X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information |
01-31-2007, 02:31 PM | #1 (permalink) |
Main gears who makes the best? Mx400
I have the Stock Main gears from Helimax (The MX400) I was wanting to get some decent maingears Both of them the one for the belt drive as well as for the Mainshaft. Any Suggestions?
Regards Mal |
01-31-2007, 04:36 PM | #2 (permalink) | |
Sorry man. Not sure anyone makes after market for them.
Dan Da Dawg - JR X9303 Hexa F550 on 3S + 6S TREX 500 + 6S TREX 600 + Blade mSR + Blade mCPx2 Brushless + 12S Rave FBL ENV |
01-31-2007, 07:45 PM | #3 (permalink) |
Maybe I am Not giving the Part the right Name. The Two Geard tooth wheels the Pinion from the motor intermeshes with one while the other meshes with a Pinion that Spins the Pinion that runs the Belt drive. I know there are aftermarket wheels...Just was wanting to know who makes the Best.
Regards Malcom |
01-31-2007, 07:49 PM | #4 (permalink) |
Moving to MX400 forum.
02-01-2007, 01:54 PM | #5 (permalink) |
Thanks Dan
Regards Mal |
02-01-2007, 02:47 PM | #6 (permalink) |
Did not help huh?
02-01-2007, 02:50 PM | #7 (permalink) |
Not yet
But i am hoping a little time will help BTW I went to www.rchover.com and bought some for the T-rex 450 they are 17.99 one of the LHS places i get stuff from said these should work and if they don`t they would take them for what I paid for them they look like a decent set. Regards Mal |
02-01-2007, 04:17 PM | #8 (permalink) |
my understanding is that trex gears will not work on the mx, for some reason or another i think they are a different size(ie tooth count).if you dont mind my asking why are you on such a mission to use different gears? my stockers have work fine thus far.
02-01-2007, 09:36 PM | #9 (permalink) | |
Well First of all I have Some "Play" on the top Gear. It moves up and down on the shaft. Now i do not know what is considerd a "Whole Bunch" but mine moves up and down about the thickness of a Dime. Wether thats wear or the previous owner did not put it together right i do not know. I have Also been told that the Stock Gears are out of round and that this is not good for the motor bearings. Now I am a Newbie but these things sound resonable to me and if i can save a motor for 17 dollars .......Maybe i am just going to fast or relying on only one answer, the more i think about it the more i come to think maybe i did jump too quick. I guess maybe i should have asked some more questions..It`s just sometimes you feel a little ...well you know Regards Mal |
02-02-2007, 08:25 AM | #10 (permalink) |
mal,
right out of the box on my mx400 there was the same slop you are talking about. i havent yet found it to be a problem. True the main gear is also probably not perfectly round, but yet again i have not found this to be a concern, I am pretty sure finless even has a video on gear mesh set up somewhere in his "techroom". If worse comes to worse just find the tight spot in the mesh, put a piece of paper in between the gears, slide them together tight, but not so tight that you cant "easily" pull the paper strip out, tighten down the motor and have at it... |
02-02-2007, 03:03 PM | #11 (permalink) | |
Regards Mal |
02-03-2007, 01:16 PM | #12 (permalink) |
Kushal_22
microheli has aftermarket gears http://www.microheli.com/mhshop/inde...44239852a550a9 http://www.grandrc.com/x_400_mod_parts |
