Go Back   HeliFreak > R/C Helicopter Support > Thunder Tiger Electric Helis > Raptor G4/E720
Raptor G4/E720 Thunder Tiger Raptor G4/E720 Helicopters
Old 05-30-2014, 01:02 AM   #1 (permalink)
Default 820's out there
Hi I've not seen much posted of the 820 and I dlike to see more so here is a picture of mine
Name:	2014-05-30 11.27.32.jpg
Compass 550 ULT, Eznov Neuron | Thunder Tiger e700 Mini Vbar | Thunder Tiger G4 e820 SPARTAN (Committed suicide)| DX8 #286
Stevewashere is offline        Reply With Quote Quick reply to this message
Old 05-30-2014, 08:36 AM   #2 (permalink)
Don't have a picture, but I'm loving mine. Currently 5 TT helis flying and this is my favorite. Using spin red tip 800's, and 120mm tailblades, plus a tail speedup gear That Benario makes. I run lower revs than is the norm, hence the tail speedup. It's smooth and precise, plenty of power and I'm just using 12S, and flights are long. With a mix of smooth 3D and some high speed flying my telemetry alarm for 4000mah capacity usage generally alerts me between 12 and 14 minutes. 400kv motor, 11/115 gearing, and 1100/1400/1600 flight modes. Can do smooth 3D at 1100 for an eternity, with telemetry indicating 8 to 10 amps stationary, less than 30 peaks and average in the low teens.Current higher of course in the other modes, but peaks for an entire flight never record 100,.. most flights under 90 peak. gps telemetry sensor showed a very surprising 106mph downwind at 1600. Adjusting for wind, probably low to mid 90mph range, which is still quite quick for a sport and smooth 3D machine. My only complaint is that my setup is too light. 12S 30C lightweight packs, smaller motor than most use, and using BEC so no rx battery, it's extremely light. While this is great for 99% of the flying, it's a bit more difficult to spin the blades up if you slow them down doing things in autorotation. Just no mass to store energy. It does auto better than my other machines and has tons of energy at the bottom, it's just a bit more difficult to spin up in the auto if you slow the blades down. I could add another pound or two of weight so it would be like everyone else's, but that just wouldn't be right <G>.
Gary Wright
Champaign Il
Helifreak user # 7001
gwright is offline        Reply With Quote Quick reply to this message
Old 05-30-2014, 09:54 AM   #3 (permalink)
Soon!
I just bought one and am in the process of assembling it (mainly trying to figure out where to mount the electronics). Then I need to figure out how to haul it. I'm actually not sure if it will fit in my car, LOL!
NRPY is offline        Reply With Quote Quick reply to this message
Old 05-30-2014, 02:07 PM   #4 (permalink)
Yes the hauling around an issue for me as I cant store it in my car permanently. I have to fold one of the rear seats forward as the heli even canopy off is 120mm to wide for my subaru wagon so for me it will be a weekend only flyer 90% of the time.
Sent from my GT-I9505 using Tapatalk
Old 06-02-2014, 02:40 AM   #5 (permalink)
Well I got another few flights in running 1700 as a head speed and went from 12 deg pitch to 14 and what a difference, not bogging and much quicker heli,
Old 06-02-2014, 10:30 AM   #6 (permalink)
That's good to know. I was wondering how much collective and cyclic pitch to run.
Old 06-02-2014, 02:30 PM   #7 (permalink)
What blades are you running
Old 06-02-2014, 03:20 PM   #8 (permalink)
Edge 813.
Also, did you guys need to shorten your motor shaft in order to clear the battery packs? My Scorpion 5035 shaft sticks out quite a bit (~14mm) beyond the motor mount counter bearing.
Old 06-02-2014, 03:35 PM   #9 (permalink)
No cutting of shaft here, but I'm using the hacker Turnado and 12S, (motor close to half a pound lighter, less battery weight also,.. it's kind of a feather <G>)
Gary Wright
Champaign Il
Old 06-02-2014, 03:48 PM   #10 (permalink)
I'm going 14s with a 380kV motor, 12T/111T, and a Kosmik 200, looking for around 1800-1900 RPM.
Old 06-02-2014, 06:06 PM   #11 (permalink)
Yes I cut mine down
Old 06-05-2014, 09:35 AM   #12 (permalink)
I have this exact setup and love it. Head speed comes out exactly where you are targeting, 1900 and some change.
bbockstanz is offline        Reply With Quote Quick reply to this message
Old 06-05-2014, 01:52 PM   #13 (permalink)
Sweet! I'm going to have some time this weekend to refocus on the E820 build. Really looking forward to flying this (enormous) thing.
Old 06-06-2014, 12:08 AM   #14 (permalink)
Hey NRPY,
post some pics id like to see more 820 action, there aren't many of us doing the e820
Steve
Old 06-06-2014, 09:46 AM   #15 (permalink)
Will do. I kind of got side tracked with some motor issues on my 7HV as well regular family stuff, but hopefully I can get back on it soon. I've got all the pieces now, so I need to get to it.
Old 08-19-2014, 04:09 AM   #16 (permalink)
Anyone got any images of there 820 also what servos are everyone using?
Old 08-26-2014, 04:50 AM   #17 (permalink)
Here's my E820 along side a N820! My spec is Xera 4530-500 motor on 12s, Kosmik 160, Savox HV servos, 12t pinion & 111t main gear, Align 780 mains & NHP 120 tails, was using NHP 800 mains but the Align 780's have transformed the heli imo. Im running it at 1850 hs and getting 4 mins 30 secs on 4400 packs but have some 5500 arrived this morning so should be closer to 6 mins now which is great for a 800 heli on 12s.
I also stuck the Kosmik up front but extended the wires (thanks Maj) so that you can still load/connect the packs from the rear so can leave the canopy on, works great like this.
N820 is also amazing, Maj is running a 120 SRX in there and is super impressive.
ID:	531693   Click image for larger version
ID:	531694   Click image for larger version
ID:	531695   Click image for larger version
George J is offline        Reply With Quote Quick reply to this message
Old 08-27-2014, 05:42 AM   #18 (permalink)
Very nice
Old 08-27-2014, 05:36 PM   #19 (permalink)
Well Ive just bit the bullet so to speak, and Im going from IKON to Spartan Vortex for my FBL unit, Im not one to be tuning and tuning and to get the best out of the IKON, So Spartan is my new FBL unit hopefully it will come in about a week.
Old 09-02-2014, 04:29 AM   #20 (permalink)
Just about to update my fbl, to a spartan, esc to a 160 amp scorpion commander, and new Revolectric 7s lipo 70c with new 4.27v cells running 14s I hope it just turns into a big power beast
