Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
08-16-2014, 04:44 PM | #1 (permalink) |
GPRO HELP NEEDED
Think I have major problem. I had gotten to the point where the Gpro was set up, the Talon was set up, motor was rotating in the correct direction. I had shut everything down to install the rear blades so I could set up the 10 mm deflection called for in the manual. I turned the transmitter back on, powered up the ESC which did it's usual beeping and tried to move the rear blades. Nothing was moving. Then I realized that my receivers were not lit (DSMX). So I assumed I had lost bind for some reason. I initiated the software and plugged in a battery to the Gpro but it is not responding. I tried two different batteries. The light on top of the Gpro is NOT lighting up. I am at a loss. Everything was working fine and then boom nothing works. Any help will be greatly appreciated.
