Old 05-27-2012, 05:40 PM   #1 (permalink)
Exclamation Tail Problem
Hi all,
I have maiden flight today.
I couldn't get the tail to be solid, no mater want gain I have stetted up, slow wiggle all the time.
I ended up with 104 gain seems to be best but still tail is not rock solid?
Do I have bad sensor?
Im on HV septum with savox SB-2272SG
Logs do not show anything unusual, no vibrations on live log with bluetooth module.
Any ideas?
( I have shortened the vbar sensor wier a bit, is that could affect the preformance?)
Rob
_______________________________
TDR, Logo XXTreme, Goblin 700,
,Logo 600, Roxxter 55 FBL, Protos 500 FBL
Blitz Avro FBL, Kasama Sirmok 90 FBL
robpod is offline        Reply With Quote Quick reply to this message
Old 05-27-2012, 10:51 PM   #2 (permalink)
I don't know how bad yours is, but I had a minor slow wagging, say a couple of inches of movement at a pulse rate of about 1 or 2 per second. It didn't look like anything serious and was only obvious in hover.
I took main blades off, and took the tail hub off altogether. I spun up the heli and polished the tail shaft with silvo (I only had that, brasso would have been fine too) and got a really nice shine on the shaft. The pitch slider slid much more smoothly after that and the wag is all but gone.
I thought it felt smooth before I polished the shaft, but after I polished it I could really feel how much more silky it was.
Cheers,
Ant
Logo Xxtreme
Mini Protos stretch - Mini VBar
AusAnt is offline        Reply With Quote Quick reply to this message
Old 05-28-2012, 07:44 AM   #3 (permalink)
I had a similar issue and found three different problems. One was the assembly of the forward tail drive gears. Mine were assembled so they allowed a little bit of play. The second was one of the bearings in the tail gear box wasn't seated properly so it allowed a bit of play in the aft tail drive gears. The third was some binding on the pitch slider as Ant found. When I fixed all of those the tail was solid.
flymustangs is offline        Reply With Quote Quick reply to this message
Old 05-28-2012, 09:46 AM   #4 (permalink)
Check event log for VBar to see if it's glitches on the RPM channel.
http://heli.dacsa.net
Old 05-28-2012, 03:04 PM   #5 (permalink)
Hi
Logs show no problem at all
Wil post them later
Tail shaft is reall polished, all moves so smoth,
Any other ideas, should i change vbar sensor?
Rob
Old 05-28-2012, 03:09 PM   #6 (permalink)
Originally Posted by robpod View Post
Hi
Have you checked the thrust bearings so that you havenīt mounted them incorrect?
Logo 700
Logo 550SX , V-Bar, 3xBLS252, 1xBLS251
ola.c is offline        Reply With Quote Quick reply to this message
Old 05-28-2012, 03:23 PM   #7 (permalink)
Thrust berings ware already installed
I will check them again
Do you have pic how they should be installed?
Rob
Old 05-28-2012, 03:39 PM   #8 (permalink)
You didnīt disassemble and apply Loctite?
From page 8 in the manual:
Logo 700
Old 05-28-2012, 04:59 PM   #9 (permalink)
I did disassemble.
Forgot about it sorry.
Thrust bearings are ok.
I just noticed that when I turned head by hand I can hear very quiet click in the boom
When the shaft turns.
I will disassemble and double check .
Old 05-28-2012, 05:04 PM   #10 (permalink)
Here is my log:
http://db.tt/npPapgCh
Old 05-28-2012, 07:40 PM   #11 (permalink)
Rob.Bring it to the field sat or sunday.We all will take a look at it
matrosek is offline        Reply With Quote Quick reply to this message
Old 05-28-2012, 07:48 PM   #12 (permalink)
Maybe during the week
Im in PA sat and sun
Old 05-29-2012, 01:19 PM   #13 (permalink)
I think i have found the problem
What do you think guys?
Name:	ImageUploadedByTapatalk HD1338315521.531536.jpg
Old 05-30-2012, 12:50 PM   #14 (permalink)
Probably......
Unless the half ring has split, degrease them and glue back on the bearing with epoxy (carefully).
I had one come apart when checking mine.
Dr_K is offline        Reply With Quote Quick reply to this message
Old 05-31-2012, 09:33 PM   #15 (permalink)
That will do it!!
Laughingstill is offline        Reply With Quote Quick reply to this message
Old 06-01-2012, 06:30 PM   #16 (permalink)
Confirmed!!!
I have been flying all day today.
Tail rock solid. :-)
Great heli.
Rob
