Old 04-25-2012, 10:28 AM   #121 (permalink)
Hold on y are u saying not to set the swash to single servo on my dx8...all the instructions say to set it to 90 degree single servo.
Goblin 700, TDR 2012, DX8
rdarby777 is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 11:06 AM   #122 (permalink)
Originally Posted by Russell Skinner View Post
Re fitting DFC head to older 500s
Have read elsewhere -
"For models that are being converted for the first time onto Flybarless, please note you may need to change your swashplate balls to the following: H50129"
Can anyone confirm whether this is necessary?
I have been having trouble setting up the Beast x with my 500 (see my post Beast x on a 500). I worked out on Monday that these needed to be replaced so have them on order. They should arrive today, so i'll post back my findings!
stewb is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 11:18 AM   #123 (permalink)
All depends on your FBL unit, Align units need to be set as 3 servo 120 deg swash, VBar, BeastX has to be set as 1 servo swash in your TX.
VControl
Old hand at Planks
Peter
Old 04-25-2012, 11:20 AM   #124 (permalink)
Question
Deleted double post
VControl
Old hand at Planks
Peter
Old 04-25-2012, 11:34 AM   #125 (permalink)
Thanks. Please let us know how you get on.
Russell Skinner is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 12:10 PM   #126 (permalink)
Should there be any play at all in the main gear? I have the slightest bit of play with both washers on my 500esp. Is this normal or has anyone had to use two of the thickest washer?
MSH, Cyclone
Way2evl is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 03:55 PM   #127 (permalink)
Shouldn't have any play. I bought the 500 pro main shaft spacers and used both of them that came in the package and there's absolutely zero play.
AMA #1039539
ddj74 is offline        Reply With Quote Quick reply to this message
Old 04-25-2012, 05:05 PM   #128 (permalink)
I bought the same spacers and there is a little play. When I spool up my main gear and auto rotation gear I can see it wobbeling left to right.
MSH, Cyclone
Old 04-25-2012, 05:44 PM   #129 (permalink)
the spacers won't have an effect on the main and auto gears wobbling
To make sure you have the spacers right grab the frame in one hand, the head block in the other and try to pull the head out/push it back into the frame. If you feel ,movement, you need more/thicker shims
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote Quick reply to this message
Old 04-26-2012, 03:29 PM   #130 (permalink)
Replaced the swash balls today, they are definately required when going FBL with a beast x. All set up, yet to test it in the air though.
Old 04-26-2012, 11:46 PM   #131 (permalink)
Hey Deet,
Great opening post - all the details there.
I started the conversion last night on an ESP that I had already converted to standard FBL with an AR7200BX. First thing I noticed was that I will need a shim or two (which I had to order today) due to way too much up/down play with main shaft.
Also I didn't realise until I received the kit two days back that I needed to order the new blade grips, they arrived today, I notice that the new DFC arms needs to be screwed into the blade grips, but it didnt come with any screws. Do you know what size they are? Thanks
Interestingly I also bought the 450 DFC kit and it is complete, no need for the latest blade grips for it to work, its all in one. very neat.
Phil.
_______________________________________________
Lots of things that fly and crash!
FlyingFiz is offline        Reply With Quote Quick reply to this message
Old 04-27-2012, 12:40 AM   #132 (permalink)
Originally Posted by FlyingFiz View Post
Hey Deet,
Phil.
Weird...my kit came with blade grip screws.
AMA #1039539
Old 04-27-2012, 02:18 AM   #133 (permalink)
mine had the bolts as well
Dave
Old 04-27-2012, 06:00 PM   #134 (permalink)
I do have a question though. I am using the stock align servo horns on my servo. I currently am at the second to last hole from the end with the most throw (end away from servo). I believed I measured it at 16.5mm. Is this too much throw. Should I move it in another hole? 90 degree is in the middl of both holes so either hole is going to be a little off. Thanks.
Originally Posted by Deet View Post
the servo arm hole will depend on your FBL controller, usually 16 or 13mm are the two sweet spots
What FBL unit are you running?
I have the AR7200BX. The DS510. Link is on the second to last hole.
sounds about right, do you get the blue LED at 6 degrees cyclic?, if so they its fine
I get the blue light at 6.2 degrees and still red at 6.
MSH, Cyclone
Old 04-27-2012, 10:45 PM   #135 (permalink)
near enough
Dave
Old 04-29-2012, 04:39 AM   #136 (permalink)
Assume you needed the longer swash balls. Where and why are they needed?
Old 04-29-2012, 06:51 PM   #137 (permalink)
Its the short swash balls you need on the innerswashn and as there are only 2 links now its pretty obvious where they need to go
Dave
Old 04-29-2012, 11:11 PM   #138 (permalink)
I now have to embarassingly admit that I think mine also came with the bolts.
I must have taken them out when I first opened it all up and inspected etc and misplaced the screws in my 500 helis screws collection, (read 100 plus screws) I finally found two sets of screws of different lengths that fitted perfectly. I figure that was them.
Must say the head look fantastic, appears the best mod to my heli since I went FBL with the AR7200BX.
Thanks.
Old 04-30-2012, 03:03 AM   #139 (permalink)
Thanks Deet, idiot proof then!
If these are a must, is it not worth adding them to your parts list in the first post of this thread?
Old 04-30-2012, 03:28 AM   #140 (permalink)
No because I already had an FBL head on the heli, and therefore had the short balls in place
Dave
