500 Class Electric Helicopters 500 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
View Poll Results: What size lipo(s) do you use? | |||
2600 | 7 | 9.59% | |
2650 | 19 | 26.03% | |
3000 | 24 | 32.88% | |
3300 | 23 | 31.51% | |
Other | 5 | 6.85% | |
Multiple Choice Poll. Voters: 73. You may not vote on this poll |
11-25-2014, 10:46 AM | #1 (permalink) |
What size lipo do you use
It will be interesting to see what people are using.
I've used 3000 and now 3300's
AMA: 943183, DX8, Tarot 500 DFC/Vbar, Goblin 570/Brain, Blade 180 CFX, Gaui X3/Brain |
11-25-2014, 05:00 PM | #3 (permalink) |
Turnigy 2650mAh 6s 30c.
11-25-2014, 05:12 PM | #4 (permalink) |
GensAce 3300!
KBDD-Team Captain, JR DFA Team Pilot. Forza 450, Forza 600N, Forza 700, Compass 6HV-U, Warp, 7HV,Knight Pro,Knight 3D, Atom, Odin II, 6HV, 3D Plus, Knight 50, Chronos, Velos, Steam 550 and 600, OMP M2 (and anything else I can get my hands on...). |
11-25-2014, 09:44 PM | #5 (permalink) |
Some like a lightweight setup.
But I choose 3000 or 3300 mah |
11-25-2014, 09:55 PM | #6 (permalink) |
In stock atom with 430 mm blades I run 2600
With stretch running 500 mm I run 3300.
This is gonna cost me. |
11-26-2014, 05:52 PM | #7 (permalink) |
In a 500l i run mostly 2900. Have 3200s that work well also.
11-27-2014, 02:46 AM | #8 (permalink) |
Since my Align manual recommended 2600mAh, and I was a newbie when I built my first 500, that's what I went for. I've stayed with that size ever since when flying in pod and boom form, using Align, TP, and Gens Ace packs. I time my flights for 7 minutes of gentle flying.
With a Hughes 500 fuselage on, I've found that TP Prolite 6S 3900mAh balances nicely. |
11-29-2014, 07:22 AM | #9 (permalink) |
3000mAh 30C. But I fly 5S.
Trex700N2E Trex500ESPTT(PRO head and Tail ) Trex500ESP (Belted) HC500SE ....GO TEAM FLYBAR! |
11-30-2014, 10:13 PM | #10 (permalink) |
Turnigy 3000 6s 25c.
Great for how i fly. 5mins
Assualt 700 Align DomL 500 Align 470lp Dx9 Fly like there's no limits ! |
12-26-2014, 02:52 PM | #11 (permalink) |
3000 just doesn't seem to have enough weight for proper CG for me. 3300s mounted about 1/2" down from the servos seems to be perfect balance for me.
Then again, my metal tail case and KDE tail slider didn't help CG at all. I just purchased two more 3300 glacier from buddyrc. |
01-08-2015, 01:17 AM | #12 (permalink) |
For a heli, I would not go no less than 30c. Other than that, I have a 3000 and 3300. I prefer the 3000 45c for my flying.
Trex 700L Ikon 2 / Trex 700L Ikon V. 2 / SAB Goblin 500 Sport Ikon 2 / HD Cell 500 Ikon 2 It isn't about if, it is about when! |
01-08-2015, 09:30 AM | #13 (permalink) |
Following this. I thought about buying some 3300s but I worry about fit. My pulse 2600s already rub the canopy if mounted all the way up on the tray
01-08-2015, 11:04 AM | #14 (permalink) |
What kind of canopy are you using? You've got a pro, so you should already have the lowered battery tray. I'm really surprised that the 2600's rub the canopy.
<> Trex 600 ESP FBL, Trex 500 ESP FBL, Gaui X3, Oxy 3 <> <> Builds in progress: Logo 600SX, Synergy 516 <> *Spartan Vortex VX1e*
01-08-2015, 09:10 PM | #15 (permalink) |
How's your Center of gravity with holding the heli by the blades and main shaft perpendicular to the ground and boom to the left? Does the tail fall? Do you need your battery mounted all the way up?
01-08-2015, 09:50 PM | #16 (permalink) |
try some thunder power 45c 2700mah
01-08-2015, 10:56 PM | #17 (permalink) |
I have the ESP. I use the EX canopy and allows me more space. The EX canopy is much nicer than the stock canopy. When I use the stock canopy, the 3000 is a tight fit, but works.
01-09-2015, 12:45 AM | #18 (permalink) |
Honestly haven't checked. I'll check it after I get the head rebuilt. I'd like to try out some 3300s but I worry about the weight
