Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 09-12-2012, 01:26 AM   #21 (permalink)
I run a BLS251 and although reports say it's "OK", I'm not willing to risk it.
Compass 3D+ - OS55 Hyper/Hatori/Vbar
Atom 500
Tarot 450 Pro - AR7200BX
Spektrum DX8
Inverse is offline        Reply With Quote Quick reply to this message
Old 09-12-2012, 08:14 AM   #22 (permalink)
Same here....other LV tail servos are rated at 6v, but not the bls251. Why risk it when step down regulators are cheap.
Caralmar - If weight is an overall concern (with a heli this size I'm concerned) then give LiFe packs a serious look. They make wiring easier and cleaner and save weight. Lots of info on here about running LiFe packs. One primary concern is to make sure you have a charger rated for LiFe packs, or A123.
Minicopter Diabolo-14s-Pyro 800-Kosmik-Vbar
Voodoo 400 SK540
ChadL is offline        Reply With Quote Quick reply to this message
Old 09-12-2012, 08:18 AM   #23 (permalink)
I have been running a BLS251 on my TDR @ 5.6v through the Jive 120 BEC for many flights no problems.
My E750 has a BLS251 at 6V, no issues.
Someone once posted a link to the European site that speced it at 6V, can't find the link now.
Synergy Factory Specialist / Rail Blades / Team Scorpion
Chris Sexton is offline        Reply With Quote Quick reply to this message
Old 09-12-2012, 08:54 AM   #24 (permalink)
I've seen some reports too, but just don't want to risk it. I had a bls251 fail (on the bench thankfully) and I wasn't running a step down on that servo. Keep in mind LiFe packs run at 6.6v (I'm sure you know that). Perhaps the 1.8v difference was just too much for that servo? Too each their own, and in my case I like the peace of mind running a step down gives me.
Voodoo 400 SK540
Old 09-12-2012, 09:06 AM   #25 (permalink)
My lhs was able to secure 4 kits from a source at release and I should have one. Just starting my box, lhs has the motor but no pipe....owner snagged the last one from heli proz for his lol.
Not sure what servos I'm going to run, never ran a machine with this size servos. I usually run the torq hvs in my big birds and the mks 92+ in my smaller machines. Also not sure on FBL unit yet. I run a beast x with throttle Jockey and Rev Glo and love it on my Synergy, not sure the nx4 has the room. May try brain or the 540 for an internal governor.
Team Synergy
VP Racing Fuels
Team Scorpion
Gawl is offline        Reply With Quote Quick reply to this message
Old 09-12-2012, 03:01 PM   #26 (permalink)
My problem is unfamiliarity with the LiFe chemistry. I have an iCharger 208B... dunno if it will do LiFe or not. What I've heard about them is that you can't tell how much charge they have by just looking at the voltage...is that correct?
Also, the servos are rated at 6v (DS510s)... so 6.6v gonna be ok?
Decisions, decisions!
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is offline        Reply With Quote Quick reply to this message
Old 09-12-2012, 03:29 PM   #27 (permalink)
The iCharger 208B is rated for LiFe packs. One of the reasons LiFe packs work so well as a receiver pack is they maintain 6.6v for a long portion of the capacity. The downside is it is difficult to get an idea of how much capacity you have left. They'll hold 6.6v and then drop very sharply. They're not like lipos where you can see a more linear decrease in voltage as capacity is used up.
What I've done in the past with LiFe packs is only fly 2-3 flights on each pack and then see how much capacity I put back in. I do this a few times to get a good sampling. Based off of how much average capacity I put back in I know how many flights I can safely get out of each pack. I don't even use a volt meter. On my Srimok once the pack has 7 flights I replace it, no questions.
I've been running Align, and Futbaba 6v servos at 6.6v for quite some time now with no problems at all.
Voodoo 400 SK540
Old 09-12-2012, 04:13 PM   #28 (permalink)
Good to know!
Looks like a couple of LiFe packs are in my future. Figure 1900mAh or so would be a good size for this heli?
AMA #934662
Old 09-12-2012, 06:11 PM   #29 (permalink)
Good to know!
1900mAh may be a bit heavy. If I remeber JC's setup he is running a ~1500mAh LiFe pack. I'll probably run the 1300mAh Hobbico LiFe pack.
Voodoo 400 SK540
Old 09-13-2012, 05:57 AM   #30 (permalink)
What are your plans for igniter? Can you fit a switchglo type of thing in the NX4? Or just go with the single igniter to reduce weight?
Goblin 700, Goblin 380, Gaui NX7, T-Rex 700N, T-Rex 450
iKon, because I am connected to my heli. Are you connected to yours?
RCHN #15
PauloG is offline        Reply With Quote Quick reply to this message
Old 09-13-2012, 06:06 AM   #31 (permalink)
I'm going to use a pushglo. I have one as a backup to my switchglos. I think a switchglo may be a bit bulky.
Voodoo 400 SK540
Old 09-13-2012, 06:19 AM   #32 (permalink)
I have an extra SwitchGlo so that's what I'm using.
AMA #934662
Old 09-16-2012, 03:34 AM   #33 (permalink)
Registered User
Man you guys got me thinking. I may just go LiFe myself unregulated and get a pushglow and just keep it simple. Man decisions decisions.
William James
Old 09-16-2012, 03:36 AM   #34 (permalink)
Registered User
Thank you for the info. I think I will go this route as well.
William James
Old 09-16-2012, 05:52 AM   #35 (permalink)
Yeap, I think I would build that way on this bird as well, because of space and weight.
RCHN #15
Old 09-16-2012, 06:48 AM   #36 (permalink)
Registered User
It would be great if someone would put a parts list together so we can just get it ordered.
I am also going with a beast x on this machine as I don't have an extra v-bar to spare. I may go beast x on my E5 as well.
William James
Old 09-16-2012, 07:48 AM   #37 (permalink)
Was thinking the same with throttle jockey for a governor but was thinking either brain or the 540 for an internal governor and to save some weight.
Team Synergy
VP Racing Fuels
Team Scorpion
Old 09-16-2012, 11:54 AM   #38 (permalink)
Registered User
No GOV for me, curves baby. After flying primarily E for a few years, looking forward to curves again. Might even get a gasser to get back into the hockey stick curves.
William James
Old 09-16-2012, 02:34 PM   #39 (permalink)
I don't have any experience with the brain....including the one in my head
I have a SK540 and the nitro gov on the SK540 works pretty well. I don't know what I'm running for a FBL controller yet, but the 540 does perform well. If Futaba would get the issues with the CGY sorted then I'll run that. I have 3 laying around and the gov on the CGY is outstanding (really easy to setup).
Voodoo 400 SK540
Old 09-16-2012, 06:19 PM   #40 (permalink)
Why curves over governed?
Team Synergy
VP Racing Fuels
Team Scorpion
