Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > nano CP X Brushless Mods
nano CP X Brushless Mods Blade nano CP X Brushless Mods Information and Help
Old 11-23-2012, 12:30 PM   #21 (permalink)
Well yeah I don't think anyone is going to expect you to buy a new kit... Dylan has some of the best customer service around and he'll get you fixed up one way or another.
I don't know if this is relevant to your problem, but just because the stock setup would pull 100/100 pitch fine doesn't necessarily mean the brushless kit will. The BL motor is much faster so even though you're asking for the same amount of pitch travel, you're actually demanding a much higher climb rate. Make sense?
I'm not saying you don't have a problem with the setup, I think you do. I'm just saying it might not be fair to expect the same amount of pitch travel from a much higher headspeed.
What would be better to say, I think, is that the heli feels slower and less powerful than stock. Is that true? Because it definitely shouldn't be. The kit isn't going to make the nano act like a TDR, but it will allow you to do the same tricks as stock much easier and a bit quicker, with less bogging overall.
Just curious, how did you measure your HS?
MattRendall is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 01:41 PM   #22 (permalink)
Default bl no power
with a head speed tach on my phone. and yes with 2000 more hs it would pull 100/100.
4106 is low according to dylan. im going to send it to him
TEAM:
CYCLONE BLADES
matt blaisdell is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 02:11 PM   #23 (permalink)
I'll see what's up with it. Btw headspeed apps are not precise at all on the small stuff in my experience, I only trust optical tachs or data loggers.
And..none of My bl nanos run more than 85%or so pitch...
From tapatalk
Dylan ~ www.AstroidDesigns.com
Dylwad is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 02:16 PM   #24 (permalink)
From tapatalk
Could you post recommended tx settings? I made some install vids and would like to get all the necessary info someone might need all in one thread, that way they don't have to try and search through a dozen threads to find it all like I did. Thanks
Gaui X5-MiniVbar | Gaui X3-MiniVbar | Gaui X2 SK-540 | 250 Pro DFC |130X 3S GY280 | 300X-Ikon | DX8 | Real Flight 6.5
bmc76 is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 02:32 PM   #25 (permalink)
This is a stupid question but when tour talking about 85% pitch do you mean to change pitch to 85 from 100 in the travel adjust menu ( dx6i)???
mhmx233 is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 02:39 PM   #26 (permalink)
That's the thing, ask 10 people and you will get 10 different setups:rolleyes:
I run 75% flat throttle and 85-95%pitch depending on the setup, and battery/temp. Motors can have a variance in Kv, main shaft bearings seem fragile on the nano compared to the mcpx and can effect power too.
And different flying styles use different settings, not to mention small differences between transmitters.... Always best to experiment and fine tune to your taste, just like any other heli.
I was hoping a TX setup thread would pop up after a bunch of people for their bl nanos dialed in.
Thanks for the Vids btw, I Havent had the time to watch them yet though :o
From tapatalk
Old 11-23-2012, 02:40 PM   #27 (permalink)
Exactly
From tapatalk
Old 11-23-2012, 02:48 PM   #28 (permalink)
Some ppl leave the pitch curve linear and limit the end point for the pitch channel.
Daryoon is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 02:51 PM   #29 (permalink)
Default bl kit
well ok with the tach, but it still dose t answer why a stock motor out preforms a bl motor. unless its a bad motor. I was just hoping for results with awesome power and its not there. when i went to a 3s system on my 130x that was crazy results. although i went back to a 2s. ill sent to dylan and see whats up. just bummed
TEAM:
CYCLONE BLADES
Old 11-23-2012, 03:12 PM   #30 (permalink)
Im reading this for some time now matt but when you say krazy power you aint going to get that, not from a mild kit i dont think that was the intension.
I can tell you from my experience/my feel is at 68% TC flat it feel just a tad stronger better but i do agree the climb rate i think is slower then stock lol but i dont have a stock nano to compare. im running 100% pitch so i think im going to lower it as dylwad metioned this will help my bogging at the end of the pack.
Im going to a indoor funfly tonight and there i will be able to compare stock to bl nanos and will post back late tonight
Vbar Cont/Dx9 Align 600XN my first Nitro ! Original Goblin 500 stretched/Lynxed out Oxy2 now stretched and a few micros
Lynx Heli/Team pilot
thanasi is offline        Reply With Quote Quick reply to this message
Old 11-23-2012, 03:17 PM   #31 (permalink)
Default bl nano
thats not what im saying. i bought the wild kit. and my stock bl nano has more power and it should not thats what im saying
TEAM:
CYCLONE BLADES
Old 11-23-2012, 03:19 PM   #32 (permalink)
my bad sorry
Old 11-23-2012, 03:25 PM   #33 (permalink)
Smile bl nano
its all good. i just shipped it to dylan to test
TEAM:
CYCLONE BLADES
Old 11-23-2012, 03:53 PM   #34 (permalink)
I'm curious to hear the results. Let us know what he says.
Anyone wanna put some money on anything in particular wrong?
Sent from my Verizon Galaxy SIII
Old 11-23-2012, 03:54 PM   #35 (permalink)
I'll wager a software issue, but I have no money, spent it all on rc helis....
Old 11-23-2012, 07:14 PM   #36 (permalink)
I'm getting about 4900 rpm on the mild BL, vs 4800 with a new stock motor (100% throttle, 0 pitch, optical tach)
jbilliter is offline        Reply With Quote Quick reply to this message
Old 11-24-2012, 12:14 AM   #37 (permalink)
My Mild kit has way more power than stock. Run 80% flat and 125% throw. With a new/tight swash the tail is rock solid. Just love it! Once yours is fixed you will too
Micro: OMP Hobby M1
Big: SAB Goblin 500
Radio: Spektrum DX8 Gen 1
Old 11-25-2012, 06:56 AM   #38 (permalink)
Had the same problem. Disappointing power until I pre warmed my lipos in my pocket :eek:
Verstuurd van mijn GT-I9100 met Tapatalk
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro
velocity90 is offline        Reply With Quote Quick reply to this message
Old 12-01-2012, 06:08 PM   #39 (permalink)
Don't leave us hanging
Kendo is offline        Reply With Quote Quick reply to this message
Old 12-03-2012, 06:44 PM   #40 (permalink)
Default bl nano
got it back today ill keep you all posted. DYLAN worked on it its clean. this guy can solder
TEAM:
CYCLONE BLADES
