Old 08-25-2013, 02:47 PM   #21 (permalink)
yes.. there two totally independent chargers in these things.
Old 08-25-2013, 03:18 PM   #22 (permalink)
Dammit, the only store I found it here has it for 29 EUR less then the 4010.
700E Pro DFC, 550SX v2, 450 Pro DFC, mCPX BL, DX8
Crowbar is offline        Reply With Quote Quick reply to this message
Old 08-26-2013, 04:38 PM   #23 (permalink)
Yey!!! I've been waiting for this version and now it's finally here. Love the interface on these duos. However, at only 800W per channel it barely covers doing six 6S 5000mah at 1C (756W). If its efficiency is %90, it'll need 840W to charge at 30A. Anyone know of a vid that shows it working under these conditions? If not, I'll probably go with the 4010 instead.
Grok is offline        Reply With Quote Quick reply to this message
Old 08-26-2013, 04:46 PM   #24 (permalink)
I think you're math is a little off. At 90% efficiency (720w) you could charge a 6s 5000 pack at 28 amps which is just under 6c.
Gscott is online now        Reply With Quote Quick reply to this message
Old 08-26-2013, 04:58 PM   #25 (permalink)
Default Re: New iCharger 308Duo
He said he has 6 of them.
Grok, I have assumed that the watts, like amps, are output specs. And that efficiency losses have already been accounted for. You will need to supply more than 800W, but you will get 800W out, is my assumption.
You could combine the 2 channels for 50A/1300W. But if you are charging stuff that big, the 4010 may justify the extra money.
Sent using Tapatalk.
Old 08-26-2013, 05:22 PM   #26 (permalink)
RedOctobyr, it may well be that the 800 is after efficiency. Oh well... It's only money, maybe I should go ahead and get it, post a vid showing whether it can or can't do it, sell if it can't.
Old 08-26-2013, 06:17 PM   #27 (permalink)
I looked at the manual for my 106B+. It has a graph of output watts vs input voltage, based on the 21A input current limit.
It's a 10A/250W charger, and it lists the full 250W output, once the input voltage reaches somewhere around 13.7V. At the 21A current limit, 13.7V is 290W input, to get the 250W output. They do also list a 90% efficiency number.
That would seem to provide an example of an iCharger that's quoting output specs, not input.
Relative to the PL8, if charging 6S, this seems like kind of a good deal, based on specs. 2 channels, and a max of 50A/1300W, for $30 more than the single-channel 40A/1344W (or 1000W, if doing 6S) PL8. More output, and more flexibility. I realize that you have to compare more than just specs, admittedly. And I really hope FMA is working on a dual-channel that's smaller/cheaper than the Dual PL8.
Old 08-26-2013, 07:28 PM   #28 (permalink)
Damn. Just got my new 4010. The little I have been able to play with it, it is great. Powering mine with a SolidHobby 24V PS. It'll do what I need with that setup. Besides, I only have a 110V 20 A circuit in the shop.
G.
T-450 Sport FBL, T-550 V1 FBL, Red Goblin 700. Goblin 500. 350 QX. Bunch of little Blades, and Planks. DX8 G-2, Retired Full scale Jet Plank Driver, U.S. Navy Ret.
garyji is offline        Reply With Quote Quick reply to this message
Old 08-29-2013, 06:54 AM   #29 (permalink)
Ordered one last night since the balance board went dead on my 306b this weekend . I guess I'll be a guinea pig and see how it compares with my friends 4010.
jdplasvegas is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 06:11 PM   #30 (permalink)
Has it arrived yet? I'm curious to see what people think. Haven't seen any first-hand-use impressions yet.
Old 09-09-2013, 06:35 PM   #31 (permalink)
I can't understand why it comes with 6s balance boards. (there's a guy on the otheRR board who has one)
Jeti DS14us -- TT e700 -- 6s Logo600se UL -- Logo600-3d -- Logo500 UL -- Charge Case
prototype3a is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 06:38 PM   #32 (permalink)
The balance board is extra. All you need to do is get some squid cables.
Old 09-09-2013, 07:09 PM   #33 (permalink)
So, you're saying this 8s charger ships with 6s balance boards and that you have to pay extra to get 8s boards??
Old 09-09-2013, 07:21 PM   #34 (permalink)
The charger ships with nothing. You buy any board or squid parallel solution you want.
Old 09-09-2013, 07:25 PM   #35 (permalink)
That's not what the guy on the otheRR board said. Maybe ProgressiveRC is throwing a few extra goodies in the box.
Old 09-09-2013, 07:30 PM   #36 (permalink)
From their website...
QUICK OVERVIEW
High-power charger providing 30 amps on each of two channels - or combine the two outputs in parallel for up to 50 amp charge rates!
Includes a free JST-XH balance board for each channel!
Old 09-09-2013, 07:32 PM   #37 (permalink)
It comes with 2 6S balance boards... One for each channel.
I guess you just plug an 8S pack directly into the charger... Don't know about a 7S though.
dcope17 is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 07:38 PM   #38 (permalink)
This is as goofy as those PL8 combos that came with only 6s balance boards. At least when I get mine I will already have the gear for my 7s packs.
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 09-09-2013, 07:38 PM   #39 (permalink)
I was interested in it because someday, I want to build a 14s 700. But, I have absolutely no idea why this 8s charger comes with 6s balance boards.
Old 09-09-2013, 07:57 PM   #40 (permalink)
So realistically how long would 4 6s 5000 take on this charger provided you have a good enough power supply. (i will be running a 27v 1500w meanwell or 24v 1800 server ps haven't decided if the meanwell is worth the extra $$ yet)
Dsss is offline        Reply With Quote Quick reply to this message
