Old 01-15-2015, 01:48 PM   #1 (permalink)
Default Logo 600 SX bouncy tail
Me and my friend brought 2 logo 600 SX (one is built and we are test flying it)
We have a tail issue though that we cant resolve
The tail on take of has a wag not massive but its certainly not locked in.
When you push the model it wags out of control so clearly not flyible.
The logo 600 SX setup is
Logo 600 SX
Align 800MX 520KV on 12S
Align HV servos
Castle Edge 120 HV
12T Pinion
Target headspeed 2100-2300
Gyrhpon Bec 75
We have tried EVERYTHING we can think of to fix it this includes
Govnour on/off
changing headspeed values (curently testing around 2100-2200)
Changed Gyro from BeastX to GPRO (same issue)
Changed Servos from HV to non HV
Changed tail servo to BK7005HV and back to Align HV (same issue)
Loosend belt and tight belt
rebuilt entire tail, loose grips and tight grips
Different Gyro tail gains
Adjust tail rod length
adjusted horn sizes and holes
No matter what config we try it always has a wag which when flying goes nuts, even when we auto rotate the wag is there
Has anyone any idea or can point us in the right direction, we are avid heli builders but this one is getting the better of us......
DX18 & VBAR EVO | LOGO 600SX VBAR NEO | T-REX 500XT VBAR NEO | T-REX 600N AR7200BX | 450X
thomascoleman is offline        Reply With Quote Quick reply to this message
Old 01-15-2015, 02:22 PM   #2 (permalink)
Tail gain too high, but you tried lower gains
Binding in the tail control linkage, be sure the movement of the tail control slider is glass smooth. Usually this kind of wag doesn't change much when you apply tail inputs
Bad servo, but you tried two
Tail blades, one or both on backwards,
Logo 480 XXtreme, Logo 550SX, Logo 690SX, Logo 800 XXtreme, TDR, Minicopter Diabolo 550, Minicopter Triabolo, Goblin 500, Goblin 700, Goblin 770, KDS Agile 5.5, Voodoo 600, Voodoo 400, HD Cell 500, Thunder Tiger E700
taosgraveyard is offline        Reply With Quote Quick reply to this message
Old 01-15-2015, 03:02 PM   #3 (permalink)
Yup done all that tail is smooth as silk. End points set every time. Tail blades all on right way etc.
Old 01-15-2015, 03:24 PM   #4 (permalink)
How about the tail rod, smooth in its guide?
Old 01-15-2015, 03:33 PM   #5 (permalink)
Default Headache
Checked control rod all sliders are nice and free no binding or free movement anywhere on tail.
AndreyM is offline        Reply With Quote Quick reply to this message
Old 01-15-2015, 03:45 PM   #6 (permalink)
Is the tail bouncing up and down? Or are you getting a constant slow wag that is quite visible?
maarset is offline        Reply With Quote Quick reply to this message
Old 01-15-2015, 03:52 PM   #7 (permalink)
Constant slow wag that is very visible. Bounces one foot left and right! Any adjustments we did just make it wag faster or slower
Old 01-15-2015, 04:04 PM   #8 (permalink)
Make sure the tail box is perfectly square. Sometimes this requires shims.
Make sure the tail grips are smooth. Pull them outward and twist them.
Make sure the servo tail rod guide is not over tight.
logo 600sx, 480, vcontrol ..mcpsbl
Dsss is offline        Reply With Quote Quick reply to this message
Old 01-15-2015, 04:25 PM   #9 (permalink)
Yah Dssss got it. You have binding somewhere in the tail.
Old 01-15-2015, 04:32 PM   #10 (permalink)
Tried all that pulling tail blade grips apart and twisting and checked all links 100 times checked all bearings. This is new model and all slides smooth as silk very easy. Had this issue with other Helis and most of the time it was one of the mentioned above(something binding or loose) this is absolute different story, just can't figure it out
Old 01-15-2015, 06:20 PM   #11 (permalink)
Yep sound like some binding in the tail. Tail needs to move like there is nothing there and absolutely no stick/slip anywhere as you stroke the tail from limit to limit. Next major cause is bad tail grip bearings..
Wayne
Logo 480 / Logo 600sx / Logo 690 / Logo 700 / Vbar Control
Mentalic is online now        Reply With Quote Quick reply to this message
Old 01-15-2015, 08:15 PM   #12 (permalink)
There might be some plastic flashing inside the tail grips. I would scrape them out lightly. Re-seat those bearings.
Old 01-15-2015, 10:18 PM   #13 (permalink)
gyro set to 760 when it should be at 1520?
janol is offline        Reply With Quote Quick reply to this message
Old 01-16-2015, 02:25 AM   #14 (permalink)
Problem solved! Thanks everyone for response and advice. Realised problem was so simple Grease I used on tail slider and thrust bearings was fine at home in worm but gets stiff in cold weather. It's just above freezing outside thanks everyone again
Old 01-16-2015, 05:54 AM   #15 (permalink)
I always use "dry fluid heli' on anything ( but NOT one way bearings) like liknk balls, tail shaft, main shaft, swash. It doesn't get stuff.
Using oils and greases attracts dirt, and gets sticky when it gets cold, as you've discovered
Bacon grease? Seriously?
Old 01-16-2015, 04:01 PM   #16 (permalink)
Try balancing the tail blades. My tail blades on my 450 werent balanced and had a strange bounce but it solved it
||Mikado Logo 480XXtreme||
|Trex 450|
~Futaba 14SG~
_Kyle_ is offline        Reply With Quote Quick reply to this message
Old 01-16-2015, 04:02 PM   #17 (permalink)
Edit: Nvm just saw you fixed it.....
Also double post wooppss
|Trex 450|
~Futaba 14SG~
