Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 05-22-2014, 07:12 PM   #21 (permalink)
The Scorpion
1360kv makes 630watts continuous 840watts Peak
1880kv makes 840 watts continuous 1050 watts Peak
I got 14T and 15T bar stock to make the pinions.
So now the question is:
is it worth the hassle to make the pinions in order to use the 1880kv motor or not?
and
What ESCīs work well with the scorpion motors?
AlvaSpeed is offline        Reply With Quote Quick reply to this message
Old 05-22-2014, 08:33 PM   #22 (permalink)
Member
Castle has never failed me.
I guess is depends on if you want and/or need that kind of power.
Old 05-23-2014, 08:28 AM   #23 (permalink)
Originally Posted by AlvaSpeed View Post
The Scorpion
and
Trust me, unless you're doing speed runs, you just do not need the 1880.
The 1360 actually produces a lot more than 840W peak, I've had spikes to 1350W with this motor... there is no shortage of power, it is a total beast of a motor.
Consider the fact that a 2221-8 has a continuous rating of 475W, and those are powerful little motors on your 325mm 450. This scorpion has almost 35% more continuous power on tap, and over 60% more peak power... on a heli that is not 35% larger.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
Old 06-10-2014, 11:26 PM   #24 (permalink)
How much is it to get pinions for the 18xx kv motor and where? I have been flying my dominator a lot more since I got it. I would fly the warp more with a little more power.
Just one more honey... I don't have one like this.
Kilo23 is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 09:31 AM   #25 (permalink)
For the love of god... you don't need to go that route. I don't know how else to explain it.
If you want higher headspeed, get the 18T pulley and run it with the 2520-1360... that will give you the pep you get with the high-strung dominator, but still more power.
Pulleys for the 1880 need to be custom made.
AMA# 977012
Old 06-11-2014, 09:44 AM   #26 (permalink)
I have to say that I find the HK2520-1360kv lacking in power as well(especially with higher weight setups). It has a fair amount of power but, I would like more(unless my packs are holding it back but, they are 40C Gensace). The 1880kv is considerably more powerful but, the Warps limited gearing makes it not the greatest option. I am thinking about rewinding my 1360kv to try and get some more torque out of it.
Power aside though, the Warp flies amazing. I dont think any other 450 on the market can touch its smoothness and precision in the air.
Tachead is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 10:44 AM   #27 (permalink)
Jesus! Am I missing something here? I find the stock motor to be as much power as I can handle.
I use Pulse 1350's. Standard setup with vbar gov.
maarset is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 11:18 AM   #28 (permalink)
I know that I don't need more power and can probably never fly my warp to its full potential with the current power set up but the dominator is more fun dominator with that extra power. I'm sure most of us are guilty of overpowering our helicopters just for the fun of it and not actually needing it. If it isn't ridiculously expensive for the pinions I will give it a shot.
Old 06-11-2014, 02:05 PM   #29 (permalink)
It's not that the dominator is more powerful (its actually less powerful), its that it is built to run a higher headspeed... all you need is the 18T pulley, not a new motor.
@Tachead, I dont know what you do to your heli, but I cant bog this motor with 13 degrees of pitch. I consistently log bursts of over 1000W and the occasional 1300W+ spike. The 2520-1360 is a beast of a motor.
I do full collective speed runs and even that doesn't bog it... so there has to be something else going on.
I'm using 35C Pulse packs.
The 'speed warp' is getting the 1880 for several reasons ranging from the needed extra head-speed, to compensation for losses from the two stage drive-train... the remaining power will also be needed for 10+ seconds of full collective at 15+ degrees. Nobody is doing that with the stock warp... I've seen people smack the snot out of this heli with the 1360 motor and larger pulley.
AMA# 977012
Old 06-11-2014, 02:33 PM   #30 (permalink)
Default Re: New motor for my Warp
+1, some people must be doing something wrong,. Vbar gov is amazing
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 03:05 PM   #31 (permalink)
I actually had to de-tune the vbar gov settings. Low gain and zero on Collective Add and Cyclic Add. If I didn't do this then cyclic was just way to quick for me.
I actually preferred the YGE internal gov but I would rather have the consistent HS from the fbl gov.
But Kilo has mad skills and needs that extra power!
Old 06-11-2014, 03:16 PM   #32 (permalink)
I am far from an expert pilot(hard sport at best) and barely fly these days but, it will be bog in full collective punch outs and reversals. Only at the lower head speeds however. I dropped it down to the 16 tooth pinion and that helped a bit. So did finding the max governor gain I could run and giving it a bit of overdrive. Keep in mind I am a bit on the heavy side too and running 1600mah packs. Compared to my also on the heavy side Atom 5.5 power by HKIII4020-1100kv/YGE120LVK though my Warp is tame. Am I asking too much of a small heli lol?
Sent from my SGH-I337M using Tapatalk
Old 06-11-2014, 05:07 PM   #33 (permalink)
This is normal behavior. The lower you drop the throttle curve and the further outside of the motors efficiency zone you get the more bog you will get. I actually noticed this a lot on my Goblin 500 running a YGE speed controller. It had active freewheel so I would go low on the throttle curve for low HS. The lower I would go the more bog I could observe.
NX4|Tri-Chronos|Chronos|7NT|Specter700
Saje Marvin - Citizen 125
Raz0rSh4rp is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 07:33 PM   #34 (permalink)
I know mike, I am just going to make it 12s now. That should be enough!
