have moved on by the time the RXs link up so they have no way to know the power interruption was not deliberate on the part of the user.
-DX8
Old 10-31-2012, 01:59 AM   #32 (permalink)
If you're talking about loss of signal maybe, but I thought DSM X sats would blink if they reboot. I don't have the literature in front of me but FWIW, cast a gander at this below, maybe you might be able to explain it a wee bit more!
https://www.helifreak.com/showpost.p...50&postcount=3
Old 10-31-2012, 02:52 AM   #33 (permalink)
No, because they cannot tell if you intended to power them off or not, without the ability to detect that the TX has not been power cycled they would flash on every power-on.
-DX8
Old 10-31-2012, 04:47 AM   #34 (permalink)
Hmm.. mine don't - the LED stays solid as I power up the heli's and fortunately stay that way.
Take a look at that video again. The guy has a DSMX sat bound to his AR7200BX and it starts off with a solid LED. Some malfunction appears to occur. I think it's the satellite rebooting. I think the SBEC caused the satellite to reboot with a transient voltage undershoot. It subsequently blinks.
That said: I am no electrical engineer.
Old 10-31-2012, 06:09 PM   #35 (permalink)
But bound to what and in what mode, if you bind in DSM2 mode then they will blink, they dont in DSMX.
It is easy to test, bind in DSM2 mode and then unplug the heli (leave TX on) and plug it back in, sats will flash. Do the same thing after binding in DSMX mode and they will not flash.
-DX8
Old 10-31-2012, 07:52 PM   #36 (permalink)
Ah, thanks. Now you have me with a little doubt. Haha
Old 10-31-2012, 08:26 PM   #37 (permalink)
Yes im using the sk 540 as an RX with dsmx sats
I had a dsm2 sat and had same problem.
I installed an external bec and problem is gone.
Old 10-31-2012, 08:38 PM   #38 (permalink)
if the yge is the newer one with 6amp cont. and 12 amp peak.
you are golden.
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 10-31-2012, 10:17 PM   #39 (permalink)
There is no new 60A ESC, the smallest with a 6A BEC is the 90LV, much to big for a mini P.
-DX8
Old 10-31-2012, 10:46 PM   #40 (permalink)
I need to do more tuning. It definitely flies. It has a weird tail habit I haven't had time to try to tune out, and I can't get the cyclic to feel like I want it. But I haven't had the time to tune it because I've been trying to chase an issue on one of my bigger machines. The SK540 flew perfect out of the box with default settings, though the tail was maybe a little harsh. I'm sure I can tune that out. The Brain has amazingly friendly software that encourages you to tweak it but of the BeastX, SK540, V-Bar, and Brain, the Brain is the only one that I don't feel comfortable with on the default settings within a few flights. So I wouldn't recommend to a beginner, but for someone willing to experiment, it's worth trying.
Regarding the OP's issue, have you tried putting a capacitor on the model? It might fix the symptom.
As to fixing the root cause, I am anxious to know how your servo ampmeter test goes.
