700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-09-2012, 07:18 PM | #61 (permalink) |
700e DFC / KDE 700XF-495 and mount CC Ice2 HV120 / BEC Pro Sk 720 Flybarless / Batt Bus |
12-09-2012, 07:41 PM | #63 (permalink) |
Yup, this is like a movie, I am going to start on some Ben and Jerry Peach Cobbler ice cream here, shortly....
Velos 880/Sab Urukay, KSE, Carbon Speed/Mikado Uvular/RCA Blackshark/Chaos 500 Evo, 550, 600, 700/Trex 500, 600, 600 Pro, 700/Roban 470 Cobra, 700 Apache, Cobra, 429, Jayhawk, 800 Airwolf/TFM 800 Blue Thunder, Seahawk, Jayhawk/ DX8 DX18QQ |
12-10-2012, 08:08 AM | #64 (permalink) |
Sladex, watch some of Finless Bobs build and set up videos. He does a pretty good job of explaining things.
https://www.helifreak.com/showthread.php?t=41692 Watch them and your knowledge will grow faster and less painfully. And even though you didn't fly with that repaired link, even turning it up on the ground things can go bad wrong in a heart beat. Whether you are in the air or not, once those blades are spinning, you are flying. Too much stick will roll it right into the ground.Or something else.
12-10-2012, 09:29 AM | #65 (permalink) | |
12-10-2012, 11:00 AM | #66 (permalink) |
How much stick and sim time do you have in? How many other helis?
AMA 373608 |
12-10-2012, 05:36 PM | #68 (permalink) |
I've been busy lately and haven't flew for a week.
https://www.helifreak.com/showthread.php?t=478537 |
12-10-2012, 06:11 PM | #69 (permalink) |
MAIDEN IN 10 MINUTES. SO EXCITED!!!!!!
12-10-2012, 06:30 PM | #70 (permalink) |
So what time is the vigil ceremony?
☆☆☆AMA #1039539 |
12-10-2012, 07:08 PM | #71 (permalink) |
Its over. Unfortuantly didnt turn out well. I aborted. The helicopter wants to spin vigirously to the left. I tried trimming and everything. I didnt get it off the ground due to this reason. It didnt tip over or anything luckily. So its in tip top shape.
12-10-2012, 07:27 PM | #72 (permalink) | |
It has nothing to do with trim. There are a number of things at play here. Rate vs head hold, servo direction and gyro direction. Here is how you test. Give right rudder and note the direction of the tail blade, then move the heli to the left, the tail blade should move in the same direction as when you gave right rudder. There is other setting still that could be wrong even if this test passes, Sent from my iPad using Tapatalk HD
Its all about having fun |
12-10-2012, 07:30 PM | #73 (permalink) | |
12-10-2012, 07:38 PM | #74 (permalink) | |
12-10-2012, 07:40 PM | #75 (permalink) |
I noticed somethign very strange. When my helicopter is on normal mode, bx not on setup mode or anything, it has a full left rudder input. But when i got to the bx and hit tail center, it goes center.
12-10-2012, 07:54 PM | #76 (permalink) | |
Yes, in setup centering is acquired to help you setup. Sent from my iPad using Tapatalk HD
12-10-2012, 07:56 PM | #77 (permalink) | |
On your dx8, rate mode is 0 to -100. In rate mode, the tail will return to center position when you let go of stick. In gyro heading hold mode, the numbers go from 0 to +100, HH mode, the tail will sit in the last position you left your tx stick...
12-10-2012, 07:56 PM | #78 (permalink) |
Fancy words.... Lol. So what can I do. It passed your test . And I have a lot of right trim in there to center the rudder, is that ok. Each side gets almost exactly the same amount of throw
12-10-2012, 07:56 PM | #79 (permalink) |
I sure hope your head setup doesn't have similar setup issues, it will go bad so fast.
12-10-2012, 07:57 PM | #80 (permalink) | |
