Old 11-30-2008, 09:30 PM   #141 (permalink)
no flights videos (no one willing to get that close)
I am running a 12 tooth pinion.
My heli weighs in at just over 1900grams (and it doesnt have a flybar)
yes 25C Outrage.
I see the Neu 1706 is ready https://www.helifreak.com/showpost.p...3&postcount=71
Mick
aussiemick is offline        Reply With Quote Quick reply to this message
Old 11-30-2008, 09:35 PM   #142 (permalink)
Where I can buy this motor (Medusa 32-50-1300V2)?
Thanks.
Evaldas
epkencijus is offline        Reply With Quote Quick reply to this message
Old 11-30-2008, 09:37 PM   #143 (permalink)
Thanks.
Evaldas
I will sell you mine now that i see the NEu is out.
or if that doesnt suit, http://www.medusaproducts.com/motors/036-V2.htm
Mick
Old 11-30-2008, 09:51 PM   #144 (permalink)
This motor? http://www.helidirect.com/product_in...oducts_id=8025
Evaldas.
Old 11-30-2008, 10:53 PM   #145 (permalink)
No you will need one with a 5mm shaft. Unless of course you can find pinions suitable with a 1/8" (3.18mm) bore.
Mick
Old 11-30-2008, 11:06 PM   #146 (permalink)
I read about NEU 1706H/1.5y This motor made for 6S lipo.
How You think I can use on the 8S?
Video with 6S lipo: http://www.youtube.com/watch?v=xYC55hYdh8Q
And also wath you think about 1910H/1.5Y and 1907H/1.5Y motors with 8S setup?
Evaldas.
Old 12-06-2008, 11:26 AM   #147 (permalink)
Originally Posted by Finless View Post
I am currently testing the new 30C outrage 2500... DAMN good so far!
I need to get some flights on them to see longevity.
Bob
Any updates on these Bob?
1 - T-Rex 600E: Stock, DX7 - AR9000, JR-G7703D, 2 - TP 6S 5000mAh
1 - T-Rex 500E: CF, DX7 - AR9000, JR-G7703D, 2 - Protek 5S 4000mAh
2 - T-Rex 450E: CF, DX7 - SPM6100, Align - RCE-500X , 4 - TP 3S 2100mAh
W4DJW is offline        Reply With Quote Quick reply to this message
Old 12-18-2008, 11:56 AM   #148 (permalink)
I run a scorpion 1400kv with outrage 6S 3000's and a 15t pinion.
Standard Align ESC with throttle curve at 100/90/100. Flight time is around 5.30 minutes. Putting around 75% back in when charging and Im not doing hard 3D. Circuits/inverted/flips/loops/rolls/stall turns, (180's and 540's), etc
Mouldy is offline        Reply With Quote Quick reply to this message
Old 12-20-2008, 04:49 AM   #149 (permalink)
HI mouldy...
you running the 3026 -1400 or the 4026-1400..
after reading this thread it get a bit confusing...
sorry about my ignorance..
Cause I have been flying my Stock motor for awhile now and after reading these thread about more power..
I've decided to change my motor.. as much as i want to try the Neu or the medusa motor.. its not within reach in this part of the world.. the only motor i can get here is the scorpion motor....
thanks,
quester
questerng is offline        Reply With Quote Quick reply to this message
Old 12-22-2008, 02:32 PM   #150 (permalink)
3026, sorry! Should have said!
Old 12-25-2008, 12:01 PM   #151 (permalink)
Default bigger motor
o,k guys it,s been said but i can,t find it
what about putting a 600 motor in my 500? can this been done?
will it be to heavy?
i,m gonna get a 1400 scorpion but
i like the stock align one,s
so what is better?
hawkins221 is offline        Reply With Quote Quick reply to this message
Old 12-25-2008, 03:04 PM   #152 (permalink)
Question 1706H/1.5y - Will it work with the Kontronic 55-10-32?
I heard the 1905/1.5Y would not work with the Kontronic. Will the new 1706 work with it? Also, do you have to mod the frame to fit the new 1706?
Also, can you tell me why the Kontronic would not work with the 1905/1.5Y?
Thanks in advance
Stet is offline        Reply With Quote Quick reply to this message
Old 01-04-2009, 05:35 AM   #153 (permalink)
Thanks in advance
I certainly hope so!!
I have just ordered the 1706 and have a 55-10-32 in the heli now.
I will be running mine on 8S.
Mick
Old 01-04-2009, 07:09 PM   #154 (permalink)
that should be sweeeett Mick! Let us know how it works! When my paks play out, I'll look at going 8S.
conrod is offline        Reply With Quote Quick reply to this message
Old 01-05-2009, 05:30 PM   #155 (permalink)
Default scorpion motor will not fit stock motor mount
Hi guys,
I've just got a scorpion 3026-1400.. I think its the old model that has a collar at the base of the motor sharft..
I'm using the stock upgade pinion 15T..
when i mount it on.. the pinion shoulder where it taper out is rubbing the main gear..
has anyone got this problem before... I was told that the RHINO gear fit better..
I would rather use back my 15T then to get another gear..
Has any body done this before..
the way i look at it is to find metal spacer to lower the motor so that it will bring the pinion down as well
I've tried using metal washer of 1MM.. but it need at lease 2 to 3mm.. so my worry is with 2 or 3 washer.. I'm not really comfortable because the contact between the motor and the motor mount will only be this washer area..
Has anybody tried another method before..
thanks
quest
p.s. Will the stock ESC work with this motor
I'm running align 6S 2500mah(old batt) new one is 2600mah
I'm running gov mode... should i run 100% flat.. and what HS will i get..
cheers
Old 01-05-2009, 06:54 PM   #156 (permalink)
found the thread...
thanks
Old 02-26-2009, 09:03 PM   #157 (permalink)
long story short, i had to make a 6s into a 5s, will this be ok for just hovering or should i just save it for something else. this is in a bone stock 500
rritchiev is offline        Reply With Quote Quick reply to this message
Old 02-26-2009, 09:34 PM   #158 (permalink)
Change the pinion to a 15t, if you have other good 6s batteries then not a good idea.
Redfire SVT is offline        Reply With Quote Quick reply to this message
Old 03-26-2009, 05:55 PM   #159 (permalink)
Default Power for the electronics question
Just curious here... What are guys doing to power the electronics?
I'm installing a CC Phoenix 80 ESC which has a BEC built in... is that adequate? What about just using a separate 10 AMP BEC? Or should I be providing a separate power supply all together? I'm using all digital high quality servos and powering the latest motor from Steve Neu.
I do actually have a full Duralite regulator system which uses a separate battery but am concerned about the added weight...
Anyway, just wondering what other guys are doing.
Thanks!
HoverOver is offline        Reply With Quote Quick reply to this message
Old 03-26-2009, 10:01 PM   #160 (permalink)
I run a Sports BEC at 6V, powered off the main flight battery.
mick
