Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 06-11-2014, 10:52 AM   #1 (permalink)
Default Warp #2!
I test hovered my second Warp yesterday!
This one is a third hand machine from the original batch. It has been upgraded to a current model with all the newer parts (motor can, thicker tail boom, delrin tail bellcrank mount, etc).
Balance is spot on with the Gens Ace battery pack designed for it.
This on also has a Robird and JR DMSS (via an XG14) and already feels a bit livelier than the other one:
Old 06-11-2014, 01:41 PM   #2 (permalink)
Member
Default Re: Warp #2!
Sent from my phone
Old 06-11-2014, 03:46 PM   #3 (permalink)
Welcome to the x 2 club
Name:	Warp x 2.jpg
Mini Protos, Voodoo 400, Protos 380, Protos Leggero 700 & 700X, Diabolo 700
Chris Nifty is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 06:09 PM   #4 (permalink)
Nicely done sir
Gotta love the Warp
Tachead is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 06:49 PM   #5 (permalink)
What size Gens Ace is that if you don't mind me asking?
Compass 6HV FBL, TORQ Outrage Bl 9180HVs, TORQ Bl9188, Full VBAR 5.2 Pro, HW 70A ESC, Gaui X3, JR Forza 450
DaFedMan is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 09:19 PM   #6 (permalink)
I'm using the gens 1400 packs, and mine balances perfectly with the battery place about 20mm forward on the tray
Wayne
Team Alees Australia
AleeS Rush 750 Evolution, vortex Nano. Synergy N5c, Vbar.
lowey79 is offline        Reply With Quote Quick reply to this message
Old 06-11-2014, 10:15 PM   #7 (permalink)
The battery in the photograph is a Gens Ace 6S, 1600 mah.
Old 06-13-2014, 02:38 AM   #8 (permalink)
And you need that, even with 1600mah balance is so so. Impossible to get cg right with 1400.
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 06-13-2014, 08:16 AM   #9 (permalink)
I'm using GA 1400 and my CG is perfect. That said, I'm a little lazy so because I share batteries with my X3, I have the battery carriage tray permanently affixed to my batteries which probably helps. I also run an external BEC which is mounted on the front platform along with my FBL, and esc underneath right up to the front.
So a question for those of you with a second Warp, besides those of you who had a second kit for spare purposes before realizing you'd never really use 95% of the kit as spare parts, what's the reason for having twins over going with a completely different 2nd heli?
Don't get me wrong, I love my Warp and can't see myself ever getting rid of it but I can't seem to find a good enough reason to justify owning another one. The rotting spare kit I get, maintaining and repairing less different brands of helis I get, having a Warp that is operational at all times I sort of get, and having the ability to test different components and compare their performance back-to-back I sort of get. It sounds like I'm trying to convince myself that I need a twin, and there is probably some truth to that, so please feel free to add to the list of reasons. (oh yeah and I forgot the old, "I found a deal too good to pass up" justification and for modders, one for experimentation). Anyway, a little jealous some of you guys have 2 of these, so please convince me I need to do the same
Sorry Ah Clem, I don't mean to sidetrack your thread, but I think it's related. I hope you don't mind a slight deviation. Since these weren't born at the same time, technically they aren't twins, but are they Irish twins?
DX9 | Compass Warp 360 | Gaui X3 MB v3 | T-Rex 700E V2 | Blade 130X | Blade Nano CPx
RudeRebel is offline        Reply With Quote Quick reply to this message
Old 06-13-2014, 06:09 PM   #10 (permalink)
Magical some get cg right with those light lipos. How do you determine it because it simply can't be?
Old 06-13-2014, 06:17 PM   #11 (permalink)
"And you need that, even with 1600mah balance is so so. Impossible to get cg right with 1400."
Not exactly right, sir...
My other Warp balances fine with two of the 3S, 1350 mah batteries for the Blade 300X. I just move the batteries quite far forward on the tray.
Both Warps have the extended canopy mount underneath, so that the canopy can be moved forward. I think this helps more than anything.
Old 06-13-2014, 06:28 PM   #12 (permalink)
Member
Ditto!!
Originally Posted by Bob O View Post
Mine balances perfectly with the two different packs I have. The long style pack is a PunchRC 6S 1500mAh 65C, and the short style is a Chrome 6S 1300mAh 35C. You can see how each is mounted. The ESC (Castle ICE Lite50) is on the right side near the front, and a WR High Current BEC is under the radio tray. I also have the mount for the canopy installed in the extended position.
This is with the stock tail, aluminum tail control lever mount, and Edge 60mm CF blades. Chinese weights are installed as well.
Old 06-13-2014, 07:50 PM   #13 (permalink)
Well I can't and I've more electronics on the front + an heavy esc. Weird. Do you actually measure the cg?
I've to place my 1600 2cm to the front.
Friend of mine just finished building and came to the same conclusion.
Old 06-13-2014, 07:55 PM   #14 (permalink)
Holding the ship by the rotor head, so that the blades are perpendicular to the ground seems to work best.
I believe Dave Ketelhut did a short video showing how to do it a while back.
Old 06-13-2014, 08:25 PM   #15 (permalink)
Member
+1
I do it this way for both my helis.
Though on a new build or with different batts, I will lift the heli by the head as it sits upright, just to check if the CG is in the ballpark. Then I will do it as you described, and as it shows in the vid, for a more accurate measurement.
Originally Posted by Jeff_Barrett View Post
You go way further than I do for CG ... lol ... don't get too hung up. I've seen guys go nuts with their pitch guages when trying to adjust their collective and cyclic pitch and drive themselves mad.
I use the same method that Dave Ketelhut and many other team pilots use:
Dave Ketelhut Talks COG Compass Warp360 - YouTube
Old 06-13-2014, 10:53 PM   #16 (permalink)
I balance mine as per the vid... With Gens 1400 packs mounted 2cm forward, compass esc inside the frame, vortex nano and spektrum sat mounted on the tray, it balances perfectly. Oh, and im running the canopy in the stock location.
Wayne
Old 06-13-2014, 10:56 PM   #17 (permalink)
"Sorry Ah Clem, I don't mean to sidetrack your thread, but I think it's related. I hope you don't mind a slight deviation."
I don't mind a bit.
To answer your question as to why a second one-I liked the first one so much I wanted another one.
Old 06-14-2014, 02:14 AM   #18 (permalink)
Ah OK that explains it. Wondering what was going on.
