Go Back   HeliFreak > R/C Helicopter Support > Compass Helicopters > Warp 360
Warp 360 Compass Warp 360 Model Helicopter Discussion
Old 05-14-2013, 08:56 AM   #161 (permalink)
I'm using 4 of the Punch Platinum 35C 1300 long packs. They weigh 265g and offer 4m of 3D on a 16t pinion w/ YGE governed as high as I can get it. Cells come down at 3.75V.
Cullen Colapietro is offline        Reply With Quote Quick reply to this message
Old 05-14-2013, 09:40 AM   #162 (permalink)
Default Re: Warp 360 6s Battery choice:(sticky plz)
What HS does that end up at with 16t?
___________________________
Sent via Android, Tapatalk. 7HV,Warp, 130XXX
rallyant is offline        Reply With Quote Quick reply to this message
Old 05-14-2013, 01:10 PM   #163 (permalink)
I haven't tached it... Sorry. I don't have the program card either, so it's not the highest governed HS one could expect out of a 16t. It could use just a bit more HS, but I like how it flies and I like 4m flight times better than 3.5m flight times.
Also, looks like cells are more like 3.78V.
Old 05-14-2013, 05:54 PM   #164 (permalink)
I only ask as Im considering trying a KDE 1750Kv with a 14t pinion
Old 05-15-2013, 06:04 AM   #165 (permalink)
[QUOTE=rallyant;4992272]I only ask as Im considering trying a KDE 1750Kv with a 14t pinion
Where are you going to get 14t pinion for 3.5mm shaft of this motor?
Vovets is offline        Reply With Quote Quick reply to this message
Old 05-15-2013, 08:44 PM   #166 (permalink)
Just Google 14t sM2 pulley.
Misumi sell14t bar stock. Can machine for whatever size motor shaft I want.
I might try and get a 13t. Smaller than recommend for the belts. But I have seem them around too.
Old 06-02-2013, 06:51 PM   #167 (permalink)
You could up the pinion size and use 4s packs with the KDE motor. It will draw more amps but I think the power will still be more than enough. Packs could be 1800/2200mah.
waxman is offline        Reply With Quote Quick reply to this message
Old 06-07-2013, 08:19 PM   #168 (permalink)
Well I just bought 2 gens 1400s looks like ill get a warp to go with them.
600 DFC HV
Pilot Brandon J.
bj660raptor is offline        Reply With Quote Quick reply to this message
Old 06-07-2013, 08:26 PM   #169 (permalink)
where at?
Sent from my phone using Tapatalk2...otherwise i would of sent it from my home PC.
you should look into it...........
crf69 is offline        Reply With Quote Quick reply to this message
Old 06-07-2013, 09:57 PM   #170 (permalink)
rotorquest 30 bucks for shipping but oh well. Ive never flown gens so I wanted them.
600 DFC HV
Pilot Brandon J.
Old 07-18-2013, 11:29 PM   #171 (permalink)
Hey guys,
I'm waiting to get my new Warp 360 any day and I'm still a little confused about the batteries that will fit.
I'd like to get the CoG correct and get maximal flight time out of it. And all that with the canopy mounted of course
I read here about this issue but the posts are quite old. Compass changed the canopy holes for new models didn't they? So all this canopy issue should be solved - even for bigger batteries...
In detail I'd like to try 1800mAh blue Turnigy 40C 309g with dimensions of length 113mm, height 34mm and width 39mm.
Does anyone know how that or similar packs fit inside the canopy and if they balance right?
thx
Soko
The future of setup... now! Soko Heli Toolbox app for a next generation setup experience.
ONE tool for ALL setups of ALL sizes and ALL brands of helis
www.soko-heli-tools.com
soko is offline        Reply With Quote Quick reply to this message
Old 07-19-2013, 02:34 AM   #172 (permalink)
These fit (below) So I would say those would. The is plenty of length under the canopy for the pack. Most mount them well past the the end of the tray due to CoG.
Length: 90mm
Width: 35mm
Thickness: 43mm
Weight: 260g
Capacity: 1500mAh
California Cabernet & Cuban Cigars
Warp 360 | HC-3SX | JIVE 80+ | HK 2520-1360 | MKS DS92A+/95i | Radix | DX8 | PL6 | GP 6S 1500
Mr-Mike is offline        Reply With Quote Quick reply to this message
Old 07-19-2013, 02:41 AM   #173 (permalink)
thx man
My length is almost 25mm longer - but if there's enough space to the front... thats good news
Soko
Old 07-19-2013, 06:34 PM   #174 (permalink)
Soko, with a battery that heavy, you may get away with the old canopy mounting arrangement. I run batteries in the 265g range and need to you the forward mounting option. I had to redrill the cano, not sure if this has been addressed by Compass.
Old 07-19-2013, 07:25 PM   #175 (permalink)
OK...
It seems I should give it a try. I'll report back what I've found out.
Soko
Old 07-28-2013, 09:46 AM   #176 (permalink)
Default Gens ace
Hello everyone.
Wanted to give you a heads up about the new gens ace packs designed just for the warp 360.
It's a 1600mah 6s 40c, and it will fit in and cog just right. Plus more flight time.
These packs are Awsome. I've got over a hundred flights on these and there still holding like new.
Chronos, 6HVU, atom 5.5, atom 500, warp 360
Compass rep / Team Gens Ace
Prostarhobby.com / Hobbypartz.com
Ghostrider267 is offline        Reply With Quote Quick reply to this message
Old 07-28-2013, 10:30 AM   #177 (permalink)
How is the weight of the pack??? What about CG???
flyfishsick is offline        Reply With Quote Quick reply to this message
Old 07-28-2013, 10:42 AM   #178 (permalink)
Default Gens ace
The 1200mah pack weighs 229g
The 1600mah pack weighs 284g
The extra weight really helps with cg.
You don't have to stick the batt way out on the frame. I can also get a good cg without the canopy with these where as the the other 1200's I would have them hang off the front of the Heli as far as I could and I still couldn't get good cg.
Here's what they look like next to the 1200mah pack
Old 07-28-2013, 07:15 PM   #179 (permalink)
Just picked up a couple for myself
Thanks for the post!!
Rockarruda is offline        Reply With Quote Quick reply to this message
Old 07-29-2013, 01:01 AM   #180 (permalink)
Bah, and I have a set of 1400mah gens packs arriving today to my door. Oh well, should be just fine
Goblin 700 Sport [spirit pro, hw130, xnova4525, bk kst servos, switch, gensace12s]
Warp 360 [SK540, yge v4 and other antique electronics, radix/edge blades]
uiron is offline        Reply With Quote Quick reply to this message
