Old 12-25-2012, 08:35 PM   #1 (permalink)
Default Dino - Question about umbrella gear..
Dino,
Lots of guys having problems with the new umbrella gear.. Too tight in the bearings, and some slop at the torque tube.. Is there a good reason not to leave the umbrella gear in place (white one) and just run the new tail output shaft? I have several torque tube heli's and have NEVER struck my blades on the ground and stripped a gear, so that's the least of my worries.. I'd prefer to just leave the white one in.. ??
Thanks!
TRex 700DFC CC 120HV/VBar
TRex 500 ESP/FBL CC Ice100, MiniVBar
TRex 600LE/ OS50/ Full Size VBar/ Arizona Regulator , FrankenBlade 400/Sonic head and tail/CF Frame, Blade MSR, Bunch o' planks.. DX7/Futaba 9C
Geardaddy is offline        Reply With Quote Quick reply to this message
Old 12-25-2012, 10:00 PM   #2 (permalink)
I'd like to hear an answer to this as well. It's unnerving that Align has yet to respond to the reports of bad fit with this 'fix' for the already dangerous tail problem
Blade 130X- My cul-del-sac flyer.
Blade 450X w/MSH Brain - My Ferrari
T-Rex 600 EFL Pro w/SK-720 BE, KDE600XF & SK-GPS - My BMW
T-Rex 700 HV DFC w/VBar, Kosmik 200 & KDE700XF - My muscle heli
HFMan is offline        Reply With Quote Quick reply to this message
Old 12-25-2012, 11:42 PM   #3 (permalink)
My question is that there are various combinations of different materials currently in use. Why would running the white TT gear with the new tail shaft really cause an increase in the wear of the umbrella gear, and to what extent?
If the wear is only nominally increased, my vote is to accept the wear, run a normal white TT gear and change it out when necessary. Yeh, it looks kinda goofy but that doesn't take the place of a poorly fitting TT, IMO.
Specter 700, Logo 700, Logo 690SX, Goblin 700, Trex 700DFC, Gaui X7, Trex600EFL Pro, Trex 600 ESP, Trex 500 ESP, DJI 550
Amain Hobbies Team Rep
rcflyerheli is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 07:51 AM   #4 (permalink)
I flew mine todaywith the new black gears...
loads of play in the torque tube.. none of my other torque tube helis have that much play in them...
She flew well though, and the tail held no matter what..
Would love to hear a good reason why black and white gears cannot be mixed.
EC225LP is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 09:17 AM   #5 (permalink)
It probably has to be tested to know how long it would last. But, if the new black gear contains a fibre reinforcement (it appears it does), this would be very abrasive to the white, unfilled material.
That's the why...how long it will last is probably not known.
Feeback is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 09:39 AM   #6 (permalink)
One other question. Is there a possibility that the new DFC specific TT end is slightly larger to accommodate the black gear size?
My gut feeling is this is just going to be the new material expanded more and didn't contract the same during the molding process, and Align isn't going to spend the bucks to do an EDM fabrication of a new mold. Just a guess.
Old 12-26-2012, 10:58 AM   #7 (permalink)
I have another question in my mind, is not recommended use black gear with white gear.
Now. Why there is no problem in using front black umbrella with the autorotation gear that is white?
Align 800e PRO DFC // KRAKEN Yellow // RAW Nitro // Align 700N DFC // RAW Yellow // 2x Goblin 420 // RAW 420 // RealFlight 7.5 // neXt // AccuRc // Tribunus - Vbar Control Touch - Vbar Neo
msallua is online now        Reply With Quote Quick reply to this message
Old 12-26-2012, 11:09 AM   #8 (permalink)
the reason the gear is tight is to keep what is called a interference fit but mine to where really tight i sanded the gear some and installed as for the loose fit on the tt end the white one i have fit snug that black slide right on with a tick of play and i have been running mine that way no issue so far, now as far as running white and black gears not sure how that will work out have to try it and see if the white wears out or gets play in it. The TT are the same for DFC i will send and email over and see what they have to say on this issue.
Dino
Dino Spadaccini Team Capt Align Factory Team USA / Team Futaba
Dino Spadaccini is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 11:13 AM   #9 (permalink)
Thank you for helping us Dino!
Old 12-26-2012, 11:22 AM   #10 (permalink)
+1, thanks Dino
Old 12-26-2012, 12:18 PM   #11 (permalink)
Thanks for looking into it Dino.. I'm working on fitting new umbrella gear this afternoon. Sanded it down a little bit.. Going to freeze the gear, heat the tail case and hope for the best!
Old 12-26-2012, 12:34 PM   #12 (permalink)
ok
Old 12-26-2012, 01:31 PM   #13 (permalink)
Personally, I'm staying with all the white gear, from front to back. Never had a problem with them on the Nitro, or the Electric. If it ain't broke, don't fix it....
At the precipice, we change!
Team GrandRC
ualdrivr is offline        Reply With Quote Quick reply to this message
Old 12-26-2012, 01:50 PM   #14 (permalink)
if you have no hum in the tail your ok
